The last thing I want is another instrument. I enjoy gliding because I
can fly by visual references and only use the instruments to glance at occasionally. Bill Daniels wrote: "Don Johnstone" wrote in message ... At 06:42 08 July 2006, G L I D E R S T U D wrote: Yaw sting....if you cant feel your body sliding left or right when your uncoordinated, you should probably relax some, because you are way too uptight. But then again one of my coaches said I was too relaxed. On that note my Discus 2ax didn't have a yaw sting, and my Nimbus 3 doesn't have one either, and I probably won't get it 'fixed' before the Opens. I fly in the mountains and I don't feel that it is hazardous. Plus that sting is way too much drag. I defy anyone to 'feel' the tiny amount of yaw that a yaw string will indicate. The drag created by even the largest piece of wool will be very small compared to even a small amout of yaw in straight and level flight. A 'T&S' ball is just not sensitive enough and the yaw string has the advantage of being in your eye line, you don't have to go heads down to see it. To fly efficiently in a big winged glider is is even more essential as even tiny amoutns of control differences are magnified with the addition leverage of long wings. To Don Johnstone - Yep! The weather is doing something it hasn't done in quite a while - raining - therefore, I'm spending the weekend indoors. This has led me to research a few ideas that I had set aside. One of them is an angle of attack indicator for gliders. Any reading of accident reports will quickly lead one to the conclusion that pilots don't pay enough attention to AOA. No matter how hard AOA is hammered into a students brain, a few months after their checkride, they just watch the ASI. Some of them are involved in stall/spin accidents. AOA indicators have long been essential to the safe operation of large aircraft so, now that electronics are cheap, why not gliders too? Gliders spend a lot of time flying near the stall AOA so we shoud be especially interested in an AOA indicator. So, how do we measure AOA? The traditional nose boom pitch vane is too fragile for gliders but there is another way to get AOA data. Companies like Masi make a simple AOA probes. See: http://www.cgmasi.com/aviation/index.html The Masi probe computes AOA from the pressure difference between two pressure ports at 45 degrees to the airflow. Could the same be done with pressure ports located on upper and lower nose? I think so. An inexpensive differential pressure sensor and a bit of electronics driving an LED lightbar plus a calibration proceedure would do it. The calilbration procedure would be simple since we are only interested in three AOA's - Stall, Minimum sink, and Best L/D. These would be very helpful when flying gliders with a wide range of wing loadings. The min sink AOA would be particularly helpful when flying at steep bank angles. Gliders with flaps would have to repeat the calibration procedure for each flap setting of interest - those being approach flaps and thermalling flaps. Flap setting would have to be sent to the AOA conputer. Any gadgeteers out there interested in making a few bucks awhile maybe saving a few lives? Bill Daniels |
question about instrument proficiency check | Sylvain | Instrument Flight Rules | 14 | October 20th 05 09:11 AM |
CRS: V-22 Osprey Tilt-Rotor Aircraft | Mike | Naval Aviation | 0 | October 14th 05 08:14 PM |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
