Transponder Landing System ???
Old September 13th 04, 06:41 PM
John R. Copeland
"C Kingsbury" wrote in message =
om...
"Gerry Caron" wrote in message =
=20
It works by using a Mode A interrogator and multiple receivers around =
periphery of the airport. By measuring the time difference of =
arrival
(TDOA) of your transponder replies, it calculates your position =
relative to
the airport and the approach path. It then broadcasts thru an omni =
antenna
an "ILS" signal modulating the 90 and 150 Hz tones to drive your CDI =
to
indicate the proper guidance to the approach path.
=20
Fascinating the things people thought up back in the days before a
constellation of satellites could provide a 3D positional fix with an
accuracy measured in inches.
=20
With WAAS underway, it seems predictable that non-precision approaches
will be joining colored airways in the dustbin of history. If the FAA
had the resources and motivation it could probably be accomplished in
5 years, though I suppose 20 is more likely...
=20
-cwk.
Five years? Twenty years?
Probably about a year ago, the FAA mentioned the rate at which they were
converting (IIRC) GPS approaches to LNAV/VNAV approaches.
The number sounded fairly good, until doing the math showed it would =
take
them about thirty years to finish the current number of runways at that =
rate.
---JRC---
"bush flying" in the suburbs? [email protected] Home Built 85 December 28th 04 11:04 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Fixing the Transponder with Duct Tape and Aluminum Foil Ron Wanttaja Home Built 45 March 14th 04 12:18 AM
Off topic - Landing of a B-17 Ghost Home Built 2 October 28th 03 04:35 PM
2nd update on Review of Plasma II Ignition System MikeremlaP Home Built 8 July 22nd 03 01:37 AM
