I BOILED some samples for 24 hours with no degradation other than a bit
of color change. Add light fiberglass over that... Did you compare bending strength before and after? What is the glass transition temperature for WEST system epoxy? Well, actually I made up a long sample with 2 1" wide strips glued (with fillet) together at a 90 degree angle. Then I cut this into samples, each about 1" long. Then I took these little "T" shaped samples, and subjected them to all sorts of things. They were made of Finnish Birch 3 ply (3mm thick, but quite dense.) It looked like it had penetrated to me - and they sure stayed together fine. I boiled several of them, and broke them afterward. The wood gave before the glue in all cases. I've also tried this with 1/8" Okume. Same result, but that stuff is porous enough that I'm pretty sure it soaks all the way through. I've been meaning to try it with that unfinished mahogany indoor plywood. If that "soaks all the way through" stuff works, it would be usable as a core, so I could use much cheaper material (for boats at least). As for the glass transition temperature, I think most epoxies are in the 140F range. After they cool they will return to much the same condition they were before though. The extra cure may even be beneficial. That's just a dull memory though. Correct me if I need it, but the boiled samples really did stand up fine (I'm looking at one now). |
Fabric repair | D.A.L | Home Built | 0 | April 27th 04 07:17 PM |
Replace fabric with glass | Ernest Christley | Home Built | 38 | April 17th 04 11:37 AM |
Fabric Work | Doug | Home Built | 9 | January 26th 04 03:31 AM |
Need to learn dope and fabric work | David Hill | Restoration | 5 | October 9th 03 01:52 AM |
Fiberglass Tip Tanks Question | Jay Honeck | Owning | 7 | September 26th 03 04:23 AM |
