![]() "flybynightkarmarepair" wrote in message oups.com... pTooner wrote: Firstly, I am new here although I've been reading for a few days. For anyone with more knowledge than I, I keep considering building a small 4 wing aircraft. Not stacked, but two up front and two in the rear. I have read frequently of problems supposedly resulting from interference of the airflow between wings, but I can't seem to find anything very specific. I'm fairly confident that interference between the front wings (or rear) can be minimized by reasonable spacing and differing dihedral. I'm not sure what the effect of the airflow coming off the front wings will have on the rear set. I don't know whether I could remove most of the problem by having one set considerably higher (how much?) than the other set or if it is reasonable to have them on more or less the same height. The reason for the concept is trying to get a wingspan small enough to fit into a normal garage and conceivably take off and land from streets and highways. I visualise something in a two place plane that would fall into something of the appeal category of a motorcycle or small sports car. Any thoughts would be appreciated. Gerry John Roncz called a 3 surface airplane he participated in the design of "the aerodynamicists full employment act"! You will, with optimization of all the variables. be lucky to get 40% of the lift/drag ratio of an equivalent conventional planform. Can you elaborate? I don't see why this should be true. But the bigger problem will be control. Pitch stability, in and out of ground effect, will be a formidable problem, as will stall characteristics. Compromises needed to make the handling acceptable may make the efficiency even worse. Well, most tandem wing aircraft are designed to make normal stall impossible. (the rutan designs for instance) Pitch stability is a problem that I thought had been pretty well handled by airfoil design in canard aircraft years ago. My thoughts (I wouldn't call it a design) are simply two sets of biplane wings mounted fore and aft. Biplane wings don't normally present much of an efficiency problem except for the bracing which isn't stricly necessary (The hyperbipe was a pretty efficent design) I certainly agree that handling especially in the pitch axis is the major challenge, but I don't see why it should present a much bigger problem than the flying flea family of aircraft where it was eventually solved satisfactorily. I agree with Ernst - a low aspect ratio delta/lifting body makes more sense. Perhaps a 2 seat Facetmobile with the outer portions folding inward like a Dyke Delta. Perhaps, but it's been tried many times and with very limited success. I know of NO attempt to build the 4 wing system that I envision. That seems strange when you consider that about every imaginable combination has been tried at one time or another. Didn't someone finally build an operable ornithopter? But have you looked at all the wires around most roads? Not an area I would want to use for landing and takeoff. Good point, but they aren't everywhere. ;-) Gerry |
![]() pTooner wrote: ... Well, most tandem wing aircraft are designed to make normal stall impossible. (the rutan designs for instance) Pitch stability is a problem that I thought had been pretty well handled by airfoil design in canard aircraft years ago. My thoughts (I wouldn't call it a design) are simply two sets of biplane wings mounted fore and aft. Biplane wings don't normally present much of an efficiency problem except for the bracing which isn't stricly necessary (The hyperbipe was a pretty efficent design) I certainly agree that handling especially in the pitch axis is the major challenge, but I don't see why it should present a much bigger problem than the flying flea family of aircraft where it was eventually solved satisfactorily. This sounds like sort of a biplane version of the dragonfly. ... Perhaps, but it's been tried many times and with very limited success. I know of NO attempt to build the 4 wing system that I envision. That seems strange when you consider that about every imaginable combination has been tried at one time or another. Everytime I've had an idea for some way to build an airplane that I had never seen before it took only a few minutes on the web to find examples of the concpet that had already been built and flown. So I daresay if you have a novel idea that has never been flown there is probably a very good reason why it hasn't. If you are merely interested in being able to get the plane easiliy into a garage, there are many folding wing designs to choose from or adapt. In addition to the Flying Flea, the kitfox is another. Regardless, good luck. Didn't someone finally build an operable ornithopter? There have been many small (e.g. bird-sized) ones flown. You can buy a plastic toy ornithopter for under $50.00 and there are plans available on the web to build a rubber-bad powered version. But have you looked at all the wires around most roads? Not an area I would want to use for landing and takeoff. Good point, but they aren't everywhere. ;-) You have legal restrictions to be concerned with on public roads, but there are private roads. |
