"Jim Macklin" wrote in message
news:q2Ymg.49475$ZW3.39824@dukeread04... Did I ever say that I had taught any particular theory to any student? Nope. You said that you're a CFI and that you believe stalls work in a particular way. Most CFIs teach what they believe to be true about fundamental aviation matters. Do you do otherwise? --Gary |
Gary Drescher wrote: "Jim Macklin" wrote in message news:q2Ymg.49475$ZW3.39824@dukeread04... Did I ever say that I had taught any particular theory to any student? Nope. You said that you're a CFI and that you believe stalls work in a particular way. Most CFIs teach what they believe to be true about fundamental aviation matters. Do you do otherwise? I predict what I'm about to write will be unpopular, but what the heck. I certainly agree that any CFI should have a good (and correct) understanding of the aerodynamics of stalls. That being said, all your typical pilot really has to know is: 1) Stalls happen when the wing exceeds the critial AOA. 2) This can happen at any airspeed and attitude, but for most people who fly near 1G almost all the time, "don't get too slow and don't point the nose up too high" is a pretty good rule of thumb. 3) You can recognize a stall by mushy controls, stall warner going off, buffet, and/or inability to maintain altitude. 4) You break the stall by reducing the AOA. Again, for most people who live near 1G and the dirty side down almost all the time, that means "push the yoke forward". If a student believes the tailplane stalls at the stall break, and that's what causes the nose to pitch down, it's not going to kill them. It's wrong, but it's an esoteric wrong and people don't get killed by esoteric wrongs. Not being able to figure out if you have enough fuel to get where you're going will kill you. Not knowing how to obtain and understand accurate weather information will kill you. Not understanding that stomping on the inside rudder to fix a misjudged base-to-final turn can cause a stall/spin will kill you. Not understanding the subtle details of the aerodynamics of a stall such as we've been discussing here may get you a lower score on a written test, or even make you flunk a CFI oral exam, or get roasted on usenet, but it won't kill you, and it won't kill your students either. OK, you all can beat me up now. Anyway, everybody really knows that stall recovery works like this: 1) Stall warning buzzer goes off. 2) Pilot instinctively puts his hands to his ears to block out the annoying noise. 3) As soon as his hands are removed from the yoke, the plane recovers on its own. |
"Roy Smith" wrote in message
... In article , If a student believes the tailplane stalls at the stall break, and that's what causes the nose to pitch down, it's not going to kill them. It's wrong, but it's an esoteric wrong and people don't get killed by esoteric wrongs. Roy, I agree with your general point. Much of the detail about how lift and stalls work is of interest to engineers and physicists, but not to pilots as such. And I agree that it's useful to present student pilots with as simple a model as possible that supports the right conclusions about how to fly. (Students who happen to be curious can learn more complex, more accurate models.) Still, I think it's useful to include a bit more information than the points you enumerated. In particular, some reference to the Bernoulli aspect of lift, and the separation of the boundary layer during a stall, helps make clear why the condition of the upper wing surface is important (and why a thin layer of frost on the upper surface can make it dangerous to take off, for example). Similarly, Jim's false model of stalls has some ramifications that are of interest to pilots. In particular, if Jim's model were correct, then pilots would have no reason to consider tail stalls more worrisome than normal stalls (because normal stalls would *be* tail stalls). But Jim's model is wrong, and a student who took it seriously could get into trouble. That probably wouldn't happen (because a student who could figure out that ramification could probably also figure out what's wrong with Jim's explanation), but it's still an unnecessary risk. --Gary |
Roy Smith wrote:
In article , Gary Drescher wrote: "Jim Macklin" wrote in message news:q2Ymg.49475$ZW3.39824@dukeread04... Did I ever say that I had taught any particular theory to any student? Nope. You said that you're a CFI and that you believe stalls work in a particular way. Most CFIs teach what they believe to be true about fundamental aviation matters. Do you do otherwise? I predict what I'm about to write will be unpopular, but what the heck. I certainly agree that any CFI should have a good (and correct) understanding of the aerodynamics of stalls. That being said, all your typical pilot really has to know is: Roy, the topic of discussion has nothing to do with it. It is the attitude that accepts being wrong and teaching wrong as not being wrong that is wrong! :-) Matt |
I have found that when I give a perfectly correct and
complete answer, there is nothing left to say and the thread dries up. I just tried and succeeded in stimulating the conversation. BTW, does anybody know how to explain the left hand rule for electricity or is it the right hand rule? -- James H. Macklin ATP,CFI,A&P "Matt Whiting" wrote in message ... | Roy Smith wrote: | | In article , | Gary Drescher wrote: | | "Jim Macklin" wrote in message | news:q2Ymg.49475$ZW3.39824@dukeread04... | | Did I ever say that I had taught any particular theory to | any student? | | Nope. You said that you're a CFI and that you believe stalls work in a | particular way. Most CFIs teach what they believe to be true about | fundamental aviation matters. Do you do otherwise? | | | I predict what I'm about to write will be unpopular, but what the heck. | | I certainly agree that any CFI should have a good (and correct) | understanding of the aerodynamics of stalls. That being said, all | your typical pilot really has to know is: | | Roy, the topic of discussion has nothing to do with it. It is the | attitude that accepts being wrong and teaching wrong as not being wrong | that is wrong! | :-) | | Matt |
