Preferred Routing
Old September 17th 04, 07:28 PM
Michael
Andrew Sarangan wrote
The preferred routes are listed in the AF/D. But those are pretty much
useless.
Sad but true.
You can get a better clue for the routing by looking at the
STARs.
Yes, but... You don't necessarily know what STAR's serve your
airport. I know it shouldn't be that way, but it is. If you come
into EYQ from the East or Northeast, you are going to get the ROKIT 7
arrival. Trust me - happens every time. Only there is no ROKIT 7
arrival for EYQ, and no transition to EYQ on the ROKIT 7. So how do I
know? Experience. Funny thing is, there are STARs published for EYQ
- just not ROKIT 7.
There used to be a WESAT 3 arrival for EYQ. Then BLUBELL ONE was
published. They covered the same territory. Only way to know which
one you would get was local knowledge. Eventually, they shut down
WESAT 3.
Same principle applies to DP's.
Nevertheless, the basic advice given is sound. You do the best you
can working from the available DPs and STARs and it usually works
except when it doesn't, and there nothing will work except local
knowledge.
Michael
WTB: Cessna 150 Straight Tail Feathers Preferred Spar Home Built 0 July 16th 04 08:39 PM
Preferred Routing or Tower Enroute Control cefarthing Instrument Flight Rules 3 November 30th 03 04:53 PM
IFR Routing Toronto to Windsor (CYTZ - CYQG) Rob Pesan Instrument Flight Rules 5 October 7th 03 01:50 PM
