Mr
McNicoll is correct is stating that he is allowed to substitute GPS for ADF in certain circumstances. However we have to consider the least possibly equipped aircraft shooting this approach and that requires that we place an "ADF REQUIRED " note on this approach. Why not "ADF OR GPS required"? Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
Jose wrote:
Mr McNicoll is correct is stating that he is allowed to substitute GPS for ADF in certain circumstances. However we have to consider the least possibly equipped aircraft shooting this approach and that requires that we place an "ADF REQUIRED " note on this approach. Why not "ADF OR GPS required"? Jose Good question. I'm sure that will be an option in the not too distant future, but right now you can't mix and match ground-based systems with GPS on published procedures due to TERPS requirements. That's another set of guidelines that allows substitution with GPS in some circumstances, and already you may have seen NOTAMS stating "Procedure NA except for IFR certified GPS equipped aircraft" where the NOTAM specifically allows substitution for DME or ADF ancillary equipment. John |
On 06/29/06 15:17, JPH wrote:
Jose wrote: Mr McNicoll is correct is stating that he is allowed to substitute GPS for ADF in certain circumstances. However we have to consider the least possibly equipped aircraft shooting this approach and that requires that we place an "ADF REQUIRED " note on this approach. Why not "ADF OR GPS required"? Jose Good question. I'm sure that will be an option in the not too distant future, but right now you can't mix and match ground-based systems with GPS on published procedures due to TERPS requirements. Huh? The AIM has a complete section called "Use of GPS in lieu of ADF and DME" That's another set of guidelines that allows substitution with GPS in some circumstances, and already you may have seen NOTAMS stating "Procedure NA except for IFR certified GPS equipped aircraft" where the NOTAM specifically allows substitution for DME or ADF ancillary equipment. John -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA |
![]() "JPH" wrote in message news:TjYog.11140$f76.5031@dukeread06... Good question. I'm sure that will be an option in the not too distant future, but right now you can't mix and match ground-based systems with GPS on published procedures due to TERPS requirements. That's another set of guidelines that allows substitution with GPS in some circumstances, and already you may have seen NOTAMS stating "Procedure NA except for IFR certified GPS equipped aircraft" where the NOTAM specifically allows substitution for DME or ADF ancillary equipment. It's an option now. See AIM para 1-1-19.f.: http://www.faa.gov/atpubs/AIM/Chap1/aim0101.html#1-1-19 |
Steven P. McNicoll wrote:
"JPH" wrote in message news:TjYog.11140$f76.5031@dukeread06... Good question. I'm sure that will be an option in the not too distant future, but right now you can't mix and match ground-based systems with GPS on published procedures due to TERPS requirements. That's another set of guidelines that allows substitution with GPS in some circumstances, and already you may have seen NOTAMS stating "Procedure NA except for IFR certified GPS equipped aircraft" where the NOTAM specifically allows substitution for DME or ADF ancillary equipment. It's an option now. See AIM para 1-1-19.f.: http://www.faa.gov/atpubs/AIM/Chap1/aim0101.html#1-1-19 I realize that GPS can be used as a substitute, and pointed that out in my message. His question was why the ground based procedure didn't have a chart note "ADF or GPS required". What I was stating is that TERPS criteria does not yet allow combining ground based and GPS on the chart, that's why the procedure does not say "ADF or GPS required" (A temporary NOTAM can address GPS but the chart can not). As I said, you can use GPS to substitute in some situations based on regulations other than TERPS, but TERPS criteria does not yet allow GPS notes to be charted on ground based procedures (except on the old GPS overlay procedures). TERPS criteria still requires ground based procedures to be built based only on ground based equipment, so your not going to see a "GPS required" note on a ground based procedure. JPH |
![]() "JPH" wrote in message news:EEmpg.11443$f76.5591@dukeread06... I realize that GPS can be used as a substitute, and pointed that out in my message. You did? Where? His question was why the ground based procedure didn't have a chart note "ADF or GPS required". What I was stating is that TERPS criteria does not yet allow combining ground based and GPS on the chart, that's why the procedure does not say "ADF or GPS required" (A temporary NOTAM can address GPS but the chart can not). As I said, you can use GPS to substitute in some situations based on regulations other than TERPS, but TERPS criteria does not yet allow GPS notes to be charted on ground based procedures (except on the old GPS overlay procedures). TERPS criteria still requires ground based procedures to be built based only on ground based equipment, so your not going to see a "GPS required" note on a ground based procedure. "ADF OR GPS REQUIRED" would just add unnecessary clutter as it's already understood that GPS can substitute for ADF in cases like this. |
![]() "Jose" wrote in message om... Why not "ADF OR GPS required"? No need for that, GPS can substitute for ADF in this case anyway. But why not "ADF REQUIRED FOR LOC RWY 2"? |
Help! - Wooden prop - any info? | G0MRL | Aviation Marketplace | 1 | February 13th 06 03:14 PM |
Seeking Northrop Gamma info | Dillon | Restoration | 3 | December 12th 05 04:45 AM |
Helicopter Physics info online anywhere?? | [email protected] | Rotorcraft | 4 | April 24th 04 04:18 PM |
POSA Carb Info and HAPI Engine Info | Bill | Home Built | 0 | March 8th 04 08:23 PM |
Starting new info site need info from the pros | MRQB | Piloting | 7 | January 5th 04 03:20 AM |
