I installed Maxxima LED replacement brake/turn/tail lights as well as a
high, fin mounted 3rd brake light on my Cobra. For the fin, it is important to fabricate a wedge of some sort (I used white plastic) to get the LED perpendicular to the ground, as the beam angle is narrower than with incandescent lighting. For the 3rd brake light "logic", I used a relay, with the coil being driven off one brake/turn and the NO contact on the relay being driven by the other brake turn. That way the fin brake light is only on when both L & R brake lights are on. I used all flush mount lights with rubber grommets. Also mounted LED aux turn signals on the side of the trailer on the upper clam just above the existing running lights, amber mid-ship and red at the rear. -- bumper ZZ (reverse all after @) "Dare to be different . . . circle in sink." "chipsoars" wrote in message oups.com... Anyone know where I can get the weatherstripping seal on the bottom half of the trailer. This is what the clamshell closes against. Also, has anyone replace lights with LED's and mounted a high center stop light? What bulbs are in the tail lens? Chip F. |
Help - Cobra Trailer Trim? | WDM | Soaring | 2 | January 12th 05 07:47 PM |
Cobra Trailer Hookup | [email protected] | Soaring | 12 | January 12th 05 03:08 PM |
COBRA Skin Trailer Protector - Commercial | John Seaborn | Soaring | 0 | July 20th 04 04:38 PM |
Cobra Trailer Axel Replacement | Carter | Soaring | 7 | July 7th 04 02:06 PM |
Cobra trailer fittings for different glider makes & models | John W | Soaring | 4 | September 24th 03 03:21 PM |
