FM radio interference from planes
Old July 14th 06, 10:54 PM posted to rec.aviation.piloting
RST Engineering
Default FM radio interference from planes
Macklin, I like you, you are a nice guy. But sometimes you give advice that
is way the hell out of your depth. Like this one.
"Jim Macklin" wrote in message
news:AVTtg.67782$ZW3.26133@dukeread04...
104.1 FM is below the aircraft navigation and below the
communication assigned frequencies. But there are harmonic
signals that you cheap FM transmitter is not screening out.
Are you using a wired connection from the PC to the FM
transmitter or a WiFi or other radio? Most likely you're
getting the interference in that way.
You may be in violation of FCC rules.
Probably not, with a store-boughten transmitter. And harmonics (which are
integral multiples of a fundamental signal) probably have little to do with
it.
Consider the most probable cause. An FM receiver at 104.1 has a local
oscillator at 114.8 MHz to produce an IF of 10.7 MHz. Not only will that
beat with 104.1 on the low side of the LO, it will beat with 125.5 on the
high side. Most FM receivers have at least a +/- 50 kHz. wide IF strip to
allow the stereo subcarrier at 38 kHz. to come through, so 125.45, 125.5,
and 125.55 will come through as well.
The OP said that he doesn't get any interference when his transmitter is
off, so my best place to start looking is the front end of the receiver,
where the normal filtering of any decent FM receiver should take care of the
"image" problem. However, when a very strong signal (like from a 100 mW
legal transmitter) comes blowing into the front end of the receiver from a
few feet away, crossmod and intermod are NOT your friend, and no designer in
this world can make a brick wall filter that will take care of it.
Having said all that, the real problem is to keep whatever small amount of
aircraft band com energy is present at the front end from getting into the
receiver.
And, before we start off on a wild goose chase, I'd advise the OP to get a
small handheld aircraft band transceiver or scanner and see if the real
transmitter is somewhere around 125.5 MHz.. It is always good to be able to
do a math calculation to see exactly what is getting into what before
spending a lot of time chasing your tail.
For those who say "you can't hear AM on an FM receiver", I say
horsefeathers. It may be reduced in volume, it may be distorted, but it
will get through.
Do the test, tell me what frequency from 118-136.975 MHz. the aircraft is
on, and we'll go from there.
Old July 15th 06, 12:35 AM posted to rec.aviation.piloting
Jim Macklin
What did I say that was wrong [other than the typo you
should have been your]. The comment about FCC rules...they
do frown on transmitting or retransmitting the wrong
signals.
BTW, back in the 1974 period I gave a student a night dual
x-c from Tulsa to OKC and back one night. We picked up
several TV stations on the old AM radios in the C150 we were
flying. So bad radios, that do not have properly working
filters and signal rejection can do strange things.
We also had fun with CB radios in our cars back in the late
60's, parking outside a church or at the drive-in movie and
being able to have our comments come over the PA system.
Poor shielding let our 5 W CB radio get into their amp.
Some times you give criticism that isn't helpful. In my old
age, I do make misteaks [mistakes] and often brake rules
[break] because I sometimes remember the wrong bit of
information. And sometimes I'm right [correct] by accident.
mine..."| "Jim Macklin"
harmonic
| signals that you[r] cheap FM transmitter is not
screening out.
you're
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
some support
http://www.usdoj.gov/olc/secondamendment2.htm
See http://www.fija.org/ more about your rights and duties.
"RST Engineering" wrote in message
| "Jim Macklin" wrote
in message
harmonic
out.
you're
little to do with
| it.
has a local
only will that
with 125.5 on the
wide IF strip to
125.45, 125.5,
transmitter is
the receiver,
from a 100 mW
receiver from a
and no designer in
care of it.
small amount of
getting into the
| receiver.
the OP to get a
see if the real
good to be able to
what before
say
distorted, but it
| will get through.
the aircraft is
| Jim
Old July 15th 06, 02:41 AM posted to rec.aviation.piloting
Michael Ware
news:CSVtg.68473$ZW3.64903@dukeread04...
signals.
*snip*
| Jim
He isn't transmitting anything on the wrong freq, he is receiving signals
that are originating from a freq outside the supposed range of the FM system
he bought.
That system he is using is undoubtedly a 'PART 15' device, with a label or
literature reading:
"This device complies with part 15 of the FCC Rules. Operation is subject
to the following two conditions: (1) This device may not cause harmful
interference, and (2) this device must accept any lnterference re-
ceived, including interference that may cause undesired operation."
