Paul Tomblin wrote:
As a former surveyor, I can tell you that the altitude requirements for surveying are a lot more precise than for aviation - if my bridge abutment is built 2 feet high, I'm getting fired. If my plane is 2 feet high, nobody is going to notice. Looks as if I'm missing something central here, as usual ![]() If there is a 4-hour flight that passes over some 10 waypoints and if the FMGS keeps getting data that's off by 50 meters or so, am I to understand that the aircraft will still make heading changes, etc. that'd be in accordance with the programmed flight plan and that none of the waypoints will be missed or indeed the final destination precisely arrived at? And someone mentioned an acceptable accuracy of 0.1 foot in property surveying. If surveyors in my industry had that much latitude, there'd be a lot of equipment skids that'd get installed quite inappropriately, with lots of patched modifications thereon ![]() Ramapriya |
oups.com... Looks as if I'm missing something central here, as usual ![]() Could be. ![]() If there is a 4-hour flight that passes over some 10 waypoints and if the FMGS keeps getting data that's off by 50 meters or so, am I to understand that the aircraft will still make heading changes, etc. that'd be in accordance with the programmed flight plan and that none of the waypoints will be missed or indeed the final destination precisely arrived at? That is correct. The presumed 50 meter accuracy is constant throughout the flight. It's not as though it's additive for each waypoint (or worse, as a continuous function along the flight). Though frankly, even if it were, you'd only be off by 500 meters after 10 waypoints which is still "no big deal". That's one of the many nice things about GPS. It is a continuous readout of one's current position and any forward-looking navigation solution can be derived from the instantaneous position information, without any previous position information affecting the future calculations. And of course, again...being 50 meters off in aviation just isn't that big of a problem. Heck, being a mile off in aviation isn't that big of a problem most of the time. And someone mentioned an acceptable accuracy of 0.1 foot in property surveying. If surveyors in my industry had that much latitude, there'd be a lot of equipment skids that'd get installed quite inappropriately, with lots of patched modifications thereon ![]() Well, as that poster pointed out, it depends on the situation. But property surveying for non-commercial purposes isn't likely to be used for any sort of actual construction (except possibly locating a building, and for sure no one is going to care if a building is off one inch one direction or another, especially in a non-commercial situation). As for equipment skids and such, since I don't know the details of your industry I can't really comment on that. But it seems to me that if you require that level of detail and are using GPS to accomplish it, you must be dealing with positioning these skids at a significant distance from wherever they are referenced to. Otherwise, I'd think one would use more "conventional" surveying techniques to determine position, orientation, etc. The only surveys I've ever hired were strictly property surveys, in which property boundaries are determined, locations of roads, trees, terrain contours, etc. Getting the results to within an inch is perfectly sufficient for that type of survey. It's not hard to imagine a wide variety of surveys for which the same holds true. Just because some situations demand higher precision, that doesn't mean all situations do. Pete |
Peter Duniho wrote:
That is correct. The presumed 50 meter accuracy is constant throughout the flight. It's not as though it's additive for each waypoint (or worse, as a continuous function along the flight). Though frankly, even if it were, you'd only be off by 500 meters after 10 waypoints which is still "no big deal". Now I know why planes occasionally land on the wrong runway in IFR conditions ![]() As for equipment skids and such, since I don't know the details of your industry I can't really comment on that. But it seems to me that if you require that level of detail and are using GPS to accomplish it, you must be dealing with positioning these skids at a significant distance from wherever they are referenced to. Otherwise, I'd think one would use more "conventional" surveying techniques to determine position, orientation, etc. When I began my career, there were only conventional surveying equipment. These days, however, rarely do you get a client in the oil and gas industry who'll accept anything but a GPS survey. Btw, we engineers are barred too from all surveying, although we're responsible for supervision and copping attendant liabilities. The actual task itself is carried out by qualified surveyors who do nothing else ![]() Ramapriya |
oups.com... Now I know why planes occasionally land on the wrong runway in IFR conditions ![]() Well, for what it's worth, wrong-runway (or even wrong airport) landings are much more common in visual conditions, when the pilot is trusted to find the runway himself. Flying an ILS involves tuning a radio to a frequency that is specific to the runway. If an airplane winds up in a position to land on the wrong runway, then the ILS indication will be so far off that the pilot should be flying a "missed approach" (that is, aborting the approach to try again). In visual conditions, simple human error can result in landing in the wrong place. In instrument conditions, there needs to be a series of poor judgment decisions on the part of the pilot (or the simple error of tuning the wrong frequency into the ILS receiver, of course ![]() "accuracy of guidance" issue, so it doesn't seem relevant in this discussion). Pete |
![]() wrote in message oups.com... Peter Duniho wrote: That is correct. The presumed 50 meter accuracy is constant throughout the flight. It's not as though it's additive for each waypoint (or worse, as a continuous function along the flight). Though frankly, even if it were, you'd only be off by 500 meters after 10 waypoints which is still "no big deal". Now I know why planes occasionally land on the wrong runway in IFR conditions ![]() As someone already mentioned, the error is not cumulative. Then, too, approach GPS is a different animal from enroute. |
conditions You do? I don't. In fact, I don't think they do. That happens in visual conditions. -- Thomas Borchert (EDDH) |
Airmens' Freedoms Threatened by Harsh Congressional Proposals | Larry Dighera | Piloting | 24 | July 29th 05 06:15 PM |
Aviation Books&CD Roms FS | [email protected] | Home Built | 0 | April 10th 05 10:29 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Home Built | 3 | May 14th 04 11:55 AM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Owning | 0 | May 11th 04 10:43 PM |
