On 9/7/04 1:21 PM, Frank Ch. Eigler wrote the following:
Mitty writes: [...] Doesn't seem like the MAP is that important. So what if you are a bit early or late when you decide you can't see where you're going? The result is the same, or should be. Depending on how big "a bit" is, being late to "go missed" can put one outside the airspace protected from obstructions. - FChE Point taken, but you can do rough math within "a bit" in your head I think. Particularly with a ground speed readout on the GPS. Or interpolate off the plate. |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
Approach Question- Published Missed Can't be flown? | Brad Z | Instrument Flight Rules | 8 | May 6th 04 04:19 AM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
