![]() "AES" wrote in message ... some text deleted So, how does a frisbee fly, anyway? Another of his favorites is just a 10" diameter weighted outer rim filled in with a slightly saggy "cloth drumhead", which visibly bulges upward 1" or so at the center into a fair imitation of an airfoil when you throw it. I've always figured the heavy rim kept the thing spinning and thus semi-rigid, and the forward motion of the airfoil shape gave the lift. I'm a proponent of the Bernoulli theory (Stand by with flame deflectors). I agree with the metal mass providing fly wheel effect and the airfoil for lift. I'll add to that my theory that gyroscopic precession makes it tilt so the lift vector turns it. Try changing from backhand to forehand to change the direction of rotation. One small quibble with your post. Frisbee is a brand name and deserves trademark recognition. That is to say, while Frisbee makes a flying disc, not all flying discs are Frisbees. If it don't say Frisbee on the gizzie, it ain't. |
Casey Wilson wrote:
"AES" wrote in message ... some text deleted So, how does a frisbee fly, anyway? Another of his favorites is just a 10" diameter weighted outer rim filled in with a slightly saggy "cloth drumhead", which visibly bulges upward 1" or so at the center into a fair imitation of an airfoil when you throw it. I've always figured the heavy rim kept the thing spinning and thus semi-rigid, and the forward motion of the airfoil shape gave the lift. I'm a proponent of the Bernoulli theory (Stand by with flame deflectors). I agree with the metal mass providing fly wheel effect and the airfoil for lift. I'll add to that my theory that gyroscopic precession makes it tilt so the lift vector turns it. Try changing from backhand to forehand to change the direction of rotation. Then how do you explain how well a simple flat disk such as a CD will fly? It certainly has no airfoil shape. Matt |
Matt Whiting wrote in news:Fj%ng.29$Pa.4943
@news1.epix.net: Snipola Then how do you explain how well a simple flat disk such as a CD will fly? It certainly has no airfoil shape. They don't. At least none of the CD's that I've ever thrown went very far. They all roll immediately and change direction. I used to work at a CD plant, so I had a few to throw around. Brian -- http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html Quake "predictions": http://www.skywise711.com/quakes/EQDB/index.html Sed quis custodiet ipsos Custodes? |
Then how do you explain how well a simple flat disk such as a CD will fly? It certainly has no airfoil shape. Skywise wrote: They don't. At least none of the CD's that I've ever thrown went very far. They all roll immediately and change direction. I agree, CD's fly about as well as a crumpled up piece of paper. You can throw them across the room, but they're not really flying due to lift. Spinning the CD just keeps it somewhat stable, but I don't think it generates any lift. I think throwing a CD vertically will go about the same distance as throwing a CD horizontally. |
Bucky wrote:
Matt Whiting wrote in news:Fj%ng.29$Pa.4943 Then how do you explain how well a simple flat disk such as a CD will fly? It certainly has no airfoil shape. Skywise wrote: They don't. At least none of the CD's that I've ever thrown went very far. They all roll immediately and change direction. I agree, CD's fly about as well as a crumpled up piece of paper. You can throw them across the room, but they're not really flying due to lift. Spinning the CD just keeps it somewhat stable, but I don't think it generates any lift. I think throwing a CD vertically will go about the same distance as throwing a CD horizontally. If you give it a positive AOA at release and it is spinning fast at all, it will fly just fine for a ways. It is too light to go far, but that isn't due to lack of lift. Matt |
"Skywise" wrote in message
... Then how do you explain how well a simple flat disk such as a CD will fly? It certainly has no airfoil shape. They don't. At least none of the CD's that I've ever thrown went very far. They all roll immediately and change direction. They fly as well as a frisbee (kleenex, q-tip, big deal) that has similar size and mass distribution. You can improve things at that scale somewhat by adding more mass around the edge to stabilize it, but as anyone who's tried to toss a small 5" or so frisbee knows, they really don't fly that well at that size, even when they are designed as a frisbee rather than a CD. IMHO, there are two key elements to frisbee aerodynamics: the mass and its distribution (providing stability); and straight-up Newtonian deflection for lift. It's possible that there's a smidgen of airfoil effect due to some oddity of airflow around the disc (air damming up at the front or something like that), and of course there are a number of specialty discs (used in golf, ultimate, etc.) that have specific aerodynamics built in that affect the course of the disc. But otherwise, I would be surprised to find a frisbee is a heck of a lot different, lift-wise, from your hand stuck out the window of a car. Pete |
On 2006-06-27, Peter Duniho wrote:
It's possible that there's a smidgen of airfoil effect due to some oddity of airflow around the disc (air damming up at the front or something like that) A flat plate (which essentially is what the spinning CD will be) will work as an airfoil if it has any angle of attack. John Denker's site has some explanations. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
![]() "Dylan Smith" wrote in message ... On 2006-06-27, Peter Duniho wrote: It's possible that there's a smidgen of airfoil effect due to some oddity of airflow around the disc (air damming up at the front or something like that) A flat plate (which essentially is what the spinning CD will be) will work as an airfoil if it has any angle of attack. John Denker's site has some explanations. I think better analogies would be that it works like a sled on snow or a rock skipping across water. |
Skywise wrote:
Matt Whiting wrote in news:Fj%ng.29$Pa.4943 @news1.epix.net: Snipola Then how do you explain how well a simple flat disk such as a CD will fly? It certainly has no airfoil shape. They don't. At least none of the CD's that I've ever thrown went very far. They all roll immediately and change direction. I used to work at a CD plant, so I had a few to throw around. You need better technique. I can get 50' out of a CD. A larger and heavier thin disk will go a lot farther even. Matt |
Matt Whiting wrote in news:wN7og.35$Pa.5633
@news1.epix.net: Skywise wrote: Matt Whiting wrote in news:Fj%ng.29$Pa.4943 @news1.epix.net: Snipola Then how do you explain how well a simple flat disk such as a CD will fly? It certainly has no airfoil shape. They don't. At least none of the CD's that I've ever thrown went very far. They all roll immediately and change direction. I used to work at a CD plant, so I had a few to throw around. You need better technique. I can get 50' out of a CD. A larger and heavier thin disk will go a lot farther even. Well, the clean room was only so big..... My take on it is that a CD simply has insufficient mass to maintain gyroscopic stability. If you spin it fast enough, yes, but by hand it's not easy. If it were metal I'd expect it to fly just fine. BTW, the CD's came out of the pressing machine with a small plug in the center hole that had what amounted to a small axle through it. This was punched out automatically by the machinery. But, I had a few sample discs with it still in place and you could actually make it spin like a top if you could get it spinning fast enough. I usually used a blast of compressed air, since it was handy. I mean FAST fast. Twirling it by hand was not fast enough. Brian -- http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html Quake "predictions": http://www.skywise711.com/quakes/EQDB/index.html Sed quis custodiet ipsos Custodes? |
