#31
Aaron Coolidge writes:
You wouldn't convert it. You'd just hook it up to ~125 VDC. It will work great. You may have trouble if it has an electronic thermostat (SCR/TRIAC) because these require the reversals of the AC voltage to stop conducting (you can turn on a TRIAC with DC across it, but you have to interrupt the current flowing to shut it off). Good point. Do any engine heaters have electronic thermostats though? I was under the impression that they limited themselves simply with the increased resistance of the heating elements at higher temperatures. --kyler |
#32
On Wed, 5 Jul 2006 17:11:54 +0000 (UTC), Aaron Coolidge
wrote: Ron Rosenfeld wrote: : What are the design considerations for converting a heating element that : has been designed to function on 120VAC to 12VDC? : For example, I have a TANIS system in my a/c which draws about 375W @ : 120VAC. You wouldn't convert it. You'd just hook it up to ~125 VDC. It will work great. You may have trouble if it has an electronic thermostat (SCR/TRIAC) because these require the reversals of the AC voltage to stop conducting (you can turn on a TRIAC with DC across it, but you have to interrupt the current flowing to shut it off). Ok, I see what you have in mind. So instead of a 12V DC PV system and 12V batteries, we would set up a 120VDC system and batteries. Depending on the batteries, some fancy wiring would be needed also to do the trickle charging for the a/c battery. I suspect the costs of setting up a low wattage 120VDC system would be excessive compared with the 120VAC system. I did find a 4.5W 12V thin film solar panel for $45. You'd need 10 of them in series and they only have a 2 year warrantee. That's $450 without putting together a 120VDC battery bank. Sunwize makes a 5W panel available for $68.60 with a twenty year warrantee, which is closer to the "industry-standard". You'd still need ten of them for $686.00. Then for batteries, you'd need to size them, too, appropriately. I guess with the 60 cells a 120VDC battery would require, I'd want to use a sealed AGM or Gel Cell or some other maintenance free battery bank. Then you'd have to check the rating at the discharge rate. If the heater draws 1A for four hours, and you have a deep discharge battery that you can draw down 50%, you'd need to figure the battery capacity at that current draw. (Battery capacity changes depending on current draw). I see a 12AH 12V AGM battery for $15.95. At 0°F and drawing 1.12A, it has a capacity of 8.16AH. A four hour heating run would draw it down to 50% capacity. There's another $159.50. Since he's not running the heater every day, (I'm assuming once/week), the array should replenish the batteries after a few days of sunshine. Of course, when you get into PV systems with a nominal voltage of greater than 50V, there are a variety of NEC code requirements to be complied with. They are safety related but, if he's at a public airfield, there may be inspection fees and a requirement for a licensed electrician. I still think the 12VDC / Inverter system will be less expensive than the 120VDC system when all is said and done. It may or may not be cheaper than running a line to a nearby hangar and paying for the electricity, depending on those costs. For an AC system you could save money by using larger panels. ($/watt decreases as watts increase). I see a 12V 30Watt panel that would meet the requirements for $178.20. A Trojan 27TMX 12V 105AH (20hr rate) battery is $118.25 and you'd only need one of them. So for panel and battery we're at just under $300 for battery and panel. I see 300W inverters available for as low as $27 but I'd guess $100 would purchase a more reasonable unit. Add mounts, wiring, etc. and we're probably close to the $500 I originally guesstimated for the system, versus probably double that for the 120VDC system. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
#33
On Wed, 05 Jul 2006 17:05:21 -0400, Ron Rosenfeld
wrote: On Wed, 5 Jul 2006 17:11:54 +0000 (UTC), Aaron Coolidge wrote: Ron Rosenfeld wrote: : What are the design considerations for converting a heating element that : has been designed to function on 120VAC to 12VDC? : For example, I have a TANIS system in my a/c which draws about 375W @ : 120VAC. You wouldn't convert it. You'd just hook it up to ~125 VDC. It will work great. You may have trouble if it has an electronic thermostat (SCR/TRIAC) because these require the reversals of the AC voltage to stop conducting (you can turn on a TRIAC with DC across it, but you have to interrupt the current flowing to shut it off). Ok, I see what you have in mind. So instead of a 12V DC PV system and 12V batteries, we would set up a 120VDC system and batteries. Depending on the batteries, some fancy wiring would be needed also to do the trickle charging for the a/c battery. I suspect the costs of setting up a low wattage 120VDC system would be excessive compared with the 120VAC system. I did find a 4.5W 12V thin film solar panel for $45. You'd need 10 of them in series and they only have a 2 year warrantee. That's $450 without putting together a 120VDC battery bank. Sunwize makes a 5W panel available for $68.60 with a twenty year warrantee, which is closer to the "industry-standard". You'd still need ten of them for $686.00. Then for batteries, you'd need to size them, too, appropriately. I guess with the 60 cells a 120VDC battery would require, I'd want to use a sealed AGM or Gel Cell or some other maintenance free battery bank. Then you'd have to check the rating at the discharge rate. If the heater draws 1A for four hours, and you have a deep discharge battery that you can draw down 50%, you'd need to figure the battery capacity at that current draw. (Battery capacity changes depending on current draw). I see a 12AH 12V AGM battery for $15.95. At 0°F and drawing 1.12A, it has a capacity of 8.16AH. A four hour heating run would draw it down to 50% capacity. There's another $159.50. Since he's not running the heater every day, (I'm assuming once/week), the array should replenish the batteries after a few days of sunshine. Of course, when you get into PV systems with a nominal voltage of greater than 50V, there are a variety of NEC code requirements to be complied with. They are safety related but, if he's at a public airfield, there may be inspection fees and a requirement for a licensed electrician. I still think the 12VDC / Inverter system will be less expensive than the 120VDC system when all is said and done. It may or may not be cheaper than running a line to a nearby hangar and paying for the electricity, depending on those costs. For an AC system you could save money by using larger panels. ($/watt decreases as watts increase). I see a 12V 30Watt panel that would meet the requirements for $178.20. A Trojan 27TMX 12V 105AH (20hr rate) battery is $118.25 and you'd only need one of them. So for panel and battery we're at just under $300 for battery and panel. I see 300W inverters available for as low as $27 but I'd guess $100 would purchase a more reasonable unit. Add mounts, wiring, etc. and we're probably close to the $500 I originally guesstimated for the system, versus probably double that for the 120VDC system. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) I forgot to mention that the pricing source I used was http://home.altenergystore.com/ You can probably find stuff a bit cheaper, although when I've purchased big ticket items from them, they have matched any advertised price I've seen on the web. And sure, you can build your own PV panels from scrap for a lot less; you can also build your own batteries; but unless you're a real tinkerer and doing it for fun ... Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Please help -- It's down to the wire | Jay Honeck | Owning | 24 | July 14th 04 06:05 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
