Opinions on fleet replacement strategies.
Old June 23rd 06, 11:01 AM posted to rec.aviation.soaring
Default Opinions on fleet replacement strategies.
In article 4493fbb5.0@entanet, Martin Gregorie
writes
Bruce Greef wrote:
Whether the K21 is the best option - again too heavy, and too expensive.
If the K21 is too heavy, maybe you should consider throwing a bit of
money at the winch too - and/or consider a Puchacz. Its a lightly loaded
glider and relatively cheap to boot. I've been flying one a lot recently
and had forgotten how nice it is to fly and how good its air brakes are.
Its only real drawback is a rather narrow winching window - Vmw is 59 kts.
Winching: our Supacat has only a 240 hp Deutz diesel, but I've seen it
winch launch an ASH-25 several times.
I'm told that Poo-Cats have rather unfortunate spinning
characteristics, that is they go into a spin rather easily, and if you
get it wrong, can also go into an inverted spin.
While a K21 without mods, will hardy spin at all.
I suppose it depends on your philosophy, if you think pilots
should learn how to spin, how to avoid spinning when they don't mean to,
then the Poo-cats it is. But if you think that your club is better
served by avoiding the possibility of a spin, perhaps the K21 is a wiser
choice.
Mike Lindsay
Old June 24th 06, 12:43 PM posted to rec.aviation.soaring
A PW-6 may be what you need -- performance of a K21, price of a Puch, and it
spins if you want it to.
"Mike Lindsay" wrote in message
writes
Old June 24th 06, 04:28 PM posted to rec.aviation.soaring
Bruce Greef wrote:
Any thoughts on what we should do here? Other than start saving...
Your subject talks about fleet replacement strategies. You admit your
club has not been saving. The only sensible strategy is to set aside
funds based on your usage of your existing equipment. Consider
starting when putting a glider into service, though it's never too late
to start. What is the anticipated service life? An L-23 is about 6000
hours to the first overhaul. So divide the existing service life by
the number of hours remaining and bank at a rate to cover that cost.
Do the same for each glider in the club fleet. Some may be based on
restoration costs as they may not have a fixed service limit. Find a
useful estimate. Whether this comes from monthly dues or flying fees
is moot, but you must use a realistic cost basis. That's just one
factor in the real cost of soaring and must be considered when you are
setting your rates. You don't necessarily have to set the rates based
on what you want to acquire, but on your sunk costs. The rate will
increase when you replace or upgrade as you adjust the dues or fees
accordingly.
As the funds accumulate, you can decide to draw on these funds for
fleet replacement or expansion. Some clubs avoid growth and promotion
due to lack of available seats. However, if you are setting aside the
funds, upgrading and expansion are not so onerous. If you currently
have three gliders, you may find that you can add another glider
without asking for funds within 2-3 years. Adding the glider will
allow and keep more (satisfied) members and increase the rate at which
the fund builds.
Keep a couple of things in mind. A club is not a business. Yes, you
must have fiduciary responsbility, but your aims are not the same as a
business. If you adopt a realistic strategic economic plan, you can
avoid going to the bank. Financial interest is an expense of doing
business. But a club is not a business, is generally devoid of
business taxation, and has no tax leverage from expensing interest. In
economic terms, financial interest is a loss of future earnings. Keep
that in mind while doing some strategic planning. Your club is much
better off over the long run to set aside funds up front, than paying
interest on any notes later.
If you can replace or upgrade in advance of selling, you will also
leverage your purchase and sale prices. If you are under pressure, it
will cost you every time.
Frank Whiteley
Old June 25th 06, 05:37 PM posted to rec.aviation.soaring
writes
Hi Charles
PW6 is top of my list. The club management needs convincing...
Bruce
Old June 26th 06, 08:30 PM posted to rec.aviation.soaring
writes
Hi Charles
Bruce
Great ground handling also. Even better is XC training potential due
to ease of rigging and derigging. Be sure to get one with a trailer.
Frank Whiteley
is the US sailplane fleet shrinking? [email protected] Soaring 8 May 9th 06 07:23 PM
Fleet Air Arm Carriers and Squadrons in the Korean War Mike Naval Aviation 0 October 5th 04 02:58 AM
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Soviet Submarines Losses - WWII Mike Yared Military Aviation 4 October 30th 03 03:09 AM
TKM MX-11 Com true slide replacement ? Rohit Fedane Owning 0 September 21st 03 05:02 PM
