Try this. I bought one last year from this guy. Works great.
http://cgi.ebay.com/Brand-New-12V-Br...QQcmdZViewItem ..Blueskies. wrote: "john smith" wrote in message ... In article , John T wrote: This has been a recurring topic with no clear answers. I say, hoof it over to the hilton. They have wireless for their guests. There is no sign on page, but I have no idea what their range is. And someone will be sitting there with their laptop watching everything streaming by in the ether. Google "ethereal" for more information. :-)) Beware of ARP cache poisoning, also. Never use any program which transmits any of your passwords over an open wireless network. What about power for the laptop while camping by the plane. I don't think using an inverter through the aircraft battery would be a good idea ;-) |
I could see were this would come in very handy.
Lou |
Newps wrote:
Try this. I bought one last year from this guy. Works great. http://cgi.ebay.com/Brand-New-12V-Br...QQcmdZViewItem Can you just hook this up directly to maybe a sealed lead acid battery or a gel cell and charge it? I've never been clear on whether or not electronic circuits are used to prevent overcharging or whether one of these puts out enough juice to be concerned. Tom |
Most small solar panels have low amperage and will not over
charge a wet cell battery. If they were used to directly charge a dry cell battery, such as a C or D cell they might over charge, but a wet cell battery with an AHr rating of 25 amps can be charged indefinitely at a rate of 2-3 amps and you will be using the battery to run an inverter to power various other loads. "Tom McQuinn" wrote in message ... | Newps wrote: | Try this. I bought one last year from this guy. Works great. | | | http://cgi.ebay.com/Brand-New-12V-Br...QQcmdZViewItem | | | | | Can you just hook this up directly to maybe a sealed lead acid battery | or a gel cell and charge it? I've never been clear on whether or not | electronic circuits are used to prevent overcharging or whether one of | these puts out enough juice to be concerned. | | Tom |
On Sun, 25 Jun 2006 09:51:51 -0500, "Jim Macklin"
wrote in JTxng.49575$ZW3.40014@dukeread04:: Most small solar panels have low amperage and will not over charge a wet cell battery. The solar panel mentioned has a 13 watt rating. That's a little over 1 amp at 12 volts (in full sun). |
I looked up the item after I sent it out, the specs say 750
milliwatt and 14 volts. It is a good trickle charger, as long as you don't put too much load on the battery. It should do fine for charging cellphones, cameras, and even the laptop. But if they are all on the inverter at one time, the battery will be discharged. "Larry Dighera" wrote in message ... | On Sun, 25 Jun 2006 09:51:51 -0500, "Jim Macklin" | wrote in | JTxng.49575$ZW3.40014@dukeread04:: | | Most small solar panels have low amperage and will not over | charge a wet cell battery. | | The solar panel mentioned has a 13 watt rating. That's a little over | 1 amp at 12 volts (in full sun). | |
meant to say 750 milliamps (3/4 of an amp).
"Jim Macklin" wrote in message news:h9Cng.49592$ZW3.38038@dukeread04... |I looked up the item after I sent it out, the specs say 750 | milliwatt and 14 volts. It is a good trickle charger, as | long as you don't put too much load on the battery. It | should do fine for charging cellphones, cameras, and even | the laptop. But if they are all on the inverter at one time, | the battery will be discharged. | | | | "Larry Dighera" wrote in message | ... || On Sun, 25 Jun 2006 09:51:51 -0500, "Jim Macklin" || wrote in || JTxng.49575$ZW3.40014@dukeread04:: || || Most small solar panels have low amperage and will not | over || charge a wet cell battery. || || The solar panel mentioned has a 13 watt rating. That's a | little over || 1 amp at 12 volts (in full sun). || | | |
![]() "Jim Macklin" wrote in message news:JTxng.49575$ZW3.40014@dukeread04... Most small solar panels have low amperage and will not over charge a wet cell battery. If they were used to directly charge a dry cell battery, such as a C or D cell they might over charge, but a wet cell battery with an AHr rating of 25 amps can be charged indefinitely at a rate of 2-3 amps and you will be using the battery to run an inverter to power various other loads. This may be true for a few days of operation at a campsite, but overcharging is overcharging, and it will eventually trash your battery. Take it from a guy who ruined far too many batteries with cheap one-amp trickle chargers before he learned. In general, solar panels need charge controllers for long-term successful operation. Vaughn |
Probably true, but this is a week long camping trip, with
the battery being used as the power source for an inverter to use the 110 VAC to charge the laptop. It would be best to get a cigarette lighter adapter for the cellphone and skip the step of the inverter. If you fly-in, just go to a nearby store and buy a cheap car battery and after the event, donate it to the shop for the airport beater or tractor. "Vaughn Simon" wrote in message ... | | "Jim Macklin" wrote in message | news:JTxng.49575$ZW3.40014@dukeread04... | Most small solar panels have low amperage and will not over | charge a wet cell battery. If they were used to directly | charge a dry cell battery, such as a C or D cell they might | over charge, but a wet cell battery with an AHr rating of 25 | amps can be charged indefinitely at a rate of 2-3 amps and | you will be using the battery to run an inverter to power | various other loads. | | This may be true for a few days of operation at a campsite, but overcharging | is overcharging, and it will eventually trash your battery. Take it from a guy | who ruined far too many batteries with cheap one-amp trickle chargers before he | learned. In general, solar panels need charge controllers for long-term | successful operation. | | Vaughn | | |
Jim Macklin wrote:
Most small solar panels have low amperage and will not over charge a wet cell battery. If they were used to directly charge a dry cell battery, such as a C or D cell they might over charge, but a wet cell battery with an AHr rating of 25 amps can be charged indefinitely at a rate of 2-3 amps and you will be using the battery to run an inverter to power various other loads. Your understanding of electricity is only exceeded by your understanding of stall dynamics. It would take in increasing voltage to maintain 2 amps into a wet cell battery as it becomes charged. If you maintain that rate for more than 12-13 hours, you will soon ruin the battery. The good news is that most chargers (and certainly a PV cell) maintain a roughly constant voltage so that the amperage tapers off as the battery approaches full charge. Matt |
Wireless head mounted microphones | Eric Greenwell | Soaring | 5 | December 8th 05 03:33 PM |
WingX Browser: Free Weather on your Pocket PC - no wireless connection required! | Hilton | Piloting | 9 | October 31st 05 01:56 PM |
WingX Browser: Free Weather on your Pocket PC - no wireless connection required! | Hilton | Instrument Flight Rules | 6 | October 14th 05 07:12 AM |
Weather for wireless PDA | Viperdoc | Instrument Flight Rules | 7 | September 24th 03 01:02 AM |
Wireless internet in North 40? | Martin Hotze | Piloting | 3 | July 28th 03 02:19 PM |
