Can anyone point me towards some good resources for CRM in a
non-professional environment with two pilots? (i.e. which pilot should do what?) I'm looking to do some personal flying with other pilots and would like both of us to participate in the flight and be able to divide up the PF/PNF tasks properly, or at least put some structure with it. Any tips? --Dan |
non-professional environment with two pilots? (i.e. which pilot should do what?) I suggest marrying the other pilot. It keeps things in perspective. (Hey, it works for Mary and me...) ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Dan wrote:
I'm looking to do some personal flying with other pilots and would like both of us to participate in the flight and be able to divide up the PF/PNF tasks properly, or at least put some structure with it. Any tips? If it were me (and I've only flown without a crew all these years), what I'd give the other guy to do is the navigation and communication chores. He needs to keep his hands off the yoke, flaps, gear, etc unless you're taking a break. OTOH, he sets up the radios, does all the talking, determines position, etc. while you leave his stuff alone. This assumes you trust him to do this. Situations vary. -- Mortimer Schnerd, RN VE |
On 21 Jul 2006 20:30:44 -0700, "Dan" wrote in
. com:: Can anyone point me towards some good resources for CRM in a non-professional environment with two pilots? (i.e. which pilot should do what?) I copied this out of a magazine several years ago when I was often flying with another pilot: Cockpit Resource Management CRM is the effective use of all resources - hardware, software, leadership, and humanware - to achieve safe and efficient flight operation. Don't divide duties as they are on most airlines. There, the pilot becomes too dependent on a copilot, because the pilot simply flies the aircraft, while the copilot does everything else - radios, navigation, checklists, and backing up the pilot as to proper altitudes and headings. The CRM philosophy puts the onus on the pilot for communications, checklists, and decision making. Decisions are based on the concerns of the less comfortable pilot. The copilot handles navigation, cross-checks the pilot's communication and navigation frequencies for an instrument approach, and assures that the altitude requirements are met at the final approach fix and at minimums. The copilot still has plenty to do, managing the aircraft's loran, RNAV radio, or handheld GPS moving map display that is used as a backup. In addition, the copilot scans for other traffic, keeps a running check on fields in which to land - just in case - and keeps track of the nearest airport. The copilot knows s/he is to support and backup the pilot and offer help in emergency situations. Pre-takeoff briefing is important for any flight; it can be abbreviated, however, when another pilot is aboard. It can be as simple as thinking out loud. If you expect the other pilot to help with the flight, say so before takeoff. Spend several minutes before the flight explaining to the non-pilot passenger how to control the aircraft and how to communicate. Once in the air, spend a few minutes letting the passenger fly. It is fun for the passenger and gives the pilot another resource to use in case of a medical emergency. |
Dan wrote:
Can anyone point me towards some good resources for CRM in a non-professional environment with two pilots? (i.e. which pilot should do what?) I wrote an article describing what I do that you may find helpful. Go to my site and click through: Aviation-Articles-Miscellaneous-Crew Procedures And although it's more of a travelogue rather than strictly crew-ops oriented, you may find another article helpful. Click through: Aviation-Articles-Travelogues-Crew Operations Safe flying, -Doug -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
By the posts that I have seen, apparently, there hasn't been much study done
in this area. The articles I have seen over the years either deal with CRM in a commercial, crew setting or with non-pilot spouses. I did find this article by Mark Twombly from 1996 that basically says we are a bunch of independent-minded PICs that need to CYA when flying with other pilots. http://www.aopa.org/members/files/pi...6/mrt9609.html For context, I am PP SEL, SES, IA. Just a weekend flyer. About 200 hours/year. I have a number of friend pilots that I fly with on a regular basis. Flying with another pilot in a small plane is completely different than any other situation. The commercial guys have been through the same training and can have the concepts and their role in CRM more clearly defined. With non-pilot spouses, there is a clear assignment of responsibility and, with most spouses, an automatic deferal to the PIC. In the beginning, it will be very much an assignment of tasks by the PIC to the spouse. Since we are talking about fellow-pilots who are theoretically both capable of being PIC, it is all about trust and communication. Communication can be created. Trust must grow. How I approach CRM depends on how much time I have with the other pilot. With someone new to me, I make it clear who is PIC. If I am PIC, then I make it clear what I expect from the other person. If I am not PIC, then I defer up to a point. If the other pilot hasn't said much by the time they are ready to turn the key, then I do. I want to make it clear that it is their flight and that, if they expect me to take an active role, they need to speak up. What must be avoided is an "if you don't know, I'm not going to tell you" attitude once airborn. As the comfort level grows, division of duties can be leveraged. Some of my flights are IFR refresher flights. I want to do as much of the flying as possible to simulate single-pilot IFR workload. Most of the time, the other guy is just a pair of eyes. I do fly with a couple of pilots who I do trust and they will have a more active role of providing "vectors" and creating scenarios. Otherwise, my relationships with other pilots range from identifying sole responsibility for the flight to shared duties. And, it varies from flight to flight even with the same pilot. Since we are in a single-pilot plane, I have had friends show up and say, "I would like to just go along for the ride today. Is that OK?" I enjoy both. Riding along as the passenger watching the scenery go by is very relaxing. Interacting in a crew environment is exciting, stimulating and always a learning opportunity. Just be sure who is doing the relaxing and who is doing the flying. -- ------------------------------- Travis Lake N3094P PWK "Doug Vetter" wrote in message ... Dan wrote: Can anyone point me towards some good resources for CRM in a non-professional environment with two pilots? (i.e. which pilot should do what?) I wrote an article describing what I do that you may find helpful. Go to my site and click through: Aviation-Articles-Miscellaneous-Crew Procedures And although it's more of a travelogue rather than strictly crew-ops oriented, you may find another article helpful. Click through: Aviation-Articles-Travelogues-Crew Operations Safe flying, -Doug -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
"Travis Marlatte" wrote in message
om For context, I am PP SEL, SES, IA. Just a weekend flyer. About 200 hours/year. I have a number of friend pilots that I fly with on a regular basis. Just a weekend flyer getting about 200 hours per year? That's a lot of flying every weekend. ![]() -- John T http://sage1solutions.com/TknoFlyer Reduce spam. Use Sender Policy Framework: http://spf.pobox.com ____________________ |
Doug,
Thanks for the reference, that was a good article. --Dan Doug Vetter wrote: Dan wrote: Can anyone point me towards some good resources for CRM in a non-professional environment with two pilots? (i.e. which pilot should do what?) I wrote an article describing what I do that you may find helpful. Go to my site and click through: Aviation-Articles-Miscellaneous-Crew Procedures And although it's more of a travelogue rather than strictly crew-ops oriented, you may find another article helpful. Click through: Aviation-Articles-Travelogues-Crew Operations Safe flying, -Doug -------------------- Doug Vetter, ATP/CFI http://www.dvatp.com -------------------- |
This is a well-written article. Thanks for sharing.
