Plus if your logs show 5000 hours in your aircraft the feds can always
ask to look at the aircraft log books. If its in a rental aircraft the FBO will certainly have logs of it. It would probably be easy to overstate things by 10% but it wouldn't buy you enough to risk it. Overstating more than that would start to get easier to check. There is the famous story (or legend) of a guy shownig up for his multi-ATP ride with lots of multiengine time. The examiner looks through his log book and see the N number for the multi-engine plane is that same as the plane parked on the ramp, which just happens to be owned by the examiner! -Robert Dave Doe wrote: In article , says... I'm surprised. I never knew how it all worked. That leaves the whole 'minimum number of hours required' thing a bit open to fudging doesn't it? Crash Lander Yes. I have a flight that I never logged - and probably never will. I have my reasons. However logging extra hours - well - while you're doing your training, you'll be doing so presumably with the one organisation. So this is easily cross-checked (as well as very foolhardy IMO). Indeed it will be the only easy way to rebuild your logbook if you lose it. -- Duncan |
![]() Robert M. Gary wrote: Plus if your logs show 5000 hours in your aircraft the feds can always ask to look at the aircraft log books. If its in a rental aircraft the FBO will certainly have logs of it. Not without one hell of a lot legwork. If I claim to have rented planes all over the country the FAA will have a lot of work to do to prove I didn't. |
![]() Newps wrote: Robert M. Gary wrote: Plus if your logs show 5000 hours in your aircraft the feds can always ask to look at the aircraft log books. If its in a rental aircraft the FBO will certainly have logs of it. Not without one hell of a lot legwork. If I claim to have rented planes all over the country the FAA will have a lot of work to do to prove I didn't. But if the FAA suspected you had inflated your log book you can bet they would. In fact there have been several scandals in which the FAA has done just that. -Robert |
Yea.........The one I remember most is where the FAA inspectors were handing
out type ratings to each other. Karl "Curator" N185KG "Robert M. Gary" wrote in message oups.com... Newps wrote: Robert M. Gary wrote: Plus if your logs show 5000 hours in your aircraft the feds can always ask to look at the aircraft log books. If its in a rental aircraft the FBO will certainly have logs of it. Not without one hell of a lot legwork. If I claim to have rented planes all over the country the FAA will have a lot of work to do to prove I didn't. But if the FAA suspected you had inflated your log book you can bet they would. In fact there have been several scandals in which the FAA has done just that. -Robert |
The Korean war vet who did not convert his military flying
to a FAA commercial, but got a pad of temp certificates and wrote himself a commercial and when it was time to become captain, wrote himself an ATP. They finally caught him. "karl gruber" wrote in message ... | Yea.........The one I remember most is where the FAA inspectors were handing | out type ratings to each other. | | Karl | "Curator" N185KG | | | "Robert M. Gary" wrote in message | oups.com... | | Newps wrote: | Robert M. Gary wrote: | | Plus if your logs show 5000 hours in your aircraft the feds can always | ask to look at the aircraft log books. If its in a rental aircraft the | FBO will certainly have logs of it. | | Not without one hell of a lot legwork. If I claim to have rented planes | all over the country the FAA will have a lot of work to do to prove I | didn't. | | But if the FAA suspected you had inflated your log book you can bet | they would. In fact there have been several scandals in which the FAA | has done just that. | -Robert | | | |
Isn't it up to you to prove you did? Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
![]() Jose wrote: If I claim to have rented planes all over the country the FAA will have a lot of work to do to prove I didn't. Isn't it up to you to prove you did? I did, it's in the logbook. Somebody else is the one suggesting the times are fake. They are responsible for proving me wrong. |
I did, it's in the logbook. No, what's in the logbook is your statement, nothing more. It's a claim, not proof. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
"Jose" wrote in message
. com... Isn't it up to you to prove you did? I did, it's in the logbook. No, what's in the logbook is your statement, nothing more. It's a claim, not proof. It is the legally required documentation, however. You are confusing scientific proof (which requires complete, flawless documentation) with legal proof (which requires only that one comply with the legal requirements). There's no way the FAA can expect a pilot to be able to provide independent documentation of every single flight hour in their logbook. Just as an example: I am now on my third Hobbs meter in my airplane. The previous two have since been destroyed (thrown away). There is no paper trail, other than my mechanic's say-so, that the meter was replaced at the time claimed in the logbook. And other than the Hobbs meter, there is absolutely no documentation of actual hours flown in my airplane (for that matter, even if I had the original Hobbs meter, I could easily just activate it and let it run without bothering to fly). The closest thing that one might come to additional documentation is fuel purchase records but a) I don't keep those records, b) I doubt the credit card companies keep those records indefinitely, c) not all of my fuel purchases were even made with a credit card, and d) even if the records were available, they are impossible to translate directly and accurately into flight hours. There are plenty of other examples of "no paper trail" flight hours, and the pilot's inability to provide that paper trail is NOT grounds for the FAA taking action against the pilot. To make their case stick, they would have to demonstrate positively that flight hours recorded in the logbook were not flown. Which they do. The thought that the FAA wouldn't do the legwork required to examine each and every hour of a logbook of a pilot they suspected of cheating is silly. That's the examiner's job, and if they have good reason to believe they are logging fake hours, they're going to do that legwork. If for no other reason than to prove themselves right. Pete |
Stupid Americans! -- Stupid... Stupid... STUPID!!! _____________---_ unakm | Aardvark J. Bandersnatch, MP | General Aviation | 2 | December 17th 04 11:37 PM |
Stupid Americans! -- Stupid... Stupid... STUPID!!! __________==___gitqexec | Chris W | Products | 0 | November 10th 04 12:39 AM |
Stupid Americans! -- Stupid... Stupid... STUPID!!! __________==___ gitqexec | Richard Hertz | Products | 0 | November 7th 04 11:45 PM |
