#81
Jim Macklin schrieb:
I've always used rudder and elevator to hold the nose on a point when rolling, the roll being done with aileron and the nose held on the point with sometime uncoordinated use of the controls. Hopefully your use of the controls in a roll are well coordinated. Which doesn't mean the ball stays in the middle. Stefan |
#82
Ron;
I think what might be happening here is that some folks are defining the roll from the set point rather than from level flight. It's true that any raising of the nose from level flight will require more than 1 g, but once at the set point and initiating the roll (aileron roll) you can unload the airplane all the way down to 0 g if you like right up to the backside recovery to level flight, where the g of course has to be returned. Dudley Henriques "Ron Natalie" wrote in message m... Big John wrote: Andrey As has been said in all the posts, the short answer is NO. 172 is not certified to do barrel rolls. However I can barrel roll a 172 only pulling 1 G which puts no more load on airframe than straight and level flight. I have thousands of hours to back up my statement. No you can not. It's not possible to even start the roll without going greater than 1G. |
#83
That would be, "Hey, y'all, hold my beer and watch this."
Jim The most dangerous incidents in aviation are often proceded by "Watch this." |
#84
![]() "Jim Macklin" wrote in message news:Ol5wg.79455$ZW3.31376@dukeread04... I've always used rudder and elevator to hold the nose on a point when rolling, the roll being done with aileron and the nose held on the point with sometime uncoordinated use of the controls. I've never flown in competition. Never done slow or hesitation rolls. If I had my way, I'd do a hundred hammerheads for every roll. I had called that an aileron roll, but from the site, that is a slow roll, even if it is done fast! g Which acro site, give a link and I'll check it out. http://www.iac.org/begin/figures.html#Aileron%20Rolls Good site. -- Jim in NC |
#85
certified to do barrel rolls. However I can barrel roll a 172 only pulling 1 G which puts no more load on airframe than straight and level flight. I have thousands of hours to back up my statement. No you can not. It's not possible to even start the roll without going greater than 1G. Ron; I think what might be happening here is that some folks are defining the roll from the set point rather than from level flight. It's true that any raising of the nose from level flight will require more than 1 g, but once at the set point and initiating the roll (aileron roll) you can unload the airplane all the way down to 0 g if you like right up to the backside recovery to level flight, where the g of course has to be returned. Dudley Henriques Dudley, they are not paying attention. They are thinking every maneuver has to start and be flown from the straight and level. They don't think in terms of up/down-lines at any angle. ie.... Reverse half-Cuban with a barrel roll on the down 45. |
#86
Stefan
Have done many in real life. Go to Google and research Barrel Rolls. You will find links that show you can do them between 0.5 G's and max G's bird is certified for. Beside these 'experts' who posted, all I can say is fly the airplane. If you want 1 G then fly it that way. If you can't fly it that way then don't get in bird as you are an accident waiting to happen. Big John `````````````````````````````````` On Fri, 21 Jul 2006 11:10:53 +0200, Stefan wrote: Big John schrieb: I'm glad your the expert. I'm far from being an expert, but I have an idea, yes. I used to do half of a barrel roll at one G and give to student under If you can actually do a barrel roll without exceeding 1g at any point, then you should immediately inform your local university. Or, better yet, directly the nobel commitee. Because you've just proved that some very basic physical laws are wrong. Stefan |
#87
![]() Jim You explained what has been known as a 'slow roll' since I started flying heavy iron in the 40's. Have heard them called point rolls also but only on rare occasions. I thinK Stephen may be a Troll from his postings. I'm going to stop trying to feed him ![]() Big John `````````````````````````````````````````````````` ``````` On Fri, 21 Jul 2006 09:17:40 -0500, "Jim Macklin" wrote: I've always used rudder and elevator to hold the nose on a point when rolling, the roll being done with aileron and the nose held on the point with sometime uncoordinated use of the controls. I've never flown in competition. Never done slow or hesitation rolls. If I had my way, I'd do a hundred hammerheads for every roll. Which acro site, give a link and I'll check it out. |
#88
T o d d P a t t i s t wrote
Starting the BR with the aircraft track at 90 degrees to the barrel produces a loop (no roll portion to the BR). Starting it parallel to the barrel (and reducing the diameter of the barrel to zero) makes it into an aileron roll (no loop portion to the BR). Everything in between is possible, and at some point on either side as you get closer to the loop or aileron roll, you've got to stop calling it a BR. You might not have his thousands of hours, but you certainly understand a lot more about barrel rolls than does Big John. :-) :-) Of course, what can you expect from a person who flys "birds" instead of "airplanes". :-) May be some definitions...:-) Barrel Roll....................45 degrees off axis Aileron roll...................00 degrees off axis Loop...........................90 degrees off axis Sloppy barrel roll......22.5-67.5 degrees off axis Sloppy aileron roll.......01-22.5 degrees off axis Sloppy loop...............67.5-89 degrees off axis Bob Moore |
#89
On Fri, 21 Jul 2006 16:49:49 GMT, Bob Moore
wrote in :: May be some definitions...:-) Barrel Roll....................45 degrees off axis Aileron roll...................00 degrees off axis Loop...........................90 degrees off axis Sloppy barrel roll......22.5-67.5 degrees off axis Sloppy aileron roll.......01-22.5 degrees off axis Sloppy loop...............67.5-89 degrees off axis This refers to the direction of flight relative to the longitudinal axis of the aircraft? |
#90
![]() Ron Wrong choice of words. Straight and level your G meter reads one G,(force of gravity) if calabrated correctly. You roll into a turn and pull one G (2 G's on meter) to make a one G turn. Please correct my posts to show this. I should have said two G's on meter and things would work out. Sorry about that ![]() Big John `````````````````````````````````````````````````` `````````` On Fri, 21 Jul 2006 10:30:11 -0400, Ron Natalie wrote: Big John wrote: Andrey As has been said in all the posts, the short answer is NO. 172 is not certified to do barrel rolls. However I can barrel roll a 172 only pulling 1 G which puts no more load on airframe than straight and level flight. I have thousands of hours to back up my statement. No you can not. It's not possible to even start the roll without going greater than 1G. |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 04 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | July 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | June 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 08:27 AM |