Recently, my friend and I flew from KALE-KAWO to the NW EAA Fly-In at Arlington, WA, USA. He has decided to go for his instrument rating and wanted to brush up on his flying skills under the hood. We left Salem very early and he put on his hood. As I was not PIC, he had final authority on everything. This was a very clear understanding between us. However, he did delegate radios and navigation to me. By doing this, we had a fun flight for both of us on the way up and back. We both have strong, dominant personalities, so sometimes we stepped on each other a little bit, but it was to ensure safety-of-flight. As it was my first time as SIC and as Safety Pilot, it was a learning experience. I enjoyed it a lot. Good luck Dan, Chris Travis Marlatte wrote: By the posts that I have seen, apparently, there hasn't been much study done in this area. The articles I have seen over the years either deal with CRM in a commercial, crew setting or with non-pilot spouses. I did find this article by Mark Twombly from 1996 that basically says we are a bunch of independent-minded PICs that need to CYA when flying with other pilots. http://www.aopa.org/members/files/pi...6/mrt9609.html For context, I am PP SEL, SES, IA. Just a weekend flyer. About 200 hours/year. I have a number of friend pilots that I fly with on a regular basis. Flying with another pilot in a small plane is completely different than any other situation. The commercial guys have been through the same training and can have the concepts and their role in CRM more clearly defined. With non-pilot spouses, there is a clear assignment of responsibility and, with most spouses, an automatic deferal to the PIC. In the beginning, it will be very much an assignment of tasks by the PIC to the spouse. Since we are talking about fellow-pilots who are theoretically both capable of being PIC, it is all about trust and communication. Communication can be created. Trust must grow. How I approach CRM depends on how much time I have with the other pilot. With someone new to me, I make it clear who is PIC. If I am PIC, then I make it clear what I expect from the other person. If I am not PIC, then I defer up to a point. If the other pilot hasn't said much by the time they are ready to turn the key, then I do. I want to make it clear that it is their flight and that, if they expect me to take an active role, they need to speak up. What must be avoided is an "if you don't know, I'm not going to tell you" attitude once airborn. As the comfort level grows, division of duties can be leveraged. Some of my flights are IFR refresher flights. I want to do as much of the flying as possible to simulate single-pilot IFR workload. Most of the time, the other guy is just a pair of eyes. I do fly with a couple of pilots who I do trust and they will have a more active role of providing "vectors" and creating scenarios. Otherwise, my relationships with other pilots range from identifying sole responsibility for the flight to shared duties. And, it varies from flight to flight even with the same pilot. Since we are in a single-pilot plane, I have had friends show up and say, "I would like to just go along for the ride today. Is that OK?" I enjoy both. Riding along as the passenger watching the scenery go by is very relaxing. Interacting in a crew environment is exciting, stimulating and always a learning opportunity. Just be sure who is doing the relaxing and who is doing the flying. |
I gotta keep the per hour cost down somehow!!
-- ------------------------------- Travis Lake N3094P PWK "John T" wrote in message m... "Travis Marlatte" wrote in message om For context, I am PP SEL, SES, IA. Just a weekend flyer. About 200 hours/year. I have a number of friend pilots that I fly with on a regular basis. Just a weekend flyer getting about 200 hours per year? That's a lot of flying every weekend. ![]() -- John T http://sage1solutions.com/TknoFlyer Reduce spam. Use Sender Policy Framework: http://spf.pobox.com ____________________ |
CFI without commercial? | Jay Honeck | Piloting | 75 | December 8th 10 04:17 PM |
Sport Pilot pilots not insurable? | Blueskies | Piloting | 14 | July 12th 05 05:45 AM |
Dumb Reg question | John Gaquin | Piloting | 67 | May 4th 05 04:54 AM |
FA: Huge collection of Private Pilot Books | mablacksv | Aviation Marketplace | 0 | April 1st 04 06:40 AM |
