Corrosion at Aluminum/Steel Junction
Old June 25th 06, 09:30 AM posted to rec.aviation.homebuilt
Default Corrosion at Aluminum/Steel Junction
I am now more or less "trespassing" here but I would like to give an
explanation to this question.
The very smooth metal surfaces (bars), aluminum and steel are placed one on
top of an other and the explosive charge is placed, I guess above the
aluminum bar? Does this process take place in some kind of a purpose built
explosion chamber or are the materials simply buried underground (the weight
of e.g. a thick layer of sand would give enough resistance) to be fused, who
knows?
The idea is, that the detonation creates shock waves so intense, that the
metal atoms of the contact surface (layer) area are a sort of mixed
(knocked) together, hence the term fused. The process is probably called as
explosion welding? The created bond is very strong and there is no room for
any moisture to get in. That is why the corrosion can't take place between
the dissimilar materials. At least I figure this to be the case. The Mark
Andrew Spence may give more accurate explanation.
JP
"Morgans" wrote in
"Mark Andrew Spence" wrote
The TICONDROGA and SPRUANCE class ships had aluminum superstructures
which were welded to a "fusion bar" which consisted of a piece of very
clean and smoothly-machined piece of aluminum FLAT BAR joined to a very
clean piece and smoothly machined piece of steel flat bar via explosive
charges.
What was the purpose of the explosive charges? (besides, to go "bang"
g)
Jim in NC
Pilatus B4 and corrosion Mika Koski Soaring 1 April 26th 06 09:50 PM
Corrosion Evaluation Help Dick Home Built 3 July 15th 05 02:51 AM
Surface Corrosion? Joaquin Murrieta Home Built 2 May 3rd 05 01:19 AM
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
How much corrosion is too much? Carl Orton Owning 5 February 2nd 04 01:31 AM