Jim Macklin wrote:
I have found that when I give a perfectly correct and complete answer, there is nothing left to say and the thread dries up. I just tried and succeeded in stimulating the conversation. BTW, does anybody know how to explain the left hand rule for electricity or is it the right hand rule? Jim, your doctor prescribed those meds for a reason. Don't stop taking them again. Matt |
Actually, I found a bottle of antibiotic and it has cleared
up my sinuses. But other than that, I'm drug free. Forty years ago, when I cut my leg in the horse barn, I did use some of the horse medicine rather than go to a people doctor to get a shot. I just gave myself a few ccs of Combiotic (a mixture of two kinds of antibiotic also approved for people as well as cats, dogs and horses). I have also done a little surgery to remove things like nails in my arms, hands and legs, farm work can be dangerous. But all my original parts are still attached and fully functional, so I must have done it well enough. You'd probably criticize Wolfgang Langewiesche for calling elevators "flippers" or wonder like me, whether General McCauliffe really said "Nuts" or used some other common word(s). -- James H. Macklin ATP,CFI,A&P "Matt Whiting" wrote in message ... | Jim Macklin wrote: | | I have found that when I give a perfectly correct and | complete answer, there is nothing left to say and the thread | dries up. I just tried and succeeded in stimulating the | conversation. | | BTW, does anybody know how to explain the left hand rule for | electricity or is it the right hand rule? | | Jim, your doctor prescribed those meds for a reason. Don't stop taking | them again. | | Matt |
electricity or is it the right hand rule? Yes. I do. Electricity is made of two parts - electrons and French particles. They are clearly opposites. Electrons obey the lEft hand rule. That's because they are liberals - (liberal begins with an L). They are lightweights compared to other elementary particles (lightweight begins with an L) and pretty much go wherever you push them. Protons on the other hand need a lot more push, and neutrons don't give a damn - they go where they will. The French do everything differently - they even have a different name for current - they call it something like "Intensity". Alas, this abberation survives in the equation V=IR, where I means "current" (or "amount of French particles") French particles, being nationalistic, follow the rIght hand rule. Many people call them Revolutionary particles (revolutionary begins with R), ostensibly because of the French Revolution. Actually, this makes a little sense, since in a simple closed electrical circut the Rrench particles are in fact revolving (around the circuit). But then so do the electrons, but they go the other way. This causes quite a commotion, having the French particles going opposite the Electrons, and they do not get along with each other. They give each other the finger as they go by, and you can tell which is which by the kind of finger it gives you. French particles, or "revolutionary particles", use their rIght hand and give a very Intense finger - they stick out their thumb and let their fingers curl showing their contempt of the whole situation. Since the French (at least French women) have a very magnetic personality, this creates a magnetic field which follows the way the other fingers curl around the rIght hand. Elecrons use their lEft hand, Liberating their thumb and whipping their other fingers around like a fist. Since Liberals advocate free Lunches, people are attracted to them, following where their fingers point. Since it's the LEft hand, this goes opposite from the way the French (or Revolutionary) particles point. Fortunately, the kind of people that follow the French are different from the kind of people that follow the Liberals, and it all works out. Only people get confused - the particles all know where to go. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
On Sat, 24 Jun 2006 03:59:00 GMT, Jose
wrote: BTW, does anybody know how to explain the left hand rule for electricity or is it the right hand rule? Yes. I do. Electricity is made of two parts - electrons and French particles. They are clearly opposites. Electrons obey the lEft hand rule. That's because they are liberals - (liberal begins with an L). They are lightweights compared to other elementary particles (lightweight begins with an L) and pretty much go wherever you push them. Protons on the other hand need a lot more push, and neutrons don't give a damn - they go where they will. The French do everything differently - they even have a different name for current - they call it something like "Intensity". Alas, this abberation survives in the equation V=IR, where I means "current" (or "amount of French particles") French particles, being nationalistic, follow the rIght hand rule. Many people call them Revolutionary particles (revolutionary begins with R), ostensibly because of the French Revolution. Actually, this makes a little sense, since in a simple closed electrical circut the Rrench particles are in fact revolving (around the circuit). But then so do the electrons, but they go the other way. This causes quite a commotion, having the French particles going opposite the Electrons, and they do not get along with each other. They give each other the finger as they go by, and you can tell which is which by the kind of finger it gives you. French particles, or "revolutionary