Oshkosh ATC - really picking up
Old July 25th 06, 08:23 AM posted to rec.aviation.piloting
Roger[_4_]
Default Oshkosh ATC - really picking up
On Mon, 24 Jul 2006 13:10:10 -0400, FlipSide wrote:
On Sun, 23 Jul 2006 16:39:11 -0400, "Morgans"
I'll try again, this time hitting tab instead of send.
Sunday 3:30 EDST, and for the last half hour or so, the frequency has been
non stop busy.
For those interested, I'm listening to http://www.liveatc.net/topfeeds.php
Click on the Oshkosh selection, in the top 20 feeds.
Some of it seems a little intimidating but ultimately learnable.
It is no place for a pilot who always flys a stabilized pattern. The
tell when to turn, where to turn and where to land. You may end up
flying over some one or having some one fly over you. They land up to
3 at a time.
What are the pink and orange dots? I know they are checkpoints but
what are they?
Spots on the runway The different colors are usually different shapes
as well.
www.rogerhalstead.com.
Old July 28th 06, 12:45 AM posted to rec.aviation.piloting
.Blueskies.
"Roger" wrote in message ...
: On Mon, 24 Jul 2006 13:10:10 -0400, FlipSide wrote:
: : It is no place for a pilot who always flys a stabilized pattern. The
: tell when to turn, where to turn and where to land. You may end up
: flying over some one or having some one fly over you. They land up to
: 3 at a time.
: What are the pink and orange dots? I know they are checkpoints but
: what are they?
: Spots on the runway The different colors are usually different shapes
: as well.
: Roger Halstead (K8RI & ARRL life member)
: (N833R, S# CD-2 Worlds oldest Debonair)
Saw a Mooney who was cleared for takeoff on 09 just sitting there. He then asked the controller if he was cleared for
takeoff...twice! There was a 337 on final. The controller finally got it through to the guy that, yes, you are cleared
for takeoff. The Mooney then started rolling, just about as the 337 was on short final. The 337 was told to go around,
and the controller told the Mooney to not rotate until told to do so. The Moony rolled on down, the 337 finally overtook
it, maybe 50' agl and just off the right side of the runway. The controller then said good job Mooney as he let them
rotate and get out. Amazing how cool and controlled the controller was - his voice did raise a bit during all this, but
he was smooth. The controllers are the glue...
....When they get back to their normal O'Hare or La Guardia jobs they probably feel bored... ;-)
Old July 28th 06, 03:25 AM posted to rec.aviation.piloting
Yea, I saw that one as well. I happened to look up when the controller
was telling him that he would call his rotation...(not a common
instruction!).
Gotta love OSH...
Old July 28th 06, 05:13 AM posted to rec.aviation.piloting
Roger[_4_]
instruction!).
That would be really interesting in the Deb. When it's ready to fly
it is going to fly. If you try to hold it on you'll end up riding on
the nose gear. Retrimming is not a viable option for two reasons. The
trim is very coarse. In level flight a bit over a 1/4" movement of the
trim wheel will either lift you out of the seat or give about 2Gs. The
second reason is that coarse trim wheel is under and forward of the
bottom edge of the panel. You have to instinctually know where it is
and you have to lean over a bit to reach it. Something I'd not want
to do while trying to hold it on the runway.
The only real alternative would be to back off on the power and hold
it just under rotation speed, then go full power when given the OK.
Gotta love OSH...
Old July 28th 06, 12:37 PM posted to rec.aviation.piloting
I also watched this year as a Cherokee landed in front of a Baron, the
twin pilot did a good job of slightly varying his takeoff roll and
maneuvering around the cherokee in front of him, taking off and going
on his way.
I'm not sure whose fault that was, either cherokee not putting it down
on the appropriate dot, or the twin not rolling when he should have, or
the controllers just not getting the spacing right,
but they asked us to get the cherokee N-number so someone could "talk
to him"...
Ryan Wubben
Flight Line Operations
Roger[_4_]
On Thu, 27 Jul 2006 23:45:42 GMT, ".Blueskies."
I never have gotten that link to OSH ATC to work on any of these
computers.
: 3 at a time.
: what are they?
: as well.
Yup. That's another thing. Have *everything* for departure and at
least the first 10 miles all in place before starting to taxi. When
they say go they mean go. When you pull into place you are expected to
be going in just seconds.
Old July 31st 06, 01:20 PM posted to rec.aviation.piloting
Ron Natalie
Which is a good idea for any busy airport. I can not understand people
who sit there and diddle their DG, transponder, whatever for two minutes
after being cleared for takeoff (at controlled fields) or after they
pull on to the runway at uncontrolled fields. About the only thing
I do while pulling on the runway is hit the strobes (if at night).
You're Invited to the 4th Annual Rec.Aviation Oshkosh Party(s)! [email protected] Home Built 5 July 6th 06 10:04 PM
You're Invited to the 4th Annual Rec.Aviation Oshkosh Party(s)! Jay Honeck Piloting 0 June 27th 06 04:58 AM
Got any EAA Oshkosh memorabilia? Jay Honeck Owning 0 October 15th 05 08:36 PM
Got any EAA Oshkosh memorabilia? Jay Honeck Home Built 0 October 15th 05 08:36 PM
How I got to Oshkosh (long) Doug Owning 2 August 18th 03 12:05 AM
