Kingfish wrote:
Jim Macklin wrote: But I agree, jets require the squat switch (unless there is a malfunction) to deploy reverse. I read recently the C-5 that crashed at Dover, DE had a #2 engine reverser unstow right after takeoff. The crew attempted the approach with full flaps instead of partial flaps per the POH and the sink rate was too high to overcome. It was an "unlock" indication which is one step before an "unstow". They shut down the engine in question to prevent an aysmetric deployment.. I THINK i saw that they had pulled the opposite side engine (#3) back to idle for some reason (directional control presumably... but I would have thought the rudder would have enough authority for that..).. I heard the full flap thing too.. but my version has them retracting from full to some partial setting, and that the airplane was flying below the stall speed for that weight and flap setting, and then simple physics took over. Dave |
![]() "Dave S" wrote in message ink.net... Kingfish wrote: Jim Macklin wrote: But I agree, jets require the squat switch (unless there is a malfunction) to deploy reverse. I read recently the C-5 that crashed at Dover, DE had a #2 engine reverser unstow right after takeoff. The crew attempted the approach with full flaps instead of partial flaps per the POH and the sink rate was too high to overcome. It was an "unlock" indication which is one step before an "unstow". They shut down the engine in question to prevent an aysmetric deployment.. I THINK i saw that they had pulled the opposite side engine (#3) back to idle for some reason (directional control presumably... but I would have thought the rudder would have enough authority for that..).. I heard the full flap thing too.. but my version has them retracting from full to some partial setting, and that the airplane was flying below the stall speed for that weight and flap setting, and then simple physics took over. Dave The report also said that after securing the #2, they continued to operate the #2 thrust lever instead of the #3 which was still operating. Dead foot, Dead engine. Al G. |
Lyc. O-360 cylinder question | JB | Owning | 13 | November 27th 04 09:32 PM |
Handheld battery question | RobsSanta | General Aviation | 8 | September 19th 04 03:07 PM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Question | Charles S | Home Built | 4 | April 5th 04 09:10 PM |
Partnership Question | Harry Gordon | Owning | 4 | August 16th 03 11:23 PM |
