Whew - ASI died in flight
Old July 1st 06, 06:54 PM posted to rec.aviation.piloting
Mortimer Schnerd, RN[_1_]
Default Whew - ASI died in flight
Dale wrote:
I wouldn't use your trim procedure. There is a big difference in trim
settings with the 182 depending on loading. Solo you may need almost
full up trim for a normal approach...with the folks in the rear seat a
neutral trim setting will work pretty well.
Just put the nose where it's supposed to be...that works regardless of
load.
You may find it educational to look at where the trim is in cruise flight vs
where it is with full flaps and proper approach speed. I've lost ASI three
times over the years and each time was after flying through a deluge. If you
start getting slow you'll know it by the way the plane feels. Sloppy handling
close to the ground is not good for your continued health and wellbeing.
But I digress. Look at where the trim wheel is for cruise and for approach.
This is information that is good to have.
VE
RAF Blind/Beam Approach Training flights Geoffrey Sinclair Military Aviation 3 September 4th 09 06:31 PM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
