![]() "Larry Dighera" wrote in message ... On Fri, 14 Jul 2006 14:54:56 -0700, "RST Engineering" wrote in :: The OP said that he doesn't get any interference when his transmitter is off, so my best place to start looking is the front end of the receiver, where the normal filtering of any decent FM receiver should take care of the "image" problem. However, when a very strong signal (like from a 100 mW legal transmitter) comes blowing into the front end of the receiver from a few feet away, crossmod and intermod are NOT your friend, and no designer in this world can make a brick wall filter that will take care of it. So, you're saying, that although the aviation AM radio energy is not being transmitted by the local MP3 FM transmitter, the receiver's front (RF amplifier) is so overwhelmed by the local MP3 FM transmitter's signal, that it enables aviation AM radio energy to directly enter the receiver through cross-modulation and inter-modulation? Did I understand you correctly? I noted that as the most probable to me given the data presented. We could postulate several wild and hairy schemes of harmonic mixing, but the most likely suspect is inter or cross mod. The front end is not overwhelmed; it is getting about the same amount of input that a commercial station in town would present to the antenna, and the result SHOULD be the same. You can't bias an amplifier to run ultralinear across a wide range of input voltages. Isn't there also a possibility that nearby aviation AM radio energy is entering the local MP3 FM transmitter through the power lines (or transmitting antenna), and causing it to retransmit that aviation content in addition to the MP3 content? Not likely. Unless a very good case can be made, aviation ground stations (tower, ground, atc) are limited to 25 watts carrier out. The ground station would have to be literally in the OP's back yard to get into the audio circuitry of the transmitter. As for "through the power lines", most of these little transmitters are powered by wall warts that do a pretty fair job of isolating line from equipment. One way of proving this to yourself is to power the unit from a 9 volt battery and see if you get the same result(s). |
Have we established that the audio from the am source is not being
generated in the PC? Is the OP using line-out or headphone audio to drive the Part-15 device? If the latter, where is the PC headphone volume set? Don (Another oar to muddy the water) |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Owning | 77 | December 3rd 03 09:10 PM |
Radio Interference Information | Ross Richardson | Piloting | 0 | October 17th 03 02:06 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
