Scottish Glider Crash
Old July 13th 06, 07:16 AM posted to rec.aviation.soaring
bumper
Default Scottish Glider Crash
I'm sure most are already aware, the "standard" 121.5 / 243 Mhz ELT will no
longer trigger SARSAT / COPAS after 2008. So when we are talking PLB's, they
are 406 MHz and some have built in GPS too. For a comparison, see:
http://www.sarsat.noaa.gov/406vs121.pdf
bumper
"COLIN LAMB" wrote in message
ink.net...
Although I fly with an ELT, they are not a guarantee that the aircraft
will be found because of it.
I am a member of a Search and Rescue team and have been involved with the
finding of a number of downed aircraft. The two cases where the ELT
survived the crash was where the crash was next to the airport, and were
not needed.
In the fatal air crashes I have been at, the ELT was destroyed and the
aircraft was only found with old fashioned search techniques. In one
case, the largest piece of the ELT was the size of a quarter.
If you are going to install an ELT, and expect it to survive a crash, it
must be installed so that it will survive, remembering that the antenna,
the feedline and the mounting are all part of the critical installation.
Just as important as the ELT is to let someone know where you are.
Regular communication during a flight with someone to update on your
location and intended flight path can be critical.
The chance of finding someone lost is greatly improved if the searchers
know where to start looking. If they do not have that information, it is
like looking for a needle in a haystack.
Colin
Old July 13th 06, 06:22 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Relatively recently I was in a position where an ELT could have helped a
lot. As a consequence, I did a serious 'net search last year for
information about the use and purchase of ELTs in the UK. I found two
sources of 243/121.5 MHz ELTs here and nothing at all on 406 MHz ELTs
intended for aviation use.
Now, I've read that the 2008 change over to 406 MHz ELTs is intended to
be world-wide so I'm a bit perturbed by the lack of information or
devices in the UK. If the changeover affects the UK, I'm rather
unwilling to buy a 243 MHz system that will be phased out in a year.
Has anybody heard anything definite about a 406 MHz change-over in the UK?
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old July 14th 06, 01:42 PM posted to rec.aviation.soaring
COLIN LAMB
"Now, I've read that the 2008 change over to 406 MHz ELTs is intended to
Has anybody heard anything definite about a 406 MHz change-over in the UK?"
The changeover, in effect, will be worldwide. That is because the
satellites that locate the 121.5 beacon and report approximate locations
will shut down. This is the main thrust of the change. The 406 MHz signals
may or may not have gps tied in.
However, the newer beacons will continue to have a 121.5 MHz beacon for
ground searchers to locate the device. It will be lower power, however.
The older beacons will not be declared illegal and still can be used for
radiolocation - however no satellite coverage. In flat terrain, the older
ELTs might still be useful - as long as someone is looking in the general
area. Passing aircraft will still be able to hear your beacon.
Last time I looked, I found no mention of the 243 MHz signal requirement on
the new beacons, so I expect that is going away. I think that was based
upon military requirements and that has gone away.
Colin
Old July 15th 06, 01:11 AM posted to rec.aviation.soaring
Thanks for the confirmation, but who is selling aircraft-rated 406MHz
ELTs in the UK and where can I find out how to register one?
I found references to floating, boatie type 406 MHz EPIRBs that activate
on immersion but not one with impact activation.
org |
Old July 15th 06, 07:25 PM posted to rec.aviation.soaring
The Minden Soaring Club webpage recently published an article written
by Pepe Gresa, from Spain, on the exactly this subject matter:
http://mindensoaringclub.com/int2/in...=73&Itemi d=5
The article is informative, and stresses the fact that ELT's do save
lives...
Old July 16th 06, 04:56 PM posted to rec.aviation.soaring
lives...
That's a good article, though the Filser link emphasizes the point I was
making: both their ELTs are 121.5 and 243 MHz. No mention of 406 MHz
transmitters.
org |
Glider rating near Sacramento Robert M. Gary Piloting 19 March 8th 06 09:34 PM
Yet another A36 crash H.P. Piloting 10 April 23rd 05 05:58 PM
Power Commercial to Glider Commercial Mitty Soaring 24 March 15th 05 03:41 PM
Sport Pilot - School Won't Offer Gary G Piloting 38 February 16th 05 10:41 AM
Announce/USA: FAA Glider Flying Handbook / Bob Wander SoarBooks Soaring 0 August 11th 03 03:55 PM
