Confused re transponders and ADS-B
I understand that mode S transponders have unique identifiers, thus eliminating the need for beacon "codes" as we use them today. Is that right? Do people flying with mode S today still need to use beacon codes for compatibility reasons? TIS travels via the mode S data link. TIS-B uses ADS-B's data link. So no mode S transponder is required. So, in an ADS-B world, what's the story on transponders. Is mode C still required? Does the ADS-B UAT replace a transponder? Something else? Thanks... Andrew |
Andrew Gideon wrote: I understand that mode S transponders have unique identifiers, thus eliminating the need for beacon "codes" as we use them today. Is that right? No. Do people flying with mode S today still need to use beacon codes for compatibility reasons? Not for compatibility reasons. Take your average Boeing 757 used by an airline. The mode S transponder is registered to the N number. The airline will never use that N number in flight and that aircraft will fly under a different identification every day. TIS travels via the mode S data link. TIS-B uses ADS-B's data link. So no mode S transponder is required. Right but the transponder will allow others to see you. |
On Sun, 25 Jun 2006 16:47:18 -0600, Newps wrote:
Not for compatibility reasons. Take your average Boeing 757 used by an airline. The mode S transponder is registered to the N number. The airline will never use that N number in flight and that aircraft will fly under a different identification every day. It doesn't need to be this way. The controller could "assign" a "code" to the mode S id. The aircraft would never need to be involved. Still, from what you describe it apparently doesn't work that way. Oh well; I guess we're stuck with those base 8 codes. I suppose that this does provide the benefit of assuring that the object on the screen is in fact the aircraft the controller thinks it is. I'm a little surprised, though. I vaguely recall something about these being too limited for future applications. Perhaps I misunderstood (or am misremembering). TIS travels via the mode S data link. TIS-B uses ADS-B's data link. So no mode S transponder is required. Right but the transponder will allow others to see you. Which "others"? Does that mean that, as soon as those "others" "upgrade", the transponder will be a thing of the past? No more beacon codes? - Andrew |
Andrew Gideon wrote: I understand that mode S transponders have unique identifiers, thus eliminating the need for beacon "codes" as we use them today. It *could* eliminate the need for beacon codes, but only if everyone switched to Mode S transponders and all secondary radars were Mode S. TIS travels via the mode S data link. TIS-B uses ADS-B's data link. So no mode S transponder is required. no mode S required for ADS-B (still required for other reasons - for example a TCAS II system still requires Mode S) So, in an ADS-B world, what's the story on transponders. Is mode C still required? Does the ADS-B UAT replace a transponder? Something else? The ADS-B UAT provides an alternate datalink in lieu of the Mode $ tran$ponder's datalink. The transponder is still required at this time. In theory, we could dump transponders but that would require a change in how aircraft are located and identified. Numerous issues have to be addressed (no pun), including problems with spoofing. -- Bob Noel Looking for a sig the lawyers will hate |
I understand that mode S transponders have unique identifiers, True, they not only have unique identifiers but can also transmit a settable identification number (such as a flight number). thus eliminating the need for beacon "codes" as we use them today. It might, but ATC still operates in a discrete code based world. I've got mode S but it hasn't changed squat with respect to ACTC So, in an ADS-B world, what's the story on transponders. Is mode C still required? Does the ADS-B UAT replace a transponder? Something else? Transponders are still required because ATC is ignorant about ADS-B and so is TCAS. |
On Sun, 25 Jun 2006 20:22:33 -0400, Ron Natalie wrote:
Transponders are still required because ATC is ignorant about ADS-B and so is TCAS. But only mode C? That is, in an ADS-B world there's no need to upgrade to mode S? - Andrew |
On Sun, 25 Jun 2006 20:22:33 -0400, Ron Natalie wrote: Transponders are still required because ATC is ignorant about ADS-B and so is TCAS. But only mode C? That is, in an ADS-B world there's no need to upgrade to mode S? - Andrew My crystal ball is cloudy as to whether the FAA is going to continue to take the political pressure and graft that led to the disaster of Mode S and TCAS to begin with. |
