![]() On 5-Jul-2006, "FlyWithTwo" wrote: Hi Scott, An A&P friend showed me a trick on an access panel that had some stuck fasteners. He used a 1/4" speeder wrench with a phillips head socket. The speeder wrench looks like an old "bit and brace" drill. It allows you to push hard on the bit and still keep it square when you turn it. In the Air Force we called that tool a "speed handle" but I'm sure your name is more accurate. I'm sure I've got hundreds of hours turning those, we used them for opening and closing all of the various access panels on the F-4Cs and F-4Es I worked on waaay back when. Fighters use LOTS of panel fasteners! You're right, this tool does work pretty well for freeing stuck screws. Put a little valve-grinding compund on the bit tip and you can't miss! I used to know a fellow that had another type of stuck screw removal tool. I'm not sure who made it, perhaps Snap-On, but it looked kind of like a fat stubby screwdriver with a metal handle. You'd put an Apex bit in it, stick the bit in the stuck screw, and whack the butt of the handle with a hammer. The impact of the hammer pushed the bit into the handle a little, and at the same time the bit was twisted slightly counter-clockwise. That would break loose stuck screws pretty easily and quickly. You had to be careful not to whack it so hard as to cause other problems though! Scott Wilson |
Here's the tool I was talking about
http://www.factsfacts.com/MyHomeRepa...pactdriver.jpg Here is the description as I found it on factsfacts.com's site: An impact screwdriver is designed to rotate the screwdriver tip when the handle is hit with a hammer. So, the tip is forced into the screw head by the hammer blow at the same time the tip is being rotated to loosen the screw. If you have a motorcyclist friend she may have one. If the screw is in cast iron, or something else you could break by hitting it, you may not want to use this. |
Airtex Interior Refurbishment - Day 53 | Mike Spera | Owning | 1 | May 26th 05 02:52 PM |
Why not a hinged panel? | Jay Honeck | Owning | 22 | March 7th 05 11:15 PM |
PA28-181 - Stuck Mike - King Silver Crown | Roy Page | Owning | 2 | October 29th 04 03:36 AM |
Trying to find the Boeing 737-300 Photo Real Panel for FS98(antique;-) | Heiko Brandstaedter | Simulators | 0 | October 7th 04 02:42 PM |
C182 Glass Panel | Scott Schluer | Piloting | 15 | February 27th 04 03:52 PM |
