![]() "john smith" wrote in message ... In article , "Al" wrote: It looks like I will have a mission to pick up a PA32-300 on Thurs. Can anyone point me to an online copy of the flight maual, or perhaps some of the pertinent information? I've got a couple of hours in a PA32-260 some years ago, and will have a copy of the manual available when I pick up the airplane, however I would like to prepare myself somewhat. Any warnings or items I should watch out for? What year? I have manuals for a 1972 and a 1978. There are differences depending on aircraft serial number. Does the one you will be flying have club seating or all forward facing? - Fuel management is the important thing. The outboards have 17 gal, the inboards/mains have 25. The tab on the inboards/mains may be at 15 gallons or 18 gallons, depending on the serial number. Know which one you have. You will need this information depending on the load you will be carrying. I think the -300 series with the straight wing has 84 gal (17-25-25-17) usable, the -301 series with the taper wing has 96 gal (48-48) usable. - Find out how accurate the fuel flow gauge is. You fly off the mains first, then the outboards. - The manual warns that it may take up to 12 seconds to get fuel flowing from a full tank to the engine if one tank is run dry. [It may give you a warning, listen for the engine surging! Ask me how I know! ;-) ] - Cruise at 16-18 gph, depending on what the owner wants. - Full throttle altitude will vary with OAT, between 6000-8000 feet MSL. - Know your speeds for the current weight you are flying. (Make a table using a spreadsheet or word processor.) - Use 10-deg flaps for all takeoffs to reduce takeoff run. - Fly the airplane using trim. - I prefer to fly high MP/low RPM at cruise, make sure you have a power chart handy. Remember, at or below you can fly LOP without harming the engine. Thanks John. No clue yet what year or config, I do know that the "Load" is 1 pax in addition to me. Al G. |
When I checked out in one years ago, with just the instructor and myself
onboard we had to load two cases of oil in the aft baggage compartment to stay in the envelope. With just you two onboard, for heavens sake don't load any baggage in the forward compartment. Stay near the center or aft half of the W/B envelope and you won't find a tendency to hug the ground or prang the nose wheel first. Properly loaded it flies off the ground much better than the Mack truck you expect it to be. The right rudder requirement is only a problem if you find yourself at full throttle and low ground speed (little rudder authority). Since the nose wheel is direct connected to the rudder pedals, a lot of pilots tend to shove the power in and then steer with the nose wheel. If you've got enough runway there's no need to cram it all in at the beginning of the roll. As with any large engined aircraft, slow and deliberate yields pleasant results. We used to haul passengers in both the 260 and 300 for a small real estate development outfit. The 300 is the right size plane with the right size engine. Plenty of power to haul what you can get in it -- something the 260 often came up short on. -----Original Message----- From: Al ] Posted At: Monday, June 26, 2006 16:47 Posted To: rec.aviation.owning Conversation: Cherokee 6 manual/info? Subject: Cherokee 6 manual/info? "john smith" wrote in message news:jsmith-A2C33B.14391126062006@network-065-024-007- 027.columbus.rr.com... In article , "Al" wrote: It looks like I will have a mission to pick up a PA32-300 on Thurs. Can anyone point me to an online copy of the flight maual, or perhaps some of the pertinent information? I've got a couple of hours in a PA32-260 some years ago, and will have a copy of the manual available when I pick up the airplane, however I would like to prepare myself somewhat. Any warnings or items I should watch out for? What year? I have manuals for a 1972 and a 1978. There are differences depending on aircraft serial number. Does the one you will be flying have club seating or all forward facing? - Fuel management is the important thing. The outboards have 17 gal, the inboards/mains have 25. The tab on the inboards/mains may be at 15 gallons or 18 gallons, depending on the serial number. Know which one you have. You will need this information depending on the load you will be carrying. I think the -300 series with the straight wing has 84 gal (17-25-25-17) usable, the -301 series with the taper wing has 96 gal (48-48) usable. - Find out how accurate the fuel flow gauge is. You fly off the mains first, then the outboards. - The manual warns that it may take up to 12 seconds to get fuel flowing from a full tank to the engine if one tank is run dry. [It may give you a warning, listen for the engine surging! Ask me how I know! ;-) ] - Cruise at 16-18 gph, depending on what the owner wants. - Full throttle altitude will vary with OAT, between 6000-8000 feet MSL. - Know your speeds for the current weight you are flying. (Make a table using a spreadsheet or word processor.) - Use 10-deg flaps for all takeoffs to reduce takeoff run. - Fly the airplane using trim. - I prefer to fly high MP/low RPM at cruise, make sure you have a power chart handy. Remember, at or below you can fly LOP without harming the engine. Thanks John. No clue yet what year or config, I do know that the "Load" is 1 pax in addition to me. Al G. |
The useful load on the -260 is greater than the -300.
