![]() JS wrote: T o d d P a t t i s t wrote: where can I get brake shoes for a Cobra trailer? -- Make sure you get the right shoes for your trailer. When I called Rex he didn't have the vintage-1987-type so I ordered a set from Cobra. Get the instructions for adjusting the brakes. Adjusting the brakes correctly might make you believe you've changed the shoes and cut the drums. info AT cobratrailer DOT de And, while you're down there... Everybody should have the newer "beer friendly" plastic fenders (mud guards) with the flat spot on top. Rex has those complete with black wheel chocks that take UV exposure better than white ones. I took my old shoes to a brake shop in Pomona Ca and had them relined it can be done as long as you haven't let them get into the steel and have the drums turned at the same time. Price for 4 shoes & 2 drums turned $40. LED lights can be bought at any big truck trailer supply such as Utility or Trailmobile. Tail , brake & turn on my glass top cobra work and look great, but I had to take a flapper wheel on a die grinder and enlarge the holes out to 4". Side marker lights I used are (and tails) Maxima brand didn't even have to drill new screw holes bolted right on and took 30 min to do all 4. |
Help - Cobra Trailer Trim? | WDM | Soaring | 2 | January 12th 05 07:47 PM |
Cobra Trailer Hookup | [email protected] | Soaring | 12 | January 12th 05 03:08 PM |
COBRA Skin Trailer Protector - Commercial | John Seaborn | Soaring | 0 | July 20th 04 04:38 PM |
Cobra Trailer Axel Replacement | Carter | Soaring | 7 | July 7th 04 02:06 PM |
Cobra trailer fittings for different glider makes & models | John W | Soaring | 4 | September 24th 03 03:21 PM |
