Morgans wrote
I'll bet he is not going to wear a parachute, either, which is required. Where does it say that? The answer to rolling a normal category plane should be no, always. The C-172 that I fly is a Utility Category airplane, if I want it to be. Bob Moore ATP CFI |
Utility category allows some limited acro maneuvers, and a
list of approved maneuvers is on the placard on the side wall of the cabin and in the POH. If you want to do rolls, snap rolls, etc, rent or buy an airplane designed and tested and certified as such. Can the 172 do acro, sure, with Bob Hoover doing the flying. Can some ham handed 100 private pilot do it with out falling out of the roll, and pulling 9 Gs in the recovery? Probably not. Parachutes are required when you exceed certain attitudes, the mental attitude being the most important. § 91.303 Aerobatic flight. No person may operate an aircraft in aerobatic flight- (a) Over any congested area of a city, town, or settlement; (b) Over an open air assembly of persons; (c) Within the lateral boundaries of the surface areas of Class B, Class C, Class D, or Class E airspace designated for an airport; (d) Within 4 nautical miles of the center line of any Federal airway; (e) Below an altitude of 1,500 feet above the surface; or (f) When flight visibility is less than 3 statute miles. For the purposes of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an aircraft's attitude, an abnormal attitude, or abnormal acceleration, not necessary for normal flight. [Doc. No. 18834, 54 FR 34308, Aug. 18, 1989, as amended by Amdt. 91-227, 56 FR 65661, Dec. 17, 1991] § 91.307 Parachutes and parachuting. (a) No pilot of a civil aircraft may allow a parachute that is available for emergency use to be carried in that aircraft unless it is an approved type and- (1) If a chair type (canopy in back), it has been packed by a certificated and appropriately rated parachute rigger within the preceding 120 days; or (2) If any other type, it has been packed by a certificated and appropriately rated parachute rigger- (i) Within the preceding 120 days, if its canopy, shrouds, and harness are composed exclusively of nylon, rayon, or other similar synthetic fiber or materials that are substantially resistant to damage from mold, mildew, or other fungi and other rotting agents propagated in a moist environment; or (ii) Within the preceding 60 days, if any part of the parachute is composed of silk, pongee, or other natural fiber, or materials not specified in paragraph (a)(2)(i) of this section. (b) Except in an emergency, no pilot in command may allow, and no person may conduct, a parachute operation from an aircraft within the United States except in accordance with part 105 of this chapter. (c) Unless each occupant of the aircraft is wearing an approved parachute, no pilot of a civil aircraft carrying any person (other than a crewmember) may execute any intentional maneuver that exceeds- (1) A bank of 60 degrees relative to the horizon; or (2) A nose-up or nose-down attitude of 30 degrees relative to the horizon. (d) Paragraph (c) of this section does not apply to- (1) Flight tests for pilot certification or rating; or (2) Spins and other flight maneuvers required by the regulations for any certificate or rating when given by- (i) A certificated flight instructor; or (ii) An airline transport pilot instructing in accordance with §61.67 of this chapter. (e) For the purposes of this section, approved parachute means- (1) A parachute manufactured under a type certificate or a technical standard order (C-23 series); or (2) A personnel-carrying military parachute identified by an NAF, AAF, or AN drawing number, an AAF order number, or any other military designation or specification number. [Doc. No. 18334, 54 FR 34308, Aug. 18, 1989, as amended by Amdt. 91-255, 62 FR 68137, Dec. 30, 1997; Amdt. 91-268, 66 FR 23553, May 9, 2001] -- James H. Macklin ATP,CFI,A&P "Bob Moore" wrote in message . 122... | Morgans wrote | I'll bet he is not going to wear a parachute, either, which is | required. | | Where does it say that? | | The answer to rolling a normal category plane should be no, always. | | The C-172 that I fly is a Utility Category airplane, if I want it to be. | | Bob Moore | ATP CFI |
In article kMMvg.78923$ZW3.78738@dukeread04,
"Jim Macklin" wrote: Parachutes are required when you exceed certain attitudes, the mental attitude being the most important. Read it again. Parachutes are not required if you're solo. |
Then why a C172 with 4 seats. Fools always carry a witness.
"Dale" wrote in message ... | In article kMMvg.78923$ZW3.78738@dukeread04, | "Jim Macklin" wrote: | | | Parachutes are required when you exceed certain attitudes, | the mental attitude being the most important. | | Read it again. Parachutes are not required if you're solo. |
Jim Macklin wrote:
Then why a C172 with 4 seats. Fools always carry a witness. The most dangerous incidents in aviation are often proceded by "Watch this." |
That would be, "Hey, y'all, hold my beer and watch this."
Jim The most dangerous incidents in aviation are often proceded by "Watch this." |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 04 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | July 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | June 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 08:27 AM |
