John A. Weeks III writes In article op.tcfi56vzj9nxpm@clive, Clive wrote: But, The concorde crash was caused by something outside the control of the concorde crew i.e. debris from another aircraft (also the same for the Lockerbie 747), So had it not been for that it's record would have been 100%. That is a totally unrealistic line of thought. There will be FOD on the ramp or runway as some point in an airplane's operating life. Had that small piece of metal not been on the runway the day that the Concorde crashed, it would have been on some other runway some other day. An airplane that is designed to crash, burn, and kill over 100 people when it its a small piece of FOD is an aircraft that is both flawed and an accident waiting to happen. The only curious thing is why it took so long. In fact, a previous time that a Concorde hit debris and punctured the fuel tanks, the aircraft managed to survive without crashing. That is probably the true wonderment. -john- SMALL piece of FOD? Or a big chunk? Whatever, it shouldn't have been there. -- Mike Lindsay |
![]() Mike Lindsay wrote: In article , John A. Weeks III writes In article op.tcfi56vzj9nxpm@clive, Clive wrote: But, The concorde crash was caused by something outside the control of the concorde crew i.e. debris from another aircraft (also the same for the Lockerbie 747), So had it not been for that it's record would have been 100%. That is a totally unrealistic line of thought. There will be FOD on the ramp or runway as some point in an airplane's operating life. Had that small piece of metal not been on the runway the day that the Concorde crashed, it would have been on some other runway some other day. An airplane that is designed to crash, burn, and kill over 100 people when it its a small piece of FOD is an aircraft that is both flawed and an accident waiting to happen. The only curious thing is why it took so long. In fact, a previous time that a Concorde hit debris and punctured the fuel tanks, the aircraft managed to survive without crashing. That is probably the true wonderment. -john- SMALL piece of FOD? Or a big chunk? Whatever, it shouldn't have been there. It shouldn't have been there in the sense that even in the real world airplanes aren't supposed to shed small pieces of themselves, or in the sense that this is just a bad thing? In the first case, the idea that a piece of metal might have been on the ground was not only wrong, but unforseeable. I've yet to hear anybody say that this is the case, and that there's no realistic way that such bits of metal would find their way onto a runway - therefore, regardless of the misconduct (if it was misconduct) of the flight that left the offending piece of scrap, the possibility of such scrap would appear in a spot that would threaten Concorde was forseeable and should have been a design consideration. |
Mike Lindsay wrote: SMALL piece of FOD? Or a big chunk? Whatever, it shouldn't have been there. You still miss the point. It doesn't matter if it should or should not have been there--sooner or later, there is going to be FOD on the runway or ramp. If you could make a rule that prohibited FOD, then the USAF wouldn't have to do a FOD walk every morning at each of the US airbases. The fact is that you have to design for FOD, or you crash and burn, just like the Concorde did. In comparison, one F-15 lost half a wing, and an A-10 came back with a missile lodged in the wing, and both planes lived to fly again. That is the difference. As it turns out, for many years, the Concorde flew with an on-board FOD generator in the form of the main landing gear. Time after time the tires would shred on take off or landing, and spray debris all over the bottom of the aircraft and all over the runway. It wasn't supposed to happen, but it did. At least until a better tire design was made available. -john- -- ================================================== ==================== John A. Weeks III 952-432-2708 Newave Communications http://www.johnweeks.com ================================================== ==================== |
![]() "Mike Lindsay" wrote in message ... SMALL piece of FOD? Or a big chunk? Whatever, it shouldn't have been there. -- Mike Lindsay Frankly that doesnt matter. No single failure should result in the loss of an aircraft and the FOD simply burst a tyre, something that is always a possibility. It was the tyre fragments that punctured the wing tank and the armouring of the tank that removed the hazard wasnt exactly rocket science. Keith |
Concorde - join the campaign | Clive | General Aviation | 30 | July 23rd 06 12:15 AM |
Concorde - join the campaign | LWG | Naval Aviation | 0 | June 9th 06 09:06 PM |
Concorde - join the campaign | Derek Copeland | Soaring | 0 | June 6th 06 05:59 PM |
Concorde - join the campaign | Jim Carter | Owning | 0 | June 6th 06 03:28 AM |
Concorde - join the campaign | Jim | Naval Aviation | 2 | June 3rd 06 10:27 PM |
