bumper wrote:
I'm sure most are already aware, the "standard" 121.5 / 243 Mhz ELT will no longer trigger SARSAT / COPAS after 2008. So when we are talking PLB's, they are 406 MHz and some have built in GPS too. For a comparison, see: Relatively recently I was in a position where an ELT could have helped a lot. As a consequence, I did a serious 'net search last year for information about the use and purchase of ELTs in the UK. I found two sources of 243/121.5 MHz ELTs here and nothing at all on 406 MHz ELTs intended for aviation use. Now, I've read that the 2008 change over to 406 MHz ELTs is intended to be world-wide so I'm a bit perturbed by the lack of information or devices in the UK. If the changeover affects the UK, I'm rather unwilling to buy a 243 MHz system that will be phased out in a year. Has anybody heard anything definite about a 406 MHz change-over in the UK? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
"Now, I've read that the 2008 change over to 406 MHz ELTs is intended to
be world-wide so I'm a bit perturbed by the lack of information or devices in the UK. If the changeover affects the UK, I'm rather unwilling to buy a 243 MHz system that will be phased out in a year. Has anybody heard anything definite about a 406 MHz change-over in the UK?" The changeover, in effect, will be worldwide. That is because the satellites that locate the 121.5 beacon and report approximate locations will shut down. This is the main thrust of the change. The 406 MHz signals may or may not have gps tied in. However, the newer beacons will continue to have a 121.5 MHz beacon for ground searchers to locate the device. It will be lower power, however. The older beacons will not be declared illegal and still can be used for radiolocation - however no satellite coverage. In flat terrain, the older ELTs might still be useful - as long as someone is looking in the general area. Passing aircraft will still be able to hear your beacon. Last time I looked, I found no mention of the 243 MHz signal requirement on the new beacons, so I expect that is going away. I think that was based upon military requirements and that has gone away. Colin |
COLIN LAMB wrote:
"Now, I've read that the 2008 change over to 406 MHz ELTs is intended to be world-wide so I'm a bit perturbed by the lack of information or devices in the UK. If the changeover affects the UK, I'm rather unwilling to buy a 243 MHz system that will be phased out in a year. Has anybody heard anything definite about a 406 MHz change-over in the UK?" The changeover, in effect, will be worldwide. That is because the satellites that locate the 121.5 beacon and report approximate locations will shut down. This is the main thrust of the change. The 406 MHz signals may or may not have gps tied in. However, the newer beacons will continue to have a 121.5 MHz beacon for ground searchers to locate the device. It will be lower power, however. The older beacons will not be declared illegal and still can be used for radiolocation - however no satellite coverage. In flat terrain, the older ELTs might still be useful - as long as someone is looking in the general area. Passing aircraft will still be able to hear your beacon. Last time I looked, I found no mention of the 243 MHz signal requirement on the new beacons, so I expect that is going away. I think that was based upon military requirements and that has gone away. Thanks for the confirmation, but who is selling aircraft-rated 406MHz ELTs in the UK and where can I find out how to register one? I found references to floating, boatie type 406 MHz EPIRBs that activate on immersion but not one with impact activation. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
The Minden Soaring Club webpage recently published an article written
by Pepe Gresa, from Spain, on the exactly this subject matter: http://mindensoaringclub.com/int2/in...=73&Itemi d=5 The article is informative, and stresses the fact that ELT's do save lives... |
Glider rating near Sacramento | Robert M. Gary | Piloting | 19 | March 8th 06 09:34 PM |
Yet another A36 crash | H.P. | Piloting | 10 | April 23rd 05 05:58 PM |
Power Commercial to Glider Commercial | Mitty | Soaring | 24 | March 15th 05 03:41 PM |
Sport Pilot - School Won't Offer | Gary G | Piloting | 38 | February 16th 05 10:41 AM |
Announce/USA: FAA Glider Flying Handbook / Bob Wander | SoarBooks | Soaring | 0 | August 11th 03 03:55 PM |