"Jim Carter" wrote in message .net... We used to haul passengers in both the 260 and 300 for a small real estate development outfit. The 300 is the right size plane with the right size engine. Plenty of power to haul what you can get in it -- something the 260 often came up short on. -----Original Message----- From: Al ] Posted At: Monday, June 26, 2006 16:47 Posted To: rec.aviation.owning Conversation: Cherokee 6 manual/info? Subject: Cherokee 6 manual/info? "john smith" wrote in message news:jsmith-A2C33B.14391126062006@network-065-024-007- 027.columbus.rr.com... In article , "Al" wrote: It looks like I will have a mission to pick up a PA32-300 on Thurs. Can anyone point me to an online copy of the flight maual, or perhaps some of the pertinent information? I've got a couple of hours in a PA32-260 some years ago, and will have a copy of the manual available when I pick up the airplane, however I would like to prepare myself somewhat. Any warnings or items I should watch out for? What year? I have manuals for a 1972 and a 1978. There are differences depending on aircraft serial number. Does the one you will be flying have club seating or all forward facing? - Fuel management is the important thing. The outboards have 17 gal, the inboards/mains have 25. The tab on the inboards/mains may be at 15 gallons or 18 gallons, depending on the serial number. Know which one you have. You will need this information depending on the load you will be carrying. I think the -300 series with the straight wing has 84 gal (17-25-25-17) usable, the -301 series with the taper wing has 96 gal (48-48) usable. - Find out how accurate the fuel flow gauge is. You fly off the mains first, then the outboards. - The manual warns that it may take up to 12 seconds to get fuel flowing from a full tank to the engine if one tank is run dry. [It may give you a warning, listen for the engine surging! Ask me how I know! ;-) ] - Cruise at 16-18 gph, depending on what the owner wants. - Full throttle altitude will vary with OAT, between 6000-8000 feet MSL. - Know your speeds for the current weight you are flying. (Make a table using a spreadsheet or word processor.) - Use 10-deg flaps for all takeoffs to reduce takeoff run. - Fly the airplane using trim. - I prefer to fly high MP/low RPM at cruise, make sure you have a power chart handy. Remember, at or below you can fly LOP without harming the engine. Thanks John. No clue yet what year or config, I do know that the "Load" is 1 pax in addition to me. Al G. |
Steve,
For that to be true then the increase from engine weight and associated accessories is greater than the pounds/horsepower of the 260. Also, the gross weight increase of the aircraft has to be less than the increase weight from the engine and accessories. I'm struggling to see how that's possible -- but then I can't find my manuals either. If someone has the figures for the 260 and the 300 circa 1972, I'd appreciate seeing the data posted here for the gross weight and typical useful loads. I realize that was 35 years ago, but I was pretty sure the 300 could carry more then the 260. -----Original Message----- From: Steve S ] Posted At: Thursday, June 29, 2006 15:54 Posted To: rec.aviation.owning Conversation: Cherokee 6 manual/info? Subject: Cherokee 6 manual/info? The useful load on the -260 is greater than the -300. "Jim Carter" wrote in message .net... We used to haul passengers in both the 260 and 300 for a small real estate development outfit. The 300 is the right size plane with the right size engine. Plenty of power to haul what you can get in it -- something the 260 often came up short on. -----Original Message----- From: Al ] Posted At: Monday, June 26, 2006 16:47 Posted To: rec.aviation.owning Conversation: Cherokee 6 manual/info? Subject: Cherokee 6 manual/info? "john smith" wrote in message news:jsmith-A2C33B.14391126062006@network-065-024-007- 027.columbus.rr.com... In article , "Al" wrote: It looks like I will have a mission to pick up a PA32-300 on Thurs. Can anyone point me to an online copy of the flight maual, or perhaps some of the pertinent information? I've got a couple of hours in a PA32-260 some years ago, and will have a copy of the manual available when I pick up the airplane, however I would like to prepare myself somewhat. Any warnings or items I should watch out for? What year? I have manuals for a 1972 and a 1978. There are differences depending on aircraft serial number. Does the one you will be flying have club seating