I am based in El Monte (KEMT). I notice in Los Angeles area, the
effective period is from Oct. 1 to Feb. 29. I know the only sure way is to test before fill up. But does that mean no ethanol need to be added from March 1 to Sept. 29? M wrote: BTW due to the phase out of MTBE, these days chances are pretty good that ethanol is ONLY found in areas where oxygenated gasoline is required, or in states where ethanol is mandated in gasoline. The reason is supply and demand. Since the phase out of MTBE began this year there's a big shortage of ethanol that drove up the already subsidized ethanol price to something like 50c above wholesale gasonline price. It'll be hard to image any oil company blending ethanol into gasoline in aeras where ethanol isn't absolutely mandated. M wrote: http://www.eia.doe.gov/emeu/steo/pub/special/oxy2.html shows the areas that require oxygenated gasoline, which means ethanol these days. It's a bit hard to decipher because some areas listed in table 1 are now exempt according to table 3. However this is NOT a complete list. You better test your fuel using the simple method described on Petersen's website. noname wrote: I just moved to cincinnati and curious about the status of ethanol in the autofuel in the area. Is there a web site that shows what cities and/or counties that have ethanol in their autofuel? Are there any airports in the Cincinnati area that sells autofuel? Thanks Dave |
![]() As far as EPA is concerned that's true. However the state of California might have additional ethanol blending requirements. You can easily test this at a local pump next time you gas up your car. wrote: I am based in El Monte (KEMT). I notice in Los Angeles area, the effective period is from Oct. 1 to Feb. 29. I know the only sure way is to test before fill up. But does that mean no ethanol need to be added from March 1 to Sept. 29? |
