"Brenor Brophy" wrote
Here is a link to a very good article on autopilots on the Avionics West web page. I think it answers a lot of your questions. http://avionicswest.com/articles/kno..._autopilot.htm That's not a bad article. I do have some issues with it. First off, it ignores the most important difference between rate-based and attitude-based autopilot - performance in turbulence in a slick airplane. Attitude-based autopilots (those that use pickoffs on the horizon gyro) work all the time. Rate-based autopilots (those that use pickoffs on the turn coordinator) work in smooth air or with light, draggy airplanes. In a heavier slicker airplane, especially a twin, turbulence makes for a very uncomfortable ride because all the corrections are too much too late. There are NO rate-based autopilots in the transport category - they just wouldn't work. The whole system failure issue is more complex that it seems. The reality is that ALL autopilots built for GA use can roll you over in a heartbeat - every one of them without exception. Vacuum failure is only one mechanism for this - it causes the gyro to provide incorrect bank information. Here are some others: Bad connection. Really. A bad conenction to the attitude indicator (AI) or turn coordinator (TC) means the system has no idea what the bank angle or rate of turn is - but it thinks it does. Over you go. Bad brushes/dirt. A TC with bad brushes can come to a halt - and not flag out. An AI with dirt/water sucked in can stop spinning or go nuts because of the pendulous vanes - and not flag out. Warning flags on GA gyros are near-useless - they monitor only the power source, not actual rotation. Electronic failures - there is lots of circuitry required to read that AI or TC. Any of it can fail. Over you go. Bad computer. The modern autopilots are computer based. The sytem crashes, and over you go. The bottom line is that with any GA autopilot system, you as the pilot must continuously and carefully monitor whichever gyro(s) the autopilot is NOT using. The autopilot is only a way for you to take your hands off the controls, not a way to stop the scan. Michael |
![]() "Michael" wrote in message om... http://avionicswest.com/articles/kno..._autopilot.htm That's not a bad article. I do have some issues with it. First off, it ignores the most important difference between rate-based and attitude-based autopilot - performance in turbulence in a slick airplane. Attitude-based autopilots (those that use pickoffs on the horizon gyro) work all the time. Rate-based autopilots (those that use pickoffs on the turn coordinator) work in smooth air or with light, draggy airplanes. In a heavier slicker airplane, especially a twin, turbulence makes for a very uncomfortable ride because all the corrections are too much too late. There are NO rate-based autopilots in the transport category - they just wouldn't work. You might want to take a gander at this article. I'm not sure what you mean by slow corrections, but evidently S-TEC (taken with a grain of salt) has optimized the corrections, as well as smoothed them to avoid overstressing the aircraft in turbulence. See Pages 6 & 7. http://www.s-tec.com/pdf/autopilotbook.pdf Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
Matt,
You might want to take a gander at this article. I'm not sure what you mean by slow corrections, but evidently S-TEC (taken with a grain of salt) has optimized the corrections, as well as smoothed them to avoid overstressing the aircraft in turbulence. See Pages 6 & 7. http://www.s-tec.com/pdf/autopilotbook.pdf ....but the S-Tec related Meggit line of products just offerd an autopilot aimed at the multi/turboprop market, and it's attitude(position) based. Seems the realized that a rate-based auto is not on par with the airplane when installed in, e.g, a fast single-engine turboprop, just as Michael said. Regards Kai |
Honeywell KFC-225 autopilot - what could cause this failure? | Joerg | Instrument Flight Rules | 17 | June 16th 04 10:05 AM |
Ramifications of Cherokee Trim Jackcrew Failure | Bob Chilcoat | Home Built | 23 | June 9th 04 02:48 AM |
Tail flapper failure | Veeduber | Home Built | 2 | May 22nd 04 06:52 AM |
Ham sandwich navigation and radar failure | David Brooks | Instrument Flight Rules | 47 | December 31st 03 12:15 AM |
Interesting Flybaby wing failure analysis... | Richard Lamb | Home Built | 3 | August 27th 03 05:21 PM |
