Fiberglass vs. Fabric
Old June 19th 06, 04:06 PM posted to rec.aviation.homebuilt
Default Fiberglass vs. Fabric
Lou wrote:
What you described is what my plans call for. Wooden ribs with plywood
over but
routed inbetween. Then on top of the plywood I'm to install the fabric.
This is just one
of the areas that I want to replace the fabric with fiberglass. It is
obcviously not structural.
So replacing with fiberglass should give me a smoother, harder finish.
Also, I would like to know if this finish will give me a better gph for
trips not to mention maybe, just maybe a few more knots. Yes I would
love to talk to your friend.
Lou
Ahh so the fabric is to be a non structural skin over open bays like any
normal fabric covering. If you apply a rigid glass/epoxy skin it will
be the same as skinning the entire wing in plywood.
The ply is routed out between the ribs to save weight in an area where
the ply provides no structural benefit. If you want to create a rigid
glass/epoxy skin over an area that is normally covered with flexible
fabric it will have to be stiff enough to support air loads without
deforming. It will be much heavier than a fabric layer would be.
You might as well skin the entire wing in ply and use a minimal glass
layer as a protective coating. Either way you are going to end up with
a much heavier wing.
A rigid skin in the area aft of the spars designed for open bays with
flexible fabric will make no significant difference in speed if the a/c
goes under 150 mph, and it will cost you many pounds in weight.
Use a polyurethane covering process on those areas intended for fabric
over open bays. Only use glass/epoxy only on fully skinned components.
John
Old June 19th 06, 05:23 PM posted to rec.aviation.homebuilt
Hi John,
One of the idea's I came across was to insert styrofoam into the wing
under the routed plywood to keep the wing shape. Then apply the
fiberglass over the entire wing. Do you think this will be a waste of
time?
Lou
Old June 19th 06, 07:25 PM posted to rec.aviation.homebuilt
Having read his book, I think that is exactly what Bingelis did, with
either the wing, or the fuselage, or both.
The advantages were a smoother surface, though I daresay proper
wood finishing technique would produce as smooth s surface
with considerably less work and wieght, and improved resistance
to the elements.
I believe he said it added 10 to 15 lbs to the plane.
FF
Old June 19th 06, 08:22 PM posted to rec.aviation.homebuilt
to the elements.
FF
I wonder if the thin glass skin, over the plywood, would eliminate the
sagging 'tween rib bays that a Pulsar builder experienced. He was skilled
at woodworking, IIRC, but complained about sagging 'tween rib bats in humid
weather. I don't know the details, unfortunately.
As I indicated in a previous reply to this thread, he routed out the plywood
and fabricated sheets of fiberglass/epoxy as a thin "skin" that he then
applied as if it was plywood skin material. No sagging and he liked the
result. I have no details about weight penalty, engineering changes (extra
thickness all around because of the plywood over the ribs, spar, etc.).
I am trying to locate the Pulsar builder to see if his experiences could be
made available for this thread.
Michael Pilla
Old June 19th 06, 11:41 PM posted to rec.aviation.homebuilt
On Mon, 19 Jun 2006 13:22:00 -0600, "Michael Pilla"
FF
Probably coating the entire plywood covered wing, inside and out with
cladding epoxy would eliminate the changes brought on by humidity
variations.
Old June 20th 06, 05:03 AM posted to rec.aviation.homebuilt
variations.
You may be familiar with "Wood/Epoxy Saturation Technique"
That has been used in boat building for decades?
How about "WEST systems" epoxy?
Yep - that's where the "WEST" in WEST systems comes from.
The wood gets soaked all the way through, so the wood is just there for
support, and it seems to last forever.
I BOILED some samples for 24 hours with no degradation other than a bit of
color change. Add light fiberglass over that...
Old June 20th 06, 07:30 PM posted to rec.aviation.homebuilt
variations.
In furniture making it is considered important to finish both sides
of a piece of wood the same to maximize dimentional stability.
Otherwise the rate at which moisture enters or leaves one side
of the board is different from the other so that whenever there
is a rapid change in humidity one side swells more than the other.
IOW, I tend to agree with the statement above, but the same
would be true for varnish, shellac, paint etc, so long as it was
the same inside and out, and the wing was vented so that the
humidity inside the wing was the same as outside.
Of course the sun only shines on (and dries) the outside.
Hve you tried cutting through a sample? My understanding is that the
epoxy will not penetrate any deeper than 1/16" through side grain,
and it would be VERY unlikely to penetrate past the glue beneath
the surface veneer in plywood. It woudl penetrate farther up the
endgrain, but since epoxy hardens pretty fast I doubt it would get
very fat that way either. You can saturate a board with linseed oil,
or mos taly oil, by leaving one end in a bowl of oil overnight.
Did you compare bending strength before and after? What is the
glass transition temperature for WEST system epoxy?
No question that it's good stuff, but it's not magic.
FF
Old June 21st 06, 01:40 AM posted to rec.aviation.homebuilt
of
Well, actually I made up a long sample with 2 1" wide strips glued (with
fillet) together at a 90 degree angle. Then
I cut this into samples, each about 1" long. Then I took these little "T"
shaped samples, and subjected them to all sorts of things.
They were made of Finnish Birch 3 ply (3mm thick, but quite dense.) It
looked like it had penetrated to me - and they sure stayed together fine. I
boiled several of them, and broke them afterward. The wood gave before the
glue in all cases.
I've also tried this with 1/8" Okume. Same result, but that stuff is porous
enough that I'm pretty sure it soaks all the way through. I've been meaning
to try it with that unfinished mahogany indoor plywood. If that "soaks all
the way through" stuff works, it would be usable as a core, so I could use
much cheaper material (for boats at least).
As for the glass transition temperature, I think most epoxies are in the
140F range. After they cool they will return to much the same condition they
were before though. The extra cure may even be beneficial. That's just a
dull memory though. Correct me if I need it, but the boiled samples really
did stand up fine (I'm looking at one now).
Fabric repair D.A.L Home Built 0 April 27th 04 07:17 PM
Replace fabric with glass Ernest Christley Home Built 38 April 17th 04 11:37 AM
Fabric Work Doug Home Built 9 January 26th 04 03:31 AM
Need to learn dope and fabric work David Hill Restoration 5 October 9th 03 01:52 AM
Fiberglass Tip Tanks Question Jay Honeck Owning 7 September 26th 03 04:23 AM
