![]() "Jose" wrote in message .net... I suppose this would be true, as the actual regulations are in part something-or-other, and it is not required that one even have the chart, just the textual description of the approach. Nonetheless, I would expect pilots not to second-guess government publications in that manner; after all part something-or-other might also have a misprint. If it is an error, it should be NOTAM'd until it is reprinted. Absent a NOTAM, I would expect pilots to rely on the government publication that contained the putative error. In what manner would you expect pilots to rely on the note "ADF REQUIRED" on the SAC ILS or LOC RWY 2? When ADF is actually required on non-NDB approaches the note "ADF REQUIRED" adds nothing to the approach, it simply states a fact. When the note appears on an approach that can be flown without ADF it only creates confusion. FAA Order 8260.19C Flight Procedures and Airspace CHAPTER 8. INSTRUMENT APPROACH PROCEDURES DATA TRANSMITTAL SYSTEM SECTION 3. COMPLETION OF FAA FORMS 8260-3/5 814. NOTES. h. Equipment Requirement Notes. Determine the need for equipment notes after evaluating all SIAP segments, including missed approach. To avoid proliferation of equipment requirement notes, all IFR aircraft are assumed to have at least one VOR receiver. Therefore, the note "VOR required" is not appropriate. VOR, ILS, or other non-ADF approaches may require ADF for procedure entry or missed approach. Use standard Note: "ADF required." If radar vectoring is available, use standard Note: "ADF or radar required." |
Steven P. McNicoll wrote:
"Jose" wrote in message .net... I suppose this would be true, as the actual regulations are in part something-or-other, and it is not required that one even have the chart, just the textual description of the approach. Nonetheless, I would expect pilots not to second-guess government publications in that manner; after all part something-or-other might also have a misprint. If it is an error, it should be NOTAM'd until it is reprinted. Absent a NOTAM, I would expect pilots to rely on the government publication that contained the putative error. In what manner would you expect pilots to rely on the note "ADF REQUIRED" on the SAC ILS or LOC RWY 2? When ADF is actually required on non-NDB approaches the note "ADF REQUIRED" adds nothing to the approach, it simply states a fact. When the note appears on an approach that can be flown without ADF it only creates confusion. FAA Order 8260.19C Flight Procedures and Airspace CHAPTER 8. INSTRUMENT APPROACH PROCEDURES DATA TRANSMITTAL SYSTEM SECTION 3. COMPLETION OF FAA FORMS 8260-3/5 814. NOTES. h. Equipment Requirement Notes. Determine the need for equipment notes after evaluating all SIAP segments, including missed approach. To avoid proliferation of equipment requirement notes, all IFR aircraft are assumed to have at least one VOR receiver. Therefore, the note "VOR required" is not appropriate. VOR, ILS, or other non-ADF approaches may require ADF for procedure entry or missed approach. Use standard Note: "ADF required." If radar vectoring is available, use standard Note: "ADF or radar required." You have just proven yourself wrong. The note that results from application of Paragraph 814 h. goes on the applicable 8260.3 or 8260.5 which is an amendment to FAR 97. |
![]() "Sam Spade" wrote in message news:sOxlg.179314$bm6.172001@fed1read04... You have just proven yourself wrong. The note that results from application of Paragraph 814 h. goes on the applicable 8260.3 or 8260.5 which is an amendment to FAR 97. You've just demonstrated your inability to use simple logic. |
"Sam Spade" wrote in message news:sOxlg.179314$bm6.172001@fed1read04... You have just proven yourself wrong. The note that results from application of Paragraph 814 h. goes on the applicable 8260.3 or 8260.5 which is an amendment to FAR 97. You've just demonstrated your inability to use simple logic. When you are out of ideas then, in your typical fine fashion, you resort to personal attacks. Shoot the messenger as you so love to do, Steve. That does not change the FACT that the note is an FAR. |
![]() "Sam Spade" wrote in message news:BNylg.179320$bm6.132661@fed1read04... When you are out of ideas then, in your typical fine fashion, you resort to personal attacks. I never resort to personal attacks. You truly have demonstrated your inability to use simple logic. Again. Shoot the messenger as you so love to do, Steve. You still don't get it. Your message is wrong. That does not change the FACT that the note is an FAR. Prove it. |
the SAC ILS or LOC RWY 2? When ADF is actually required on non-NDB approaches the note "ADF REQUIRED" adds nothing to the approach, it simply states a fact. When the note appears on an approach that can be flown without ADF it only creates confusion. .... in the same manner that pilots would deal with being given a clearance to fly an ILS when they did not have an ILS receiver aboard. I expect pilots to rely on the publication as accurately reflecting facts, and the presence of "ADF Required" (which as stated upthread was actually initiated by NOTAM) would be relied upon as reflecting the fact that ADF is required. I would not expect pilots to second-guess NOTAMS or approach procedures. If it says ADF required, then an ADF is required. So, if cleared for the approach, and no ADF is aboard, the word "unable" or some equivalent would be legally required. As you note, when the note is "in error", confusion results. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message y.net... ... in the same manner that pilots would deal with being given a clearance to fly an ILS when they did not have an ILS receiver aboard. I fail to see any similarity. An "ILS receiver" is clearly needed to fly an ILS approach. In what manner would you expect pilots to rely on the note "ADF REQUIRED" when they're flying an approach that does not require ADF? I expect pilots to rely on the publication as accurately reflecting facts, and the presence of "ADF Required" (which as stated upthread was actually initiated by NOTAM) would be relied upon as reflecting the fact that ADF is required. But we know that ADF is not required for this approach. In what manner would you expect pilots to rely on the note "ADF REQUIRED" when they know ADF is not required? I would not expect pilots to second-guess NOTAMS or approach procedures. If it says ADF required, then an ADF is required. What is the ADF required for on approaches where ADF is not required but carry the note "ADF REQUIRED"? So, if cleared for the approach, and no ADF is aboard, the word "unable" or some equivalent would be legally required. Is carrying an old, unserviceable ADF in the baggage compartment good enough? If not, why not? |
No, we do not know that. We know that the FAA, in its infinite wisdom, has stated a requirement for an ADF receiver to be on board. It has done so by NOTAM (according to a previous poster). It all boils down to whether or not a pilot is to rely on the publications of (or sanctioned by) the FAA for regulatory information. For all I know (no comments from the peanut gallery!) it may be typical for ATC to issue alternate missed approach instructions "proceed direct to the ABC More Music station and hold until you hear Jethro Tull", and the ADF prepares you for that. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message .net... No, we do not know that. Okay, all of us don't know that. But all of us that are knowledgeable on IFR procedures know it. We know that the FAA, in its infinite wisdom, has stated a requirement for an ADF receiver to be on board. It has done so by NOTAM (according to a previous poster). No, we only know that at least one not-too-sharp procedures specialist believes ADF is required for this approach. |
Help! - Wooden prop - any info? | G0MRL | Aviation Marketplace | 1 | February 13th 06 03:14 PM |
Seeking Northrop Gamma info | Dillon | Restoration | 3 | December 12th 05 04:45 AM |
Helicopter Physics info online anywhere?? | [email protected] | Rotorcraft | 4 | April 24th 04 04:18 PM |
POSA Carb Info and HAPI Engine Info | Bill | Home Built | 0 | March 8th 04 08:23 PM |
Starting new info site need info from the pros | MRQB | Piloting | 7 | January 5th 04 03:20 AM |