![]() You will, with optimization of all the variables. be lucky to get 40% of the lift/drag ratio of an equivalent conventional planform. Can you elaborate? I don't see why this should be true. Well, let's see. The back wing(s) operate in the downwash of the forward wings, there's a hit there. The upper wings operate in a flow field affected by the lower wings, there's a hit there. Twice as many wingtip vortices, take a hit there, and at some angles of attack, the aft wing(s) will be operating in the vortice of the front wing(s). But the bigger problem will be control. Pitch stability, in and out of ground effect, will be a formidable problem, as will stall characteristics. Compromises needed to make the handling acceptable may make the efficiency even worse. Well, most tandem wing aircraft are designed to make normal stall impossible. (the rutan designs for instance) There is a price paid in efficiency, and in landing speed in making this NECESSARY trait possible. It's necessary because a canard or tandem wing design is very vulnerable to an un-recoverable deep stall. The consequence is that you cannot optimize the angle of attack for both wings simultaneously, and that the C ell Max of the combined system is degraded, making the landing speed higher, or the wings bigger (which will hurt efficiency AGAIN). Pitch stability is a problem that I thought had been pretty well handled by airfoil design in canard aircraft years ago. My thoughts (I wouldn't call it a design) are simply two sets of biplane wings mounted fore and aft. Biplane wings don't normally present much of an efficiency problem except for the bracing which isn't stricly necessary (The hyperbipe was a pretty efficent design) Pretty efficient for a biplane, but nowhere near as efficient as a conventional design. I certainly agree that handling especially in the pitch axis is the major challenge, but I don't see why it should present a much bigger problem than the flying flea family of aircraft where it was eventually solved satisfactorily. Again, by limitations that hurt efficiency. And a good half-dozen people died before the pitch stability issue was solved. That was actually a problem at cruise/top speed. The transition between operating in ground effect and out of it is pretty tricky for a equal area tandem wing airplane. This was seen in some of the first experimental Wing In Ground effect surface skimmers. They had tremendous pitch stability (a problem if you're trying to rotate) until they suddenly didn't, and they would pitch up quite violently. That's one reason the Quickies have ANHEDRAL on the forward wing, and Dihedral on the aft wing, as well as mounting the forward wing lower than the aft wing. In this way, with a pitch up to rotate, both wings come out of ground effect at much closer to the same instant, without a sharp pitch divergence. I agree with Ernst - a low aspect ratio delta/lifting body makes more sense. Perhaps a 2 seat Facetmobile with the outer portions folding inward like a Dyke Delta. Perhaps, but it's been tried many times and with very limited success. Various low aspect ratio designs have been flow since the twenties, it's true. The Burnellis, the Spratt, the Fike designs. The Dyke Delta is a low aspect double delta, with the main cabin airfoil shaped. But true lifting bodies were basically unknown until the 1960's. John McPhee wrote about one of them in "The Deltoid Pumpkin Seed". The the Facetmobile is, IMHO, the most successful general aviaition true lifting body design. |
![]() "flybynightkarmarepair" wrote in message oups.com... You will, with optimization of all the variables. be lucky to get 40% of the lift/drag ratio of an equivalent conventional planform. Can you elaborate? I don't see why this should be true. Well, let's see. The back wing(s) operate in the downwash of the forward wings, there's a hit there. That's not necessarily true, it depends on many additional factors. The same could be said for the main sail on a sloop operating in the downwash of the jib, but it works damned well. The upper wings operate in a flow field affected by the lower wings, there's a hit there. Seems I read somewhere that as long as the gap is about 1.5 times the chord that isn''t a factor? Twice as many wingtip vortices, take a hit there, Maybe - I'm not sure about that one. There are certainly other considerations. and at some angles of attack, the aft wing(s) will be operating in the vortice of the front wing(s). That strikes me as the single most important problem with this consideration. But the bigger problem will be control. Pitch stability, in and out of ground effect, will be a formidable problem, as will stall characteristics. See above. Compromises needed to make the handling acceptable may make the efficiency even worse. Please elaborate. Well, most tandem wing aircraft are designed to make normal stall impossible. (the rutan designs for instance) There is a price paid in efficiency, and in landing speed in making this NECESSARY trait possible. It's necessary because a canard or tandem wing design is very vulnerable to an un-recoverable deep stall. The consequence is that you cannot optimize the angle of attack for both wings simultaneously, and that the C ell Max of the combined system is degraded, making the landing speed higher, or the wings bigger (which will hurt efficiency AGAIN). Generally, I agree. OTOH, all designs are compromises of some kind. Pitch stability is a problem that I thought had been pretty well handled by airfoil design in canard aircraft years ago. My thoughts (I wouldn't call it a design) are simply two sets of biplane wings mounted fore and aft. Biplane wings don't normally present much of an efficiency problem except for the bracing which isn't stricly necessary (The hyperbipe was a pretty efficent design) Pretty efficient for a biplane, but nowhere near as efficient as a conventional design. The published specs don't seem to agree with you there. I certainly agree that handling especially in the pitch axis is the major challenge, but I don't see why it should present a much bigger problem than the flying flea