Steven P. McNicoll wrote:
"Sam Spade" wrote in message news:0Nxlg.179313$bm6.96676@fed1read04... That is incorrect. As they can be nothing else, that is entirely correct. Why can they be "nothing else?" |
![]() "Sam Spade" wrote in message news:2Oylg.179321$bm6.81683@fed1read04... Why can they be "nothing else?" Because that's all they can be, that should be obvious even to you. When "ADF REQUIRED" appears on a non-NDB SIAP where ADF is actually required to fly the approach it does nothing to alter the approach in any way. It's only function is to alert those pilots who don't do an adequate job of preparing for the approach. Those pilots who do prepare adequately will understand that ADF is required without the note. When it appears on an approach where ADF is not required, as in this case, it's meaningless and does nothing other than cause confusion in some pilots and indicate that the FAA is running short of competent procedures specialists to others. The note cannot create a regulatory requirement to use ADF where ADF is not operationally required. |
"Sam Spade" wrote in message news:2Oylg.179321$bm6.81683@fed1read04... Why can they be "nothing else?" Because that's all they can be, that should be obvious even to you. When "ADF REQUIRED" appears on a non-NDB SIAP where ADF is actually required to fly the approach it does nothing to alter the approach in any way. It's only function is to alert those pilots who don't do an adequate job of preparing for the approach. Those pilots who do prepare adequately will understand that ADF is required without the note. When it appears on an approach where ADF is not required, as in this case, it's meaningless and does nothing other than cause confusion in some pilots and indicate that the FAA is running short of competent procedures specialists to others. The note cannot create a regulatory requirement to use ADF where ADF is not operationally required. You should transfer to FAA legal. |
Help! - Wooden prop - any info? | G0MRL | Aviation Marketplace | 1 | February 13th 06 03:14 PM |
Seeking Northrop Gamma info | Dillon | Restoration | 3 | December 12th 05 04:45 AM |
Helicopter Physics info online anywhere?? | [email protected] | Rotorcraft | 4 | April 24th 04 04:18 PM |
POSA Carb Info and HAPI Engine Info | Bill | Home Built | 0 | March 8th 04 08:23 PM |
Starting new info site need info from the pros | MRQB | Piloting | 7 | January 5th 04 03:20 AM |
