J.Kahn wrote:
The stuff is rolled into coils for shipment. Scroll down and check out the flat version bent by hand into a half circle. Yup, that's the way I get it, spools of 1000 to 1500 feet. |
![]() Bob Kuykendall wrote: J.Kahn wrote: The stuff is rolled into coils for shipment. Scroll down and check out the flat version bent by hand into a half circle. I've seen a picture of graphlite (TM) rod bent into a loop with a radius of about an inch or so. Now, imagine that you want a 2" diameter ring, like a key ring. Would you bend the rod into a circle and glue the ends together? I think not! Yup, that's the way I get it, spools of 1000 to 1500 feet. As you probably noticed, when you take it off the spool, it straightens out. I want to shape it so that it is curved without any applied stress. -- FF |
Fred,
The graphlite derives its strength from the fact that the individual carbon fibers are all kept very straight. Even when slightly bent, the fibers in any local vicinity are still relatively straight. If you try to heat it past its transition temperature while bent, the fibers under more tension will try to displace toward the fibers under less tension. I believe that you could do this; transition temperature is transition temperature; I don't think you got it hot enough... But then you would lose the basic strength characteristic of the material. Bob's suggestion of using/joining smaller diameter rods is a logical one. The pre-stress here may be something that you can easily live with... When joining with other same diameter rods or larger diameter rods for axial loads, you need to have enough length such that the surface area of the adhesive around the rod times its psi strength equals the psi strength of a rod. For a round rod in tension L has to be approx. 80 D; assuming an adhesive strength of 1,000 psi. So you can see that smaller diameter rods have to have less length joining. I have been giving some thought as to how to use this material other than in a strictly axial loading, e.g. wing spars. Still thinking... Blue skies, Tom wrote: Bob Kuykendall wrote: J.Kahn wrote: The stuff is rolled into coils for shipment. Scroll down and check out the flat version bent by hand into a half circle. I've seen a picture of graphlite (TM) rod bent into a loop with a radius of about an inch or so. Now, imagine that you want a 2" diameter ring, like a key ring. Would you bend the rod into a circle and glue the ends together? I think not! Yup, that's the way I get it, spools of 1000 to 1500 feet. As you probably noticed, when you take it off the spool, it straightens out. I want to shape it so that it is curved without any applied stress. -- FF |
![]() J.Kahn wrote: wrote: Bob Kuykendall wrote: J.Kahn wrote: The stuff is rolled into coils for shipment. Scroll down and check out the flat version bent by hand into a half circle. I've seen a picture of graphlite (TM) rod bent into a loop with a radius of about an inch or so. Now, imagine that you want a 2" diameter ring, like a key ring. Would you bend the rod into a circle and glue the ends together? I think not! Yup, that's the way I get it, spools of 1000 to 1500 feet. As you probably noticed, when you take it off the spool, it straightens out. I want to shape it so that it is curved without any applied stress. I don't think it's necessary to eliminate all preload. Nor do I. But if I want a curved structure made from the rod to hold its shape without a lot of built-in stress it is necessay to eliminate MOST of the pre-load. ... I would extend a graphlite top rib cap as far forward as it can be comfortably bent by hand and use a wood nose block for the very front for the nose radius. I wouldn't even consider doing that. If I'm going to use materials in addition to graphlite rod, I'll use foam, monofilament tapes, fiberglass, or some such. I love working with wood. I just don't see that as a efficatious use, if I'm already using composites. As noted before, there are a myriad of perfectly servicable alternatives, all of which are outside of the scope of the original question. There is no problem at all finding alternatives and how to use them. Perhaps more to the point, I just suggested a rib as an example. Being able to bend graphlite rod like one steam bends wood opens up a lot of design possibilites. Imagine, instead of reinforcing other materials with the rod, making a wing, or wing and fuselage built like a birdcage and then covered with Dacron. Not the cheapest and maybe not the lightest or strongest and certainly not the most practical way to go. But an interesting concept. How about a dirigible made the same way? (Here one could probable accept the pre-loading as there would be no really tight radius curves.) How about a kayak? How about a key-ring? If it CAN'T be done, then it can't be done. -- FF |
![]() wrote Perhaps more to the point, I just suggested a rib as an example. Being able to bend graphlite rod like one steam bends wood opens up a lot of design possibilites. Imagine, instead of reinforcing other materials with the rod, making a wing, or wing and fuselage built like a birdcage and then covered with Dacron. Not the cheapest and maybe not the lightest or strongest and certainly not the most practical way to go. But an interesting concept. How about using flat graphite stock and laminate the shape you want to end up wit. That would eliminate purdy much all of the preload, no? g -- Jim in NC |
![]() Morgans wrote: wrote Perhaps more to the point, I just suggested a rib as an example. Being able to bend graphlite rod like one steam bends wood opens up a lot of design possibilites. Imagine, instead of reinforcing other materials with the rod, making a wing, or wing and fuselage built like a birdcage and then covered with Dacron. Not the cheapest and maybe not the lightest or strongest and certainly not the most practical way to go. But an interesting concept. How about using flat graphite stock and laminate the shape you want to end up wit. That would eliminate purdy much all of the preload, no? g The cat's meow would be pultruding it directly into the desired shape. That's a bit beyond the capabilites of the homebuilder--I think. -- FF |
![]() Ernest Christley wrote: wrote: Perhaps more to the point, I just suggested a rib as an example. Being able to bend graphlite rod like one steam bends wood opens up a lot of design possibilites. I think you're missing the forest for the trees. A wood steamer is your answer. Make a form out of sheet metal, then bend the graphlite around it. Tg is around 180F for most epoxies, so an hour at 212F should turn it to it's plastic state throughout. The internal bending stresses will pull themselves out. Take it out of the oven, and it should hold whatever shape it had been forced into. I first tried heating the rod in boiling water and bending it. No dice. I then tried heating it with a heat gun, still wouldn't bend. But that time I heated the middle of the rod, not the end. I'll go back and try heating the end. Then I may take up your suggestion, but bending the rod to a tight curve while it is at room temperature is NOT trivial. Phenolic resins are thermosetting. While they do have a glass transition temperature, that GTT increases when the material is heated, making it a moving target. My impression is that most phenolic resins will char befor they soften. There are thermoplastic resins that have a reproducible GTT. Dunno if anybody makes pultruded rod using them though. I am also less than confident in the vendor's published descriptions of the products. Even if they were accurate when written the vendor may change their source to a similar product without updating the description. Now, what I understand of graphlite is that it gets it's strength from having all the fibers aligned and equally tensioned. Doing the above, you will probably get something only marginally better than a hand layup. But you won't know until you try. You and a preceding author both raised this point and it is well taken. Maybe if the rod is bent 'monotonically', I.e. bent onto the form without wiggling it the fibers will slip in only one direction and retain their approximately equal tension. -- FF |
Bending sheet stock | Michael Horowitz | Restoration | 1 | April 24th 06 04:28 AM |
Wing Bending Oscillation | jcarlyle | Soaring | 18 | February 21st 06 04:37 PM |
Bending extruded angle | Veeduber | Home Built | 8 | August 29th 04 12:58 AM |
Building the Po' Boy Bending Brake | Veeduber | Home Built | 14 | March 1st 04 06:15 PM |
Minimum bending radius for 0.050" 6061-T6? | Bob Chilcoat | Home Built | 11 | February 5th 04 04:59 PM |
