![]() "Doug Haluza" wrote in message oups.com... Try making a small right angle bend out of solid wire, and mount it up on the panel so it shows a 45 degree angle like a letter-v (you may have seen something similar on an aerobatic airplane). Use it as a reference with the horizon to see if you really are banking at 45 degrees in a tight thermal. You may be surprised to learn that what you thought was 45 degrees was only 30 or so. It's a very common problem. In a glider with a reasonably supine seating position I use the instrument mounting screws as a 45 degree reference. It's not so easy to do in a glider where you're sitting up more because the instruments aren't so near the horizon. Stephen |
Theories of lift | Avril Poisson | General Aviation | 3 | April 28th 06 07:20 AM |
Lift Query | Avril Poisson | General Aviation | 8 | April 21st 05 07:50 PM |
Tamed by the Tailwheel | [email protected] | Piloting | 84 | January 18th 05 04:08 PM |
New theory of flight released Sept 2004 | Mark Oliver | Piloting | 70 | October 10th 04 10:50 PM |
thermal lift | ekantian | Soaring | 0 | October 5th 04 02:55 PM |
