barrel roll in 172
Old July 23rd 06, 07:02 AM posted to rec.aviation.piloting
Larry Dighera
Default barrel roll in 172
On Sun, 23 Jul 2006 01:54:35 GMT, Matt Whiting
wrote in ::
Flight load factor
Flaps up = +4.4 G's and -1.76 G's
So, in inverted flight a C-172 has only a 76% of a G margin to carry
additional G force. That isn't much.
Thanks.
No, 176% of a G.
No. A _margin_ of only a 76% of a G to carry G forces in addition to
the one G natural force.
Old July 23rd 06, 03:00 PM posted to rec.aviation.piloting
Matt Whiting
wrote in ::
Flight load factor
Thanks.
No, 176% of a G.
When you are pulling negative G, there is no one natural G force. It
takes -1 G of acceleration to counter gravity and get you to 0 G. You
can then add -1.76 G of additional acceleration and still be within load
limits. The negative G load factor is referenced to 0 G, not 1 G
straight and level.
Matt
Old July 23rd 06, 05:24 PM posted to rec.aviation.piloting
john smith
straight and level.
Is negative G an up force or a down force?
Old July 23rd 06, 08:13 PM posted to rec.aviation.piloting
Morgans[_3_]
"john smith" wrote in message
straight and level.
I'll disagree, here.
Straight level flight, right side up is 1 G
Free-fall, so you are not touching the seat or seatbelt is O G
Straight level flight upside down, is -1G
If the plane is upside down, and pushes up elevator, until a100KG weight
weighs 176KG, that is a -1.76 G factor. Not much extra for upside down
flight, is it.
Jim in NC
Old July 25th 06, 11:09 PM posted to rec.aviation.piloting
Matt Whiting
straight and level.
It is an acceleration opposite the normal acceleration due to gravity,
so it would be downward with respect to the airframe.
Matt
Old July 25th 06, 11:21 PM posted to rec.aviation.piloting
Peter R.
What about the case of a fighter jet climbing on afterburners at a steep
nose-high attitude quickly rolling forward through the horizon to a steep
nose-low attitude? Wouldn't the negative G force be considered an upward
force with respect to the airframe?
Peter
Old July 26th 06, 12:17 AM posted to rec.aviation.piloting
Larry Dighera
On Tue, 25 Jul 2006 18:21:54 -0400, "Peter R."
wrote in ::
Of course.
Old July 23rd 06, 07:10 PM posted to rec.aviation.piloting
Larry Dighera
On Sun, 23 Jul 2006 14:00:37 GMT, Matt Whiting
wrote in ::
wrote in ::
Flight load factor
Thanks.
No, 176% of a G.
While you are in the vicinity of the Earth, your aircraft is being
acted upon by the Earth's one G gravitational force.
If you are flying straight and level while inverted, the airframe is
experiencing -1G, not 0 G.
That provides the remaining 0.76 (76%) of a G of the C-172's negative
load factor specification of -1.76 to carry the load of any
acceleration that may subsequently occur.
It takes -1 G of acceleration to counter gravity and get you to 0 G.
Agreed.
You can then add -1.76 G of additional acceleration and still be within load
limits.
That analysis presumes the aircraft is not inverted.
straight and level.
Are not both the positive and negative load factors referenced to 0 G?
You don't set your G-meter to 0 when you are on the taxiway; you set
it to read 1 G, right?
We were discussing the negative load that might be encountered during
the inverted recovery from a barrel roll, so the earth's gravity would
add to any accelerative force while the aircraft is inverted, right?
Old July 23rd 06, 09:18 PM posted to rec.aviation.piloting
RomeoMike
If the barrel roll is performed correctly it is a +G maneuver
throughout, even while inverted.
Old July 24th 06, 12:10 AM posted to rec.aviation.piloting
Larry Dighera
On Sun, 23 Jul 2006 14:18:23 -0600, RomeoMike
wrote in
While that may be true, it isn't pertinent to this branch of this
message thread:
Newsgroups: rec.aviation.piloting
Subject: barrel roll in 172
Message-ID: 2SQvg.78944$ZW3.35114@dukeread04
Date: Thu, 20 Jul 2006 14:31:05 -0500
The issue is recovery from a botched barrel roll, such as in
inverted stall followed by a high speed dive and too strong
a pull on recovery.
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 04 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 July 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 June 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 08:27 AM
