On Sun, 23 Jul 2006 14:00:37 GMT, Matt Whiting
wrote in :: Larry Dighera wrote: On Sun, 23 Jul 2006 01:54:35 GMT, Matt Whiting wrote in :: Flight load factor Flaps up = +4.4 G's and -1.76 G's So, in inverted flight a C-172 has only a 76% of a G margin to carry additional G force. That isn't much. Thanks. No, 176% of a G. No. A _margin_ of only a 76% of a G to carry G forces in addition to the one G natural force. When you are pulling negative G, there is no one natural G force. While you are in the vicinity of the Earth, your aircraft is being acted upon by the Earth's one G gravitational force. If you are flying straight and level while inverted, the airframe is experiencing -1G, not 0 G. That provides the remaining 0.76 (76%) of a G of the C-172's negative load factor specification of -1.76 to carry the load of any acceleration that may subsequently occur. It takes -1 G of acceleration to counter gravity and get you to 0 G. Agreed. You can then add -1.76 G of additional acceleration and still be within load limits. That analysis presumes the aircraft is not inverted. The negative G load factor is referenced to 0 G, not 1 G straight and level. Are not both the positive and negative load factors referenced to 0 G? You don't set your G-meter to 0 when you are on the taxiway; you set it to read 1 G, right? We were discussing the negative load that might be encountered during the inverted recovery from a barrel roll, so the earth's gravity would add to any accelerative force while the aircraft is inverted, right? |
![]() Larry Dighera wrote: We were discussing the negative load that might be encountered during the inverted recovery from a barrel roll If the barrel roll is performed correctly it is a +G maneuver throughout, even while inverted. |
On Sun, 23 Jul 2006 14:18:23 -0600, RomeoMike
wrote in :: Larry Dighera wrote: We were discussing the negative load that might be encountered during the inverted recovery from a barrel roll If the barrel roll is performed correctly it is a +G maneuver throughout, even while inverted. While that may be true, it isn't pertinent to this branch of this message thread: From: "Jim Macklin" Newsgroups: rec.aviation.piloting Subject: barrel roll in 172 Message-ID: 2SQvg.78944$ZW3.35114@dukeread04 Date: Thu, 20 Jul 2006 14:31:05 -0500 The issue is recovery from a botched barrel roll, such as in inverted stall followed by a high speed dive and too strong a pull on recovery. |
On Sun, 23 Jul 2006 14:00:37 GMT, Matt Whiting wrote in :: Larry Dighera wrote: On Sun, 23 Jul 2006 01:54:35 GMT, Matt Whiting wrote in :: Flight load factor Flaps up = +4.4 G's and -1.76 G's So, in inverted flight a C-172 has only a 76% of a G margin to carry additional G force. That isn't much. Thanks. No, 176% of a G. No. A _margin_ of only a 76% of a G to carry G forces in addition to the one G natural force. When you are pulling negative G, there is no one natural G force. While you are in the vicinity of the Earth, your aircraft is being acted upon by the Earth's one G gravitational force. If you are flying straight and level while inverted, the airframe is experiencing -1G, not 0 G. That provides the remaining 0.76 (76%) of a G of the C-172's negative load factor specification of -1.76 to carry the load of any acceleration that may subsequently occur. If you had said 76% of a negative 1 G, I'd have agreed with you. :-) Just saying of a G, implies positive 1 G by most conventions. Matt |
Matt Whiting wrote: Just saying of a G, implies positive 1 G by most conventions. More accurately, doesn't it depend on your frame of reference? |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 04 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | July 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | June 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | May 1st 04 08:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | April 1st 04 08:27 AM |
