The props on the King Air will reverse in-flight as can the
Pilatus bushplane. There can be some interesting aerodynamic effects. But very few recreational airplanes have any sort of reverse. But I agree, jets require the squat switch (unless there is a malfunction) to deploy reverse. -- James H. Macklin ATP,CFI,A&P wrote in message ... | On 24 Jun 2006 03:48:13 -0700, wrote: | | If you float in above the threshold a fair bit higher than Vref, is it | acceptable technique to chance the reverser to preclude landing too far | down the runway? | | I've only allegedly worked on couple of different types of buckets, | all on biz-jets and they have had one thing in common. | | The aircraft must have a weight-on-wheels signal present somewhere in | the logic circuit before the reversers will unlock or deploy. | | Inflight, if a not-locked condition is detected, the reversers are | hydraulically driven to the stowed position and pressure is maintained | holding them there until the not-locked condition goes away. | | Unless you are learning to fly the space shuttle: | | http://www.nasa.gov/vision/space/pre...week5_sta.html | | http://www.nasaexplores.com/show2_ar....php?id=04-067 | | http://www.aopa.org/pilot/features/9703feat.html | | having the buckets out while flying is a RBT (really bad thing), but | I'm sure there are some exceptions out there. | | http://www.globalsecurity.org/milita...craft/c-17.htm | | TC |
![]() Jim Macklin wrote: But I agree, jets require the squat switch (unless there is a malfunction) to deploy reverse. I read recently the C-5 that crashed at Dover, DE had a #2 engine reverser unstow right after takeoff. The crew attempted the approach with full flaps instead of partial flaps per the POH and the sink rate was too high to overcome. |
Kingfish wrote:
Jim Macklin wrote: But I agree, jets require the squat switch (unless there is a malfunction) to deploy reverse. I read recently the C-5 that crashed at Dover, DE had a #2 engine reverser unstow right after takeoff. The crew attempted the approach with full flaps instead of partial flaps per the POH and the sink rate was too high to overcome. It was an "unlock" indication which is one step before an "unstow". They shut down the engine in question to prevent an aysmetric deployment.. I THINK i saw that they had pulled the opposite side engine (#3) back to idle for some reason (directional control presumably... but I would have thought the rudder would have enough authority for that..).. I heard the full flap thing too.. but my version has them retracting from full to some partial setting, and that the airplane was flying below the stall speed for that weight and flap setting, and then simple physics took over. Dave |
![]() "Dave S" wrote in message ink.net... Kingfish wrote: Jim Macklin wrote: But I agree, jets require the squat switch (unless there is a malfunction) to deploy reverse. I read recently the C-5 that crashed at Dover, DE had a #2 engine reverser unstow right after takeoff. The crew attempted the approach with full flaps instead of partial flaps per the POH and the sink rate was too high to overcome. It was an "unlock" indication which is one step before an "unstow". They shut down the engine in question to prevent an aysmetric deployment.. I THINK i saw that they had pulled the opposite side engine (#3) back to idle for some reason (directional control presumably... but I would have thought the rudder would have enough authority for that..).. I heard the full flap thing too.. but my version has them retracting from full to some partial setting, and that the airplane was flying below the stall speed for that weight and flap setting, and then simple physics took over. Dave The report also said that after securing the #2, they continued to operate the #2 thrust lever instead of the #3 which was still operating. Dead foot, Dead engine. Al G. |
![]() wrote in message ... On 24 Jun 2006 03:48:13 -0700, wrote: having the buckets out while flying is a RBT (really bad thing), but I'm sure there are some exceptions out there. http://www.globalsecurity.org/milita...craft/c-17.htm TC Yup, you found it. The C-17 thrust reversers are certified as flight controls. |
Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 09:32 PM |
Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 03:07 PM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Partnership Question | Harry Gordon | Owning | 4 | August 16th 03 11:23 PM |