family of aircraft where it was eventually solved satisfactorily. Again, by limitations that hurt efficiency. And a good half-dozen people died before the pitch stability issue was solved. That was actually a problem at cruise/top speed. Sad, but many people died to learn what we now know about aeronautics. The transition between operating in ground effect and out of it is pretty tricky for a equal area tandem wing airplane. This was seen in some of the first experimental Wing In Ground effect surface skimmers. They had tremendous pitch stability (a problem if you're trying to rotate) until they suddenly didn't, and they would pitch up quite violently. That's one reason the Quickies have ANHEDRAL on the forward wing, and Dihedral on the aft wing, as well as mounting the forward wing lower than the aft wing. In this way, with a pitch up to rotate, both wings come out of ground effect at much closer to the same instant, without a sharp pitch divergence. Interesting observation that I haven't come across previously. I agree with Ernst - a low aspect ratio delta/lifting body makes more sense. Perhaps a 2 seat Facetmobile with the outer portions folding inward like a Dyke Delta. Perhaps, but it's been tried many times and with very limited success. Various low aspect ratio designs have been flow since the twenties, it's true. The Burnellis, the Spratt, the Fike designs. The Dyke Delta is a low aspect double delta, with the main cabin airfoil shaped. But true lifting bodies were basically unknown until the 1960's. John McPhee wrote about one of them in "The Deltoid Pumpkin Seed". The the Facetmobile is, IMHO, the most successful general aviaition true lifting body design. I agree. \ |
flybynightkarmarepair wrote:
Various low aspect ratio designs have been flow since the twenties, it's true. The Burnellis, the Spratt, the Fike designs. The Dyke Delta is a low aspect double delta, with the main cabin airfoil shaped. But true lifting bodies were basically unknown until the 1960's. John McPhee wrote about one of them in "The Deltoid Pumpkin Seed". The the Facetmobile is, IMHO, the most successful general aviaition true lifting body design. I've heard this stated several times, and always found it a bit strange. What is it that makes the Facetmobile so successful? A single prototype that crashed, vs the Dyke Delta that has had dozens flying and about half a dozen currently airworthy. Why is the Dyke Delta not considered a lifting body design? The fuselage provides the majority of the lift at cruise, according to John Dyke and verified in XPlane (if that can be considered any sort of verification). -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Ernest Christley wrote:
flybynightkarmarepair wrote: Various low aspect ratio designs have been flow since the twenties, it's true. The Burnellis, the Spratt, the Fike designs. The Dyke Delta is a low aspect double delta, with the main cabin airfoil shaped. But true lifting bodies were basically unknown until the 1960's. John McPhee wrote about one of them in "The Deltoid Pumpkin Seed". The the Facetmobile is, IMHO, the most successful general aviaition true lifting body design. I've heard this stated several times, and always found it a bit strange. What is it that makes the Facetmobile so successful? A single prototype that crashed, vs the Dyke Delta that has had dozens flying and about half a dozen currently airworthy. Why is the Dyke Delta not considered a lifting body design? The fuselage provides the majority of the lift at cruise, according to John Dyke and verified in XPlane (if that can be considered any sort of verification). This is an admittedly arbitrary distinction. The cabin on a Dyke Delta is, again, IMHO, not well integrated into the fuselage/wing - MY definition of a lifting body is that it's ALL an integrated whole. Compare these pictures of a Dyke Delta: http://www.pivot.net/~psi/philt2.htm and the Facetmobile: http://members.aol.com/slicklynne/FMX4IF1.JPG The other piece of my arbitrary distinction is that the Dyke Delta has discernable wings, while the Facetmobile doesn't. I think the Dyke Delta is a great airplane; one I've loved since I read about it in Air Progress probably nearly 40 years ago. |
![]() "flybynightkarmarepair" wrote This is an admittedly arbitrary distinction. The cabin on a Dyke Delta is, again, IMHO, not well integrated into the fuselage/wing - MY definition of a lifting body is that it's ALL an integrated whole. So, in your opinion, the Hyper Bipe is not a lifting body? It provides substantial lift, therefore, it is a lifting body, in everyone's view, except yours. I submit that you are incorrect. -- Jim in NC |
Morgans wrote:
"flybynightkarmarepair" wrote This is an admittedly arbitrary distinction. The cabin on a Dyke Delta is, again, IMHO, not well integrated into the fuselage/wing - MY definition of a lifting body is that it's ALL an integrated whole. So, in your opinion, the Hyper Bipe is not a lifting body? It provides substantial lift, therefore, it is a lifting body, in everyone's view, except yours. I submit that you are incorrect. Well, so does the Tailwind. But the trick is, alla these have - well - wings! |
Thrusting or Sucking (where's Howard Stern when we need him.) | Ken Kochanski (KK) | Soaring | 37 | January 14th 06 09:51 AM |
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell | Otis Willie | Military Aviation | 0 | March 18th 04 08:40 PM |
Wing tip stalls | mat Redsell | Soaring | 5 | March 13th 04 05:07 PM |
Can someone explain wing loading? | Frederick Wilson | Home Built | 4 | September 10th 03 02:33 AM |
Wing Extensions | Jay | Home Built | 22 | July 27th 03 12:23 PM |
