allowable compass error...
Old June 19th 06, 03:17 PM posted to rec.aviation.piloting
Default allowable compass error...
Thanks, I know about compass roses and swinging the compass. What I'm
looking for is an indication that the compass needs swinging. That's why my
hypothetical scenario stated that the runway alignment is correct. That does
happen, by the way, even if the odds are against it.
"RomeoMike" wrote in message
Don't know, but if you are using the runway heading to judge whether your
compass reading is in error, remember that runway headings are not always
true. There are other ways to calibrate your compass.
Casey Wilson wrote:
My FARAIM is at my daughter's house and I can't find anything on the 'net
to answer my questions. Please indulge me....
Scenario:
1) line up with runway centerline[for my hypothetical, the runway is
dead nuts to the compass]
2) note compass heading
3) add/subtract compass card correction
Questions:
1) How much error is allowable between known heading and corrected
compass reading?
2) Does a significant error down the airplane as unworthy?
3) Where can I find applicable references?
Old June 19th 06, 10:35 PM posted to rec.aviation.piloting
I had a thought, what do you think? If you are tracking a radial on a VOR
couldn't you compare the radial to the compass heading and get a good idea of
the compass error?
GeorgeC
Old June 19th 06, 10:56 PM posted to rec.aviation.piloting
I've got no problem with that George, as a general indication of
discrepancy. On the other hand, I sure that some of the nitpickers in our
RAP community would want to immediately toss in the VOR calibration and
accuracy, crab angle caused by crosswind drift relative to the actual course
versus heading, yadda, yadda...
What my question really is, is how much difference (for discussion I'll
agree that the method described is acceptable) between that compass heading
and the VOR radial is tolerable before the airplane should be grounded and
the compass readjusted, repaired, or replaced? Secondly, what is the
applicable reference for that?
"GeorgeC" wrote in message
of
the compass error?
my
does
GeorgeC
Old June 20th 06, 12:52 AM posted to rec.aviation.piloting
A 100 KIAS with a 50 knot 90 degree crosswind can be flown
without any compass at all, you just need a stable heading
reference, but it is so far from being close to any easy
reference, it tells you nothing about the compass accuracy.
You need an accurate compass/heading reference for ADF
tracking and it does help with getting and staying on course
with radio navigation.
The question is not how bad can it be, but how good can it
be.
James H. Macklin
ATP,CFI,A&P
"Casey Wilson" N2310D @ gmail.com wrote in message
news:Y3Flg.22377$YI2.20622@trnddc01...
indication of
nitpickers in our
calibration and
the actual course
discussion I'll
be grounded and
what is the
a radial on a VOR
and get a good idea
| of
| the compass error?
@ gmail.com
compass. What I'm
| my
is correct. That
| does
| GeorgeC
Old June 20th 06, 03:57 AM posted to rec.aviation.piloting
I misread read your post. I "read" that you wanted to check to see if your
compass was out of tolerance, but your question was what were the tolerances.
Which I see James answered.
GeorgeC
Old June 19th 06, 11:17 PM posted to rec.aviation.piloting
No, the radial can be flown on any heading. What you can do
in parts of the country that have been laid out with section
line grids of roads and highways, is fly a heading along a
road and not correct for drift. These roads were laid out
to true north/south/east and west. You can apply the local
variation to get the magnetic of that road. You manually
set your heading indicator and then turn to magnetic north,
etc, and check the compass. You can thus swing the compass
in-flight on every 30 degree heading and write down the
observed error. You should probably do this with various
combinations of configuration.
I remember a twin that had a compass error of 30 degrees if
the left alternator was off-line. I seem to remember that
the problems was in the right alternator, the compass would
point to the right engine.
You're probably most concerned about compass errors when the
compass is all you have, so I'd check with alt/gen off,
radios off as well as with all systems on-line. Make a grid
and fill in the blanks. Check the heading indicator on each
true road to be sure that you have compensated for gyro
drift. If you have a remote compass, manually set the
heading to check at least the four headings on the road.
If you find any errors greater than 10 degrees on any
heading, you will need some professional assistance to
determine why and fix the problem. It can be electrical
leakage, or some local magnetic item, even a lightening
strike could have magnetized the engine mount or other steel
parts of the airplane.
James H. Macklin
ATP,CFI,A&P
radial on a VOR
get a good idea of
| the compass error?
compass. What I'm
correct. That does
| GeorgeC
Old June 20th 06, 12:12 AM posted to rec.aviation.piloting
the compass error?
Only with no crosswind.
Jose
PZL Compass Dave Springford Soaring 3 December 7th 05 04:05 AM
Do you use your magnetic compass? Roger Long Piloting 42 May 25th 04 12:08 PM
Strange compass behavior me Owning 10 February 14th 04 04:24 AM
Compass turning error Marty Ross Piloting 3 August 21st 03 02:53 PM
