I'm not convinced that it is right.
Vx occurs at the airspeed where excess thrust is maximized, while Vy occurs at the airspeed where excess power is maximized. Off the top of my head, I don't see any reason to believe that for a jet, that it's a given that maximum excess thrust would occur at a constant airspeed with respect to altitude. The ***TAS*** would definitely increase, but the drag/thrust curve moves to the right rather than to the right and up like the power required curve. As far as I can tell, and I'm basing it (probably WAY too much) on the interactive program found at this page http://www.professionalpilot.ca/aero.../climb_jet.htm, the ***IAS*** remains almost constant for a jet. Confusing stuff. |
"xerj" wrote in message
... The ***TAS*** would definitely increase, We were talking about IAS. I didn't change that. but the drag/thrust curve moves to the right rather than to the right and up like the power required curve. As far as I can tell, and I'm basing it (probably WAY too much) on the interactive program found at this page http://www.professionalpilot.ca/aero.../climb_jet.htm, the ***IAS*** remains almost constant for a jet. Got an example that doesn't require the installation of an ActiveX control? I have, against my better judgment, already succumbed to Java and Flash, but I draw the line at adding Shockwave to the mix. Also note that "remains almost constant" isn't the same as "stays the same". Confusing stuff. It's only confusing to those who haven't studied it enough to have an intuitive sense of how things work. Of course, that describes most of us (including myself). ![]() seems to me that in aerodynamics particularly, most analysis winds up being based on some fairly simple principles. The trick is knowing how to apply them. Pete |
No, I don't have an example without the need for shockwave.
I'll trawl around and see if I can can up with something. |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 03:04 AM |
IVO props... comments.. | Dave S | Home Built | 16 | December 6th 03 11:43 PM |
Overweight takeoff / flight | Koopas Ly | Piloting | 50 | December 3rd 03 11:53 PM |
