Frequency pair
Old July 23rd 06, 08:20 AM posted to rec.aviation.piloting
Dave S
Default Frequency pair
thejim wrote:
Can someone explain me what do we mean by the term frequency pairing?
I met the term in an avionics book.The phrase is the following;
The DME interrogation and reply frequency are paired with VOR
frequency.
Thank you
VOR's are in the VHF band (108-118 mHz approx)
DME's are in the UHF band (up in the 400's mHZ)
When you tune a DME, the VHF frequency you enter on the device (or have
channeled to it from the nav) is a paired frequency, established years
ago by international convention.
Dave
Old July 23rd 06, 03:55 PM posted to rec.aviation.piloting
RST Engineering
Noooo...
VORs (plural, not possessive) are in the VHF band (108-118 MHz. exactly)
Glideslopes are in the UHF band (325 MHz. or so)
DMEs are in L band (1000 MHz or so)
"Dave S" wrote in message
nk.net...
Old July 24th 06, 01:55 AM posted to rec.aviation.piloting
Dave S
Thanks Jim...
I know I can count on you to keep me straight when I fudge radio stuff a
little bit.
Dave
RST Engineering wrote:
Noooo...
nk.net...
Old July 29th 06, 02:53 PM posted to rec.aviation.piloting
Ron Natalie
Noooo...
Actually, the apostrophe is NOT incorrect here if you consider VOR
to be a grouping of letters (abbreviation) rather than a acronym
(a word made out of the abbreviation). Certainly DME is not an
acronym. The rules of usage allow don't really favor one or the
other.
Old July 29th 06, 03:17 PM posted to rec.aviation.piloting
Bob Noel
other.
VOR and DME are both acronyms (VOR being a compound
acronym).
VOR - Very High Frequency Omni-directional Range
DME - Distance Measuring Equipment
Bob Noel
Looking for a sig the
lawyers will hate
Old July 29th 06, 03:47 PM posted to rec.aviation.piloting
John[_2_]
other.
acronym).
No. How do you pronounce "DME" as a word? "NASA" is an acronym. "RADAR"
is an acronym. DME is not, although it is an abbreviation.
Abbreviations, not acronyms.
Old July 29th 06, 04:17 PM posted to rec.aviation.piloting
Bob Noel
In article , John
acronym).
My dictionary doesn't say anything about pronouncing an acronym as a word.
Abbreviation: a shortened form of a word or phrase used for brevity
Acronym: A word formed from the initial letter or letters of each of the
successive parts or major parts of a compound term.
Bob Noel
lawyers will hate
Old July 29th 06, 05:36 PM posted to rec.aviation.piloting
Casey Wilson[_1_]
"Bob Noel" wrote in message
In article , John
acronym).
Bob Noel
lawyers will hate
An acronym is not a word. Like Bob said there is no requirement that an
acronym be pronouncable, . For detailed references, troop down to your local
library (or branch) and peruse the Chicago Manual of Style, AP Style Guide,
or New York Time Manual of Stye and Usage.
Old July 29th 06, 05:59 PM posted to rec.aviation.piloting
Peter Duniho
Did you look up the definition of "word"? How is "DME" a "word"? As Ron
implies, "VOR" *could* be considered a "word", but the vast majority of us
spell it out and don't consider it to be a "word".
Old July 23rd 06, 05:18 PM posted to rec.aviation.piloting
On Sun, 23 Jul 2006 07:20:16 GMT, Dave S
frequency.
Thank you
Dave
It's even more complex than it first looks:
There are 200 VHF channels allocated for NAV/DME of which 40 are also
paired with the ILS. That means when you tune to a VHF NAV frequency
you also tune the DME transmitter, DME receiver and ILS receiver. Each
part of the system uses a separate range of frequencies but for
simplicity selecting one automatically selects the rest.
These a
108-117.95MHz VOR/LOC
1041-1150MHz DME Transmitter
978-1213MHz DME Receiver
328-336 MHz Glideslope Receiver
(Glideslope selected by the VHF range up to 111.95MHz)
Being mere pilots all we need to know is when you tune the NAV
everything else should follow as it is 'paired'.
David
Torsional Vibration and PSRU Design Gordon Arnaut Home Built 74 April 18th 06 11:41 PM
Boston Approach frequency question John R Piloting 6 June 22nd 04 08:22 PM
Check in ...East Coast BLACKOUT Montblack Owning 65 September 28th 03 09:51 AM
Check in ...East Coast BLACKOUT Montblack Piloting 71 September 28th 03 09:51 AM
Picking up ATC from 300 NM away? Frequency bleed? Peter R. Piloting 10 August 21st 03 02:32 PM
