Marty Shapiro wrote: The other club I checked only prohibits landings on dirt, sod, or gravel runways - or at any airport that is not listed in the AF/D unless prior approval is given by the club manager or chief pilot. They also prohibit touch & goes by primary students if the runway is less than 4,000' and for anyone in a retract, high performance, or turbocharged aircraft. A club mountain flying checkout is required for operations at an airport higher than 2,000' MSL or over mountanous terrain over 8'000' MSL. If this is the club I'm thinking of, they're also know for having rules for just about everything. They probably don't have a generic runway requirement due to the fact that they are based out of airports with ~2500ft runways. John -- John Clear - http://www.clear-prop.org/ |
Yep, that's the club. At least they have removed the 3,000' restriction. One of the clubs quickly recovered when I asked where to return the aircraft and said the restriction only applied to non-towered fields. How or why the presence of a control tower should make a difference, I don't know. The tower will make some effort to see that you land into the wind. Downwind landings and short runways make a bad combination. |
In article , Roy Smith wrote:
The tower will make some effort to see that you land into the wind. The tower will make some effort, but sometimes it takes awhile for them to spin things around, especially when the pattern is busy. Downwind landings and short runways make a bad combination. I was flying the pattern at Palo Alto (PAO) one day when the winds were favoring 12, and then changed to a crosswind and then a ~5kt tailwind. There was the usual 10+ planes in the pattern. I was told I was going to be the last to land on 12 before they spun the pattern around for 30. Unfortunately, the wind was picking up, and I needed the runway to be about 10ft longer. Fortunately, the plane wasn't damaged by the trip into the weeds. A few minutes later the wind was reported as 10kts pretty much straight down the runway. The runway at PAO is 13/31 now, so this happened quite a while ago. It was quite eye opening to sit and calculate the landing roll with a 10kt tailwind. It doesn't sound like much, but it will basically double the distance needed. John -- John Clear - http://www.clear-prop.org/ |
John,
I was flying the pattern at Palo Alto (PAO) Wonder why you just happen mention THAT airport ;-) -- Thomas Borchert (EDDH) |
Roy Smith wrote:
Marty Shapiro wrote: Yep, that's the club. At least they have removed the 3,000' restriction. One of the clubs quickly recovered when I asked where to return the aircraft and said the restriction only applied to non-towered fields. How or why the presence of a control tower should make a difference, I don't know. The tower will make some effort to see that you land into the wind. Downwind landings and short runways make a bad combination. Gee never known a tower to accept that responsiblity. As a matter of fact I've had a few try to land me downwind. At least at an uncontrolled field I don't even have to ask to take the preferred runway. |
John Clear wrote:
If this is the club I'm thinking of, they're also know for having rules for just about everything. Looks an awful lot like a club I know which operates from a 2443 x 70 ft runway :-) I am pretty sure -- but then I left quite a while ago for saner pastures -- they have a checkout procedure -- and currency requirements -- for the use of the bathroom... the funny thing though is that all these rules don't seem to do much good to their safety record, but I digress. --Sylvain |
Sylvain wrote: John Clear wrote: If this is the club I'm thinking of, they're also know for having rules for just about everything. Looks an awful lot like a club I know which operates from a 2443 x 70 ft runway :-) I am pretty sure -- but then I left quite a while ago for saner pastures -- they have a checkout procedure -- and currency requirements -- for the use of the bathroom... the funny thing though is that all these rules don't seem to do much good to their safety record, but I digress. --Sylvain It also sounds like a club that had a "spot the maintenance flaws" contest one day, several years ago. They rigged a Cessna 152 with about 20 deliberate maintenance flaws and conducted a test for their members to spot the flaws on a preflight. A good friend of mine, who instructed there, and had had a set of major problems with a homebuilt he had bought, entered the contest and proceeded to find not only all the flaws on the contest list, but numerous "extra credit" flaws not on the list. Needless to say, the maintenance chief received a major "wirebrushing" as a result. |
What is a "short field" for a PA28-181 | Roy Page | Owning | 79 | November 24th 04 12:11 PM |
Short field in a Mooney | AJW | Piloting | 0 | September 26th 04 04:47 AM |
Night landings vs. day landings | Gerald Sylvester | Piloting | 15 | February 12th 04 06:38 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Tailwheel endorsement | John Harper | Piloting | 58 | December 12th 03 01:48 PM |
