AVIATIONTOOLBOX: automatic route selection
Old October 14th 04, 09:47 AM
Julian Scarfe
"Ben Jackson" wrote in message
news:tCmbd.121529$He1.75934@attbi_s01...
I keep meaning to apply Dijkstra's algorithm to airway routing.
The key will be choosing edge costs.
I tried something similar for Western Europe. Thinking aloud... My
algorithm was basically:
a) load the entire airway network as a graph using distances as costs
b) link airports to the network using SIDs and STARs (important in Europe,
probably less so in US)
c) add preferred routes using the a cost of
start_to_end_great_circle_distance * factor, where factor is just less than
1.
d) run Dijkstra's algorithm (I was doing this in Perl so I just used the
Graph module from CPAN) for a departure airport
e) store the least cost routing from the departure airport to everywhere
else in a database
Repeat for other departure airports of interest. Processing time for one
departure airport for my network was about 30s on a fairly typical desktop
machine. YMMV, literally. ;-)
Provided your airway network only changes every 28 days (can't speak for the
US but that's what happens in the rest of the world for aeronautical data),
you've then got "static" routes valid for a month which means that to run
this for 100 airports or so, it should be a case of "do the calculation once
and store the results".
You can do this all with appropriate costs assigned to the routes and
transitions that you want. The tricky part is weighting thoses costs
properly against whatever you consider to be overriding factors (eg
forecast winds, icing, aircraft performance, distance, available nav
equipment, ...)
Adding dynamic issues is not only difficult from a "what cost factor do I
use?" point of view, but actually affects the entire strategy. Calculating
weighted factors based on winds means that you have to do a calculation for
the entire network (you may be able to preload the network, but you still
have to run a weighting factor calc for each edge) which is likely to be
very time consuming. You then have to run Dijkstra's algorithm to get the
least-cost routes. But now we're doing that for *every* flight, which means
that we wait for both steps of the processing (edge costs + Dijkstra)
instead of doing a database lookup on stuff that's run once a month.
I wondered about a middle ground. If you could store the 10 or even 100
least-cost routes for a particular airport-pair, then running those routes
for a single flight would be relatively quick (either individually or doing
Dijkstra on the much reduced network). But Dijkstra doesn't produce the
runners up, only the winner, so how do we find the set of 10 or 100 routes
to consider? Do you knock out legs and run the algorithm again? If so,
which ones?
Reducing the network to waypoints within x miles of the great circle for a
particular flight (a little like Paul Tomblin's suggestion) is one
possibility, but, at least in Europe, x would have to be pretty big. On a 3
hour trip to Germany from my home base in the UK, I basically have the
choice between an initial route that goes east over Holland, or south and
then south east over Belgium. For a 450 mile route, I have to consider a
band of possibilities at least 150 miles wide.
Anyway, just sharing some thinking.
Julian Scarfe
Old October 14th 04, 03:08 PM
Kyler Laird
"Julian Scarfe" writes:
That was my first thought...'course it's about all I remember about
network theory...
What's the difficulty here? The airway file contains distances.
Are we not treating airways as the network edges?
1.
Hmmmm...I like that. It would allow for lots of tweaking too.
else in a database
I wasn't planning to do a lot of precomputation. When we get into altitude
restrictions it just gets too complicated. The shortest path for me from
Indiana to California is going to be much different than for someone who is
going to stay below 8,000'. Besides altitude restrictions, I can imagine
wanting to specify avoidance of MOAs, long overwater segments, busy
airspace, etc.
the entire network
Oh, yeah...winds too.
It's not clear to me that this is a terrible burden. A student
sitting in front of enroute charts can figure out reasonable solutions
so I assume I can program a computer to do the same in short order.
I think that learning to disregard edges that aren't of interest is
the key. This seems fairly simple at first but in mountainous regions
with low altitude restrictions it could get difficult because you might
need to go far away from a direct route.
This doesn't sound so bad to me. I don't have a grasp on the power
required to solve it though.
Indeed! I appreciate the thoughts!
--kyler
Old October 14th 04, 03:16 PM
Dave Butler
I always got stuck at trying to find a reasonable choice for the node at which
the enroute structure should be entered and exited. Once you pick the end points
(where to enter and leave) the choice of routes is just an OR optimization
problem, as others have noted.
Perhaps altitude requirements need to be included in the costs.
Dave
Old October 14th 04, 03:51 PM
Admin
I like the idea of running the script once a month, but for 20.00
airports this would be a quite database.
Another idea is when we have found preferred routes, also store use
routes (routes that user knows he/she will get from atc after filin
different route)... mainly for busy areas NY etc... atc's ow
prefferred routing as previously mentioned.
We will be using mapserver with this project and use mysql for db.
Php or cgi script for this would be nice
http://www.v1rotate.com
View this thread: http://www.v1rotate.com/portal/forum...?threadid=9334
Old October 14th 04, 07:50 PM
Ben Jackson
I think you can do better than that by ordering your edges better. You
know more than just edge costs, you also have coordinates for each node.
You can choose to explore edges that move you closer to the destination
first.
IIRC, the key to making Dijkstra fast is to find a solution as early as
possible. That establishes a baseline cost that allows massive pruning
of the search space.
Right. But if I'm going to do the work then I want it to calculate all
of the factors that I would, given infinite time and patience on my part.
Ben Jackson
http://www.ben.com/
Old October 15th 04, 09:11 AM
Julian Scarfe
desktop
news:rTzbd.249118$D%.142632@attbi_s51...
first.
That may be the case. I should have said that what I was trying to do was
create a server-based system for large numbers of users with different
dep-dest pairs. In that case, I'm looking at all potential destinations in
parallel. The strategy for a client-based system starting from scratch for
every single flight might be rather different.
Julian
Old October 20th 04, 03:56 PM
Jerry Kaidor
"Julian Scarfe" wrote in message ...
*** I would modify that to use a combination of distance and MEA as
the cost.
I've found that in my personal flight planning, lower MEAs often
translate into a better flight, even if they involve a bit of a
dogleg.
- Jerry Kaidor ( )
IFR route BOS - IAD? Peter MacPherson Instrument Flight Rules 2 September 4th 04 05:46 AM
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 05:12 AM
filing IFR plan for VFR flight conditions Paul Safran Instrument Flight Rules 53 May 11th 04 03:07 AM
Route planning question Paul Tomblin Instrument Flight Rules 3 April 4th 04 02:40 PM
My route to the 3rd annual ParasolAirplanes Fly In Scott Home Built 1 July 18th 03 07:28 PM
