KLN94 "Flagged" When Database Out of Date
Old September 6th 04, 12:52 PM
AMW
Default KLN94 "Flagged" When Database Out of Date
My cartridge update for Sept didn't arrive and my database went out of
date - I called Honeywell and they are reshipping, but in the mean
time I've run into a problem. The KLN 94 came up in Nav mode like
normal for the first three days of September, but then on the fourth
day, it came up "flagged" and refused to go into Nav mode. It passed
the internal self check tests although didn't show a radial for the
current position. The KMD880 showed the flight plan but with the
message no external position. Has anyone else had this kind of a
problem when a database went over cycle..... or am I into something
more serious?
AMW
Old September 6th 04, 01:22 PM
Peter R.
more serious?
The KLN94 GPS databases in two of my local flight school's late model
C172s are always out of date, sometimes by several months. The GPS's
do not flag.
Using this as a guide, I would suggest you talk to your avionics
specialist about a more serious problem.
Peter
Old September 6th 04, 03:11 PM
john smith
more serious?
The GPS should work normally, but you will not be able to use the
approaches.
If the GPS is unusable, something else is wrong.
Old September 7th 04, 03:29 AM
Mike Rapoport
Or perhaps it can be setup to do this.
Mike
MU-2
"Peter R." wrote in message
more serious?
do not flag.
Peter
Old September 7th 04, 02:29 PM
Peter Clark
FWIW, watching the shop guy configure the replacement for my bad 94
there wasn't anything like that anywhere in the configuration screens.
On Tue, 07 Sep 2004 02:29:24 GMT, "Mike Rapoport"
Mike
MU-2
more serious?
do not flag.
Peter
Old September 7th 04, 02:42 PM
Maik
Sometimes you will find hidden functions after a few keystrokes which
are only described in the installation and config-manual. Maybe the 94er
has some.
Mike
MU-2
more serious?
do not flag.
Peter
Old September 7th 04, 03:56 PM
Mike Rapoport
Some of the installation options are in the wiring.
Mike
MU-2
"Peter Clark" wrote in message
Mike
MU-2
more serious?
do not flag.
Peter
Old September 7th 04, 08:48 PM
Peter Clark
On Tue, 07 Sep 2004 14:56:46 GMT, "Mike Rapoport"
OK, I happened to be in the shop today for a transponder check and
asked. There are no harness strapping or configuration wires on the
KLN94, it's all done through the maint pages (install manual page
2-65), and there's no selection that can be made in the maint pages to
make the unit disable itself just because the database is expired.
Would be nice if the original poster would report the status to see
what it was?
Mike
MU-2
Mike
MU-2
more serious?
do not flag.
Peter
Learning the KLN94 GPS DH Instrument Flight Rules 7 April 7th 04 06:28 PM
What approaches are in a database? Ross Instrument Flight Rules 11 January 4th 04 07:57 PM
