questions on multi-wing planforms
Old June 27th 06, 03:06 AM posted to rec.aviation.homebuilt
Default questions on multi-wing planforms
pTooner wrote:
Firstly, I am new here although I've been reading for a few days. For
anyone with more knowledge than I, I keep considering building a small 4
wing aircraft. Not stacked, but two up front and two in the rear. I have
read frequently of problems supposedly resulting from interference of the
airflow between wings, but I can't seem to find anything very specific. I'm
fairly confident that interference between the front wings (or rear) can be
minimized by reasonable spacing and differing dihedral. I'm not sure what
the effect of the airflow coming off the front wings will have on the rear
set. I don't know whether I could remove most of the problem by having one
set considerably higher (how much?) than the other set or if it is
reasonable to have them on more or less the same height. The reason for
the concept is trying to get a wingspan small enough to fit into a normal
garage and conceivably take off and land from streets and highways. I
visualise something in a two place plane that would fall into something of
the appeal category of a motorcycle or small sports car. Any thoughts would
be appreciated.
Gerry
Gerry! Look up the Stinton reference I gave you, read it over a bunch
of times 'til you start getting an idea of how spacing and stagger
would affect the wing placement. Then keep in mind, this is
Experimental aviation! Try your idea in a large model; see how that
works. But don't let the nay-sayers keep you from experimenting.
There's no progress in building the same thing over and over. Your
creation doesn't have to be the most efficient thing out there. All
designs call for some compromises! Good experimenting!
Old June 27th 06, 04:18 AM posted to rec.aviation.homebuilt
"ELIPPSE" wrote in message
have
I'm
be
what
rear
one
of
would
be appreciated.
Gerry
Thanks, I haven't located that book yet, but I will. And I will on the
experimenting too.
Gerry
Thrusting or Sucking (where's Howard Stern when we need him.) Ken Kochanski (KK) Soaring 37 January 14th 06 09:51 AM
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 08:40 PM
Wing tip stalls mat Redsell Soaring 5 March 13th 04 05:07 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
Wing Extensions Jay Home Built 22 July 27th 03 12:23 PM