or all forward facing? - Fuel management is the important thing. The outboards have 17 gal, the inboards/mains have 25. The tab on the inboards/mains may be at 15 gallons or 18 gallons, depending on the serial number. Know which one you have. You will need this information depending on the load you will be carrying. I think the -300 series with the straight wing has 84 gal (17-25-25-17) usable, the -301 series with the taper wing has 96 gal (48-48) usable. - Find out how accurate the fuel flow gauge is. You fly off the mains first, then the outboards. - The manual warns that it may take up to 12 seconds to get fuel flowing from a full tank to the engine if one tank is run dry. [It may give you a warning, listen for the engine surging! Ask me how I know! ;-) ] - Cruise at 16-18 gph, depending on what the owner wants. - Full throttle altitude will vary with OAT, between 6000-8000 feet MSL. - Know your speeds for the current weight you are flying. (Make a table using a spreadsheet or word processor.) - Use 10-deg flaps for all takeoffs to reduce takeoff run. - Fly the airplane using trim. - I prefer to fly high MP/low RPM at cruise, make sure you have a power chart handy. Remember, at or below you can fly LOP without harming the engine. Thanks John. No clue yet what year or config, I do know that the "Load" is 1 pax in addition to me. Al G. |
"Jim Carter" wrote: If someone has the figures for the 260 and the 300 circa 1972, I'd appreciate seeing the data posted here for the gross weight and typical useful loads. The 1972 PA32-300 that I flew had the following numbers: Empty weight: 1810.0 lbs Basic weight: 1926.4 lbs Gross weight: 3400.0 lbs Useful load: 1473.6 lbs |
![]() "john smith" wrote in message ... In article , "Jim Carter" wrote: If someone has the figures for the 260 and the 300 circa 1972, I'd appreciate seeing the data posted here for the gross weight and typical useful loads. The 1972 PA32-300 that I flew had the following numbers: Empty weight: 1810.0 lbs Basic weight: 1926.4 lbs Gross weight: 3400.0 lbs Useful load: 1473.6 lbs Yea, I seem to remember we could put 1000 lbs of freight for the short hops we flew, a long time ago ;-) |
![]() "john smith" wrote in message ... In article , "Jim Carter" wrote: If someone has the figures for the 260 and the 300 circa 1972, I'd appreciate seeing the data posted here for the gross weight and typical useful loads. The 1972 PA32-300 that I flew had the following numbers: Empty weight: 1810.0 lbs Basic weight: 1926.4 lbs Gross weight: 3400.0 lbs Useful load: 1473.6 lbs |
... In article , "Jim Carter" wrote: If someone has the figures for the 260 and the 300 circa 1972, I'd appreciate seeing the data posted here for the gross weight and typical useful loads. The 1972 PA32-300 that I flew had the following numbers: Empty weight: 1810.0 lbs Basic weight: 1926.4 lbs Gross weight: 3400.0 lbs Useful load: 1473.6 lbs My 1969 -260 had gross weight of 3400 and empty weight of 1919. Useful load is 1481. I didn't say it was a lot more than the -300 but it's more :-) |
Jim Carter wrote:
Steve, For that to be true then the increase from engine weight and associated accessories is greater than the pounds/horsepower of the 260. Also, the gross weight increase of the aircraft has to be less than the increase weight from the engine and accessories. I'm struggling to see how that's possible -- but then I can't find my manuals either. If someone has the figures for the 260 and the 300 circa 1972, I'd appreciate seeing the data posted here for the gross weight and typical useful loads. I realize that was 35 years ago, but I was pretty sure the 300 could carry more then the 260. The 260 and 300 both have the same max gross (3400 lbs). An identically equipped 300 is some 80 lbs heavier, which gives the 260 the greater useful load. My '65 -260 has a useful load of 1586 lbs. That said, the -260 is not a short field machine when it is loaded up to gross. Not by any stretch of the imagination. |
A Piper Cherokee 140... good first plane? | Cecil Chapman | Owning | 20 | September 4th 05 02:50 PM |
Cherokee Pilots Association Fly-In Just Gets Better and Better | Jay Honeck | Piloting | 7 | August 8th 05 07:18 PM |
CHEROKEE NATIONAL FLY-IN - MORE INFORMATION | Don | Owning | 0 | June 16th 04 05:14 AM |
Cherokee National Fly-In & Convention - THIS MONTH | Don | General Aviation | 0 | June 3rd 04 05:01 AM |
Cherokee National Fly-In & Convention | Don | General Aviation | 0 | March 20th 04 02:15 AM |