So he can either live with it, find a HAM to build a filter, or take it back
and get something else.
Old July 15th 06, 11:40 PM posted to rec.aviation.piloting
Matt Barrow[_2_]
signals.
Forget it, Jim; the other Jim is exercising his depleted ego again.
Old July 15th 06, 12:39 AM posted to rec.aviation.piloting
Larry Dighera
On Fri, 14 Jul 2006 14:54:56 -0700, "RST Engineering"
wrote in
So, you're saying, that although the aviation AM radio energy is not
being transmitted by the local MP3 FM transmitter, the receiver's
front (RF amplifier) is so overwhelmed by the local MP3 FM
transmitter's signal, that it enables aviation AM radio energy to
directly enter the receiver through cross-modulation and
inter-modulation? Did I understand you correctly?
Isn't there also a possibility that nearby aviation AM radio energy is
entering the local MP3 FM transmitter through the power lines (or
transmitting antenna), and causing it to retransmit that aviation
content in addition to the MP3 content?
Old July 15th 06, 01:01 AM posted to rec.aviation.piloting
RST Engineering
"Larry Dighera" wrote in message
wrote in
in
I noted that as the most probable to me given the data presented. We could
postulate several wild and hairy schemes of harmonic mixing, but the most
likely suspect is inter or cross mod. The front end is not overwhelmed; it
is getting about the same amount of input that a commercial station in town
would present to the antenna, and the result SHOULD be the same. You can't
bias an amplifier to run ultralinear across a wide range of input voltages.
Not likely. Unless a very good case can be made, aviation ground stations
(tower, ground, atc) are limited to 25 watts carrier out. The ground
station would have to be literally in the OP's back yard to get into the
audio circuitry of the transmitter. As for "through the power lines", most
of these little transmitters are powered by wall warts that do a pretty fair
job of isolating line from equipment. One way of proving this to yourself
is to power the unit from a 9 volt battery and see if you get the same
result(s).
Old July 15th 06, 02:34 AM posted to rec.aviation.piloting
Don Tuite
Have we established that the audio from the am source is not being
generated in the PC?
Is the OP using line-out or headphone audio to drive the Part-15
device? If the latter, where is the PC headphone volume set?
Don (Another oar to muddy the water)
Old July 15th 06, 03:59 AM posted to rec.aviation.piloting
Nathan Young
The OP is in California bay area. Oakland Center in that area is
125.45. Southwest Airline flies to SJC, so it all makes sense...
Case solved.
-Nathan
Old July 15th 06, 04:12 PM posted to rec.aviation.piloting
RST Engineering
OK, so we think we have a possible reason for the interference. Now, if the
OP will please describe for me what sort of antenna (s)he has on the
RECEIVER, I'll make a best guess as to how to mitigate the problem.
And no, in response to another post, if a device certified to part 15 and
still meeting part 15 standards interferes with another part 15 device,
neither interferer nor interferee is responsible for cleaning up any
interference. Or, in English, if my little transmitter is screwing up your
little receiver, I ain't gotta do nothing about it.
As for selling knock-off unlicensed transmitters, last I looked nobody in
their right minds is going to expose themselves to a $10K fine for each
device so sold. I defy anybody to go into a store anywhere in this country
and buy a little FM transmitter (they sell them in K-Mart and WallyWorld)
without a certification sticker on them and the FCC type cert number.
Case solved.
-Nathan
Old July 15th 06, 12:31 PM posted to rec.aviation.piloting
Denny
that
to
125.5,
Jim, you are preaching in Sanscrit... Unless they are ham radio ops, or
have a degree in EE, they won't even begin to comprehend..
0: this is what cheap radio equipment gets you
1: his receiver receives many, many radio frequencies, not just the one
it is tuned for
2: his 'transmitter' is radiating RF on more frequencies than 104.1
3: his receiver is actually radiating RF into the receiver antenna and
broadcasting
4. the combination of RF from the transmitter mixing with the many RF
signals present on the receiver's antenna terminals cause "phantom"
signals to be heard
To cure this he needs to put a filter on the transmitter output and one
on the receiver input... Or simply turn the FM transmitter off...
denny
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 09:10 PM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Owning 77 December 3rd 03 09:10 PM
Radio Interference Information Ross Richardson Piloting 0 October 17th 03 02:06 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