particles", use their rIght hand and give a very Intense finger - they stick out their thumb and let their fingers curl showing their contempt of the whole situation. Since the French (at least French women) have a very magnetic personality, this creates a magnetic field which follows the way the other fingers curl around the rIght hand. Elecrons use their lEft hand, Liberating their thumb and whipping their other fingers around like a fist. Since Liberals advocate free Lunches, people are attracted to them, following where their fingers point. Since it's the LEft hand, this goes opposite from the way the French (or Revolutionary) particles point. Fortunately, the kind of people that follow the French are different from the kind of people that follow the Liberals, and it all works out. Only people get confused - the particles all know where to go. Somehow this can be extended to explain conventional current, I'm sure. And eagerly waiting. Don |
It is actually all magic. The Earth rotates at 1,000 mph at
the equator and the core is a little slower and at the same time the Earth is in orbit around the Sun. It is producing eclectic currents in the core and crust and trying to balance these with electrical discharges for the entertainment of the gods. This is generated as an AC current on a very slow cycle, which causes the Earth's magnetic field to change over a periods of hundreds of years. There is an exchange of French particles and electrons between the Sun and the planets. The Sun is our local power source but like all circuits is effected by the other objects in the system. The Sun can increase the output of energy and this will effect all the planets. For instance, the Earth and other planets are a little warmer and our Rovers on Mars have been getting more solar power than was expected so they have continued to operate past their designed life expectancy. As long as the proper bribes are paid to the engineers, chemists and IBEW the magic will continue to work. NASA has experimented with collecting free electricity in space by dragging a long wire in the Earth's magnetic field, but their fishing reel jammed and the wire over-heated and broke. Someday they will make a real long extension cord and send the power from orbit to Las Vegas so the lights can burn as long as the Earth turns. If you look in the building codes, the left hand rule is that the light switch is to be located on the left hand when the door hinges are on the right as you leave the room and the reverse if the door is swung from the other side. No really, the left and right hand rules tell you how to use a compass to determine positive and negative leads in a DC circuit without a standard meter. Is it true that if an electrician is well grounded in his trade, he won't last long, but if he is insolated from the reality of electricity he can last nearly forever? I plan on becoming serious sometime in July when I win the lottery. "Don Tuite" wrote in message ... | On Sat, 24 Jun 2006 03:59:00 GMT, Jose | wrote: | | BTW, does anybody know how to explain the left hand rule for | electricity or is it the right hand rule? | | Yes. I do. | | Electricity is made of two parts - electrons and French particles. They | are clearly opposites. | | Electrons obey the lEft hand rule. That's because they are liberals - | (liberal begins with an L). They are lightweights compared to other | elementary particles (lightweight begins with an L) and pretty much go | wherever you push them. Protons on the other hand need a lot more push, | and neutrons don't give a damn - they go where they will. | | The French do everything differently - they even have a different name | for current - they call it something like "Intensity". Alas, this | abberation survives in the equation V=IR, where I means "current" (or | "amount of French particles") French particles, being nationalistic, | follow the rIght hand rule. | | Many people call them Revolutionary particles (revolutionary begins with | R), ostensibly because of the French Revolution. Actually, this makes a | little sense, since in a simple closed electrical circut the Rrench | particles are in fact revolving (around the circuit). But then so do | the electrons, but they go the other way. | | This causes quite a commotion, having the French particles going | opposite the Electrons, and they do not get along with each other. They | give each other the finger as they go by, and you can tell which is | which by the kind of finger it gives you. | | French particles, or "revolutionary particles", use their rIght hand and | give a very Intense finger - they stick out their thumb and let their | fingers curl showing their contempt of the whole situation. Since the | French (at least French women) have a very magnetic personality, this | creates a magnetic field which follows the way the other fingers curl | around the rIght hand. | | Elecrons use their lEft hand, Liberating their thumb and whipping their | other fingers around like a fist. Since Liberals advocate free Lunches, | people are attracted to them, following where their fingers point. | Since it's the LEft hand, this goes opposite from the way the French (or | Revolutionary) particles point. Fortunately, the kind of people that | follow the French are different from the kind of people that follow the | Liberals, and it all works out. Only people get confused - the | particles all know where to go. | | Somehow this can be extended to explain conventional current, I'm | sure. | | And eagerly waiting. | | Don | |
Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 05:23 PM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
military men "dumb, stupid animals to be used" Kissinger | B2431 | Military Aviation | 3 | April 26th 04 05:46 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
