I intend to buy a handheld.
Old July 23rd 06, 02:24 PM posted to rec.aviation.piloting
john smith
Default I intend to buy a handheld.
The NAV function is of use when you have to talk to FSS on a COM
frequency and listen on a NAV.
Also, weather information is available on some NAV's
Old July 23rd 06, 03:30 PM posted to rec.aviation.piloting
Alan Gerber
Is that capability built in, or do you have to switch frequencies every
time you switch between transmitting and receiving?
.... Alan
Alan Gerber
gerber AT panix DOT com
Old July 23rd 06, 05:09 PM posted to rec.aviation.piloting
john smith
Built into the ICOM's.
The original A-2 had the same processor programming as the ham 2m IC-2AT.
Using the 2AT instructions on programming the repeater duplex offset,
one could program the air band to perform the same function (tune NAV to
listen/receive, depress PTT button and the frequencey would change to
the COM frequency to transmit.
Getting the MOCA Dan Instrument Flight Rules 59 July 3rd 06 01:43 AM
More IFR with VFR GPS questions Chris Quaintance Instrument Flight Rules 58 November 30th 05 08:39 PM
Navcom - handheld VS panel ? [email protected] Home Built 10 October 31st 05 08:08 PM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
