DUAT preferred routes vs. Jepp
Old July 4th 06, 01:27 AM posted to rec.aviation.ifr
Andrew Gideon
Default DUAT preferred routes vs. Jepp
Planning a flight from CDW to CQX, I found in Jepp one route: BREZY V39
CMK V3 HFD V167 PVD V151 GAILS.
DUAT offers another: FALLZ V3 JEWIT V167 PEAKE
Am I likely to get the DUAL routing if I request it? I'm surprised that
it would yield something different from Jepp. Admittedly, it's not
much different but at the ends. And the Jepp route would be easier to
enter into a GNS 430 (though the DUAT route would be easy for the 480).
But why any difference?
- Andrew
Old July 13th 06, 09:33 PM posted to rec.aviation.ifr
Marco Leon
Are you comparing the DUAT route you get from their Flight Planner
function versus the preferred routes listed in the Jepp chart pages?
The Jepp preferred routes should be the same as the FAA Preferred
routes but in a nicer format. Check out this FAA website:
http://www.fly.faa.gov/Products/Code..._database.html
Marco
- Andrew
Old July 19th 06, 08:59 AM posted to rec.aviation.ifr
I'm not sure about it but here's my guess: The Jepp routes are
"preferred routes" put together by ATC that take into account traffic
flows. DUAT, however, is independent of ATC and makes up some
reasonable route, where "reasonable" was decided by the people who
wrote the comptuer algorithm that comes up with routes.
- Andrew
Old August 7th 06, 09:34 PM posted to rec.aviation.ifr
Andrew Gideon
Yes.
The Jepp preferred routes should be the same as the FAA Preferred routes
When I'm with my flight gear, I'll have to see how this compares to DUATS
and Jepps.
Thanks...
Andrew
LA Basin Preferred Routes? Dane Spearing Instrument Flight Rules 4 May 22nd 06 07:27 PM
Preferred routes to Canada wan2fly99 Instrument Flight Rules 2 March 22nd 06 02:12 AM
Preferred Routes Stan Gosnell Instrument Flight Rules 1 December 5th 05 03:22 PM
Military Slow Routes R22AV8R Rotorcraft 0 April 17th 04 01:51 AM
Preferred Routes on the net Roy Smith General Aviation 2 March 15th 04 12:32 AM
